Question about Insignia IS-LCDTV32 32 in. Television
My insignia tv has volume problems and I am not sure if I need to return it or if it it something easy I can fix. Essentially almost as soon as it is turned on the volume disappears. It will continue to go in and out intermittently with times varying in between. It leans towards not working the majority of the time. If i use the digital box remote to turn up the volume eventually it'll come back, but almost immediately the sound will cut out again. As far as I can tell all wires etc are secure. The tv worked fine for the first hour or so after I bought it.
  • 71 Answers
SOURCE: remote control volume
Reset the TV. Unplug it, wait 1minute and replug it. Did it work?
Posted on Sep 11, 2008
John-INSG
  • 312 Answers
SOURCE: Insignia NS-LTDVD26 TV screen will cut out after
Issues of this type can generally only be resolved by repairs. Service can be obtained by carrying your TV in to the place of purchase.
Posted on Mar 25, 2010
SOURCE: Sound and Volume trouble
I bought my Insignia 32" LCD in November 2007 - same problem. I figured out that if you press the "input" button on your remote select any of the other options "component 1, composite 1, etc.. that you're TV isn't on -then press "input" again and go back to the component that you're TV plays on - you'll have volume when you go back every time. I've gotten so used to doing it now that it's become habit. 9 times out of 10 I have to do it.
Posted on Apr 01, 2008
  • 8457 Answers
SOURCE: Insignia NS-PDP50 Plasma TV - Remote Sensor failure
Change batteries.Reboot everythings.Tv unplug,replug couple mins later.Ur Directv box,push off/on for new update software.After that sould work.Rate me after u done this.
Posted on Jan 02, 2010
SOURCE: Insignia NS-LCD32 - 32" 720p Flat-Panel LCD Turns itself off, resets, then turns back on
It's haunted. You must appease the spirits with a virgin sacrifice.
Posted on Jan 15, 2010
Tv turns on but backlight fails to light up,
Have to make sure all ribbons are seated, and tabs locked. If any.
Feb 10, 2014 | Sharp LC60LE810UN 60 in. LCD TV
Insignia LCD TV screen goes black until hit.
Try to follow the inverter to backlight connections---either a loose or damaged plug (look for any plug with tape on it at the plug first) or on the board that powers the lights a bad solder connection or connections where plugs connect.
Oct 29, 2012 | Insignia NS-LCD26-09 26 in. HD-Ready LCD...
Insignia tv volume just shuts off. volume indicator shows volume still up.
Hi johneb77. The problem is the cables, You see the quality is not very good, the brand is average. i suggest you upgrate your tv, Or you will have to spend £180 to fix your problem, because it is hard to get the cables. Hope this helps!
Nov 05, 2010 | Insignia NSLTDVD26 LCD TV
We can't set up our 32 inch insignia 120Hz tv. It keeps saying "no signal." We have been on the phone to both Insignia and Comcast with each essentially blaming the other. We have a digital cable box...
Tries unplug tv and cable box replug both back about an hours.The tv now,it resetting itself back to the factory setting.The cable box is now resetting and it upgrading it softwares.The tv should work now.Not,tell the cable company sent u another box,still have same problems,the tv board call the Tuner signal board have problems,must be replace.This Tuner signal board,that the board,where the tv incomming broadcasting signal cable plug into it.If the tv is out of warrenty,tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Oct 24, 2010 | Insignia NS-L46X10A LCD TV
I have the same problem
Unfortunately your TV will need to be serviced. You may take the unit to Best Buy to arrange for repair.
Sep 18, 2009 | Insignia NS-LCD19 19 in. LCD TV
When the volume for my TV is at 100% the tv is almost too quiet to hear on some stations. Can this be fixed?
are you using any kind of digital cable or satellite box?
If so check and make sure all the seeting in the box is at 100% and set to FIXED
Also some tv's have an option for sound limiting as far as max volume and steady volume.
Make sure those are disbled.
Jul 16, 2009 | Insignia Televison & Video
Remote control volume
Aug 30, 2008 | Insignia IS-LCDTV32 32 in. Television
My phillips tv audio doesn't work well
This problem might be related to a bad control board that controls the Audio and Video and other functions. It costs $180.00 to replace. Not worth fixing
Jun 21, 2008 | Philips 27PT6441 27" TV
Lost volume
check the power amplifier IC at the audio section
Feb 01, 2008 | Samsung DLP HL-P5663W 56" TV
Insignia IS-LCDTV32 32 in. Television Logo
528 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
