Question about Honeywell Heating & Cooling
The display on my Honeywell Thermostat reads: 6Rt (or e) Lo What does this mean? The furnace is currently not working and this error message is displayed.
jaylex
  • 417 Answers
SOURCE: Can't What displayed error message means
49 error normally means that the information sent to the printer is corrupted clear the print que shut down printer and restart. If problem still there then shutdown the printer then remove one of the additional memory turn back on if still same problem repeat removal of the next memory replacing the one you have just removed and so on. After you have done this and you are still getting the problem then it is 99% certain that the printer system firmware is corrupted or the formatter control board is faulty.
Thanks J
Posted on Jan 27, 2008
Benimur
  • 6966 Answers
SOURCE: A thermostat versus an AC problem
"outside sensor error" is indicative of a Diagnostic error display, a feature where the device checks the functionality of each attached component. It would seem that your system has the optional "Outdoor Temperature Sensor" (probably P/N TSTATXXSEN01-B). The error then indicates that either that sensor is faulty or the hook up cable is unplug or defective. If you do not observed any critical changes in the comfort inside your home or the area that your system monitors/controls, then this only confirms that it is external and a sensor problem and does not affect the A/C and/or the variable speed furnace/comfort zone system. Normal faults could be the external sensor to cable connector/terminals being exposed to the elements and would require hard cleaning.
This sensor is not critical to the operation of the system and is optional.
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 04, 2008
SOURCE: EEE error message
I just talked to Honeywell support - they claim that an eee error means there has been a "unique error" and that the unit will need to be replaced - cannot be fixed. They were pretty good about giving a suggestion for a new thermostat and wiring directions if you want to DIY. Otherwise, call a pro.
Posted on Oct 11, 2008
cactus bob
  • 267 Answers
SOURCE: Honeywell Programmable Thermostat Display issues
there are currently 60 honeywell thermostats made i have no idea witch one you have , but a lot of the new ones run on batterys you might be seeing a low battery signal . look for a door where batterys might be and replace them
Posted on Jan 15, 2009
mastatech
  • 478 Answers
SOURCE: display is blank and furnace fan stays on
Remove wires at tstat Turn switch for furnace off than on.
touch the red wire to the white to simulate a call for heat.
Or Touhc red green and yellow to simulate a call for cool.
If that works get a new thermostat.
Posted on May 10, 2009
What does 54NC mean when displayed on my Honeywell room thermostat?
I'm guessing, I don't have your thermostat, but "NC" sounds like, "Not Connected". Check wiring at back of thermostat and at furnace.
May 13, 2015 | Heating & Cooling
Bae lo This is the message my electric Honeywell programable thermostat is flashing. It's still working. What's that mean? Thanks.
Try with this site:
Honeywell thermostat website: http://yourhome.honeywell.com/home/Applications/SmartSearchResults.aspx?searchkey=thermostatfor heating
Dec 12, 2010 | Heating & Cooling
Batt Lo Displayed. I replaced with new batteries. The display still reads Batt Lo and I cannot changed temperature, etc.
sometimes you can bend out the battery holders to allow more tention on the batteries but thats only a temporary repair. a new thermostat is needed
Oct 28, 2009 | Honeywell Programmable Thermostat Heater
Thermostat not functioning correctly
-AC means there is no power coming from the furnace. not a tstat problem
Sep 24, 2009 | Honeywell Programmable Thermostat Heater
No display on Robertshaw 9600; unit seems dead/furnace works
Hello
you have to have a thermostat! The thermostat tell the unite what to do. Get a new one.
Jul 25, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
26 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
