Question about Toshiba 57H81 57" Rear Projection Television
TOSHIBA 57H81 replaced conv amps and +- fuses set now fires without video. has horz and vert screen filament good. turn up screens get rgb glow with retrace. has good waveforms to the guns. 200v good. what am I MISSING.
  • doug white Dec 30, 2010
    all the parameters ie; screen high filament 200 voltages are good as are the waveforms to the guns. I am missing something
  • Toshiba Master
  • 1,548 Answers
I assume you checked the waveforms right at the CRT cathode pins, not just at the input connectors to the CRT boards. If I read this correctly, if you turn up the screen, you get a uniformly illuminated raster on each picture tube, overlaid with retrace lines, with no picture, and you have sound from the video source.
If this is so, you have vertical and horizontal deflection (the original failure is repaired, more or less, with only adjustments left to do), and the presence of the blank raster implies both the CRT grounds and second anode connections are good. What's left are the focus, G1 and G2 voltages (one of the grid voltages sets the screen and the other the brightness limit). Perhaps the brightness limit is killing the gain of the CRT (wiping out the video signal). The question arises, how did that get broken? Look for a cable that was not properly reconnected after you put the deflection board back in. If you remember putting tension on a cable when you removed the board, (missed unplugging it the first time you tried to remove it), check the other end to make sure it wasn't pulled partway out of its socket.
Don't feel too embarrassed if this turns out to be the case- how do you think I thought of checking for it?
Posted on Dec 30, 2010
    President:
  • Toshiba Master
  • 2,246 Answers
Change your tv dispalay screen
i hope this helpfull
please rate my answer
  • Lastoni Wibowo Jan 06, 2011
    change your tv dispalay screen
Screen size adjustment for horz.and vert/
Go to the start menu then control panel then click on display change the resolution to the highest setting
Feb 25, 2015 | HP dx2300 Monitor Personal computer Intel...
After 10 to 20 mins left half of screen goes to white vert lines
Sounds like power supply regulator board fault. Check all the electrolytic capacitors for any leaked or bulged one. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
Jul 01, 2014 | Samsung LN32D450G1D 32 LCD TV
My Compaq P110 monitor's VGA input does not working
posted 2 times, please erase one, thanks.
P110.
its a tuby 4:3 monitor, useless for wide video. plays.
1600 x 1200 at 85 Hz
do not exceed this, or boom. 1920x1080 will fail.
no resolution stated by you. and matters big time on all old monitors. (old = poor resolution only)
redux for less....words...
does it fail on all PCs connected, sure
does it fails set to lowest Resolution and 60hz?
RGB BNC only proves the analog side works.
not the digital side.
The VGA needs sync
if the PC is working (is it? on other monitors set to below reso.?)
then the 2 sync lines are active
at 1600 x 1200 , max (cant exeed this, ever)
then if that is true then the OSD buttons now work
do they? this is next.
does the On screen menu button work?
if not? it's a digital failure.....
or power to that section dead. or weak.
only googling finds schematics this old.
sorry.
nobody fixes these now, for good reasons.
labor costs on it would exceed a new LCD. fast.
we call this throwing good money after bad.
Sep 15, 2017 | Compaq P110 21" CRT Monitor
Toshiba 57h81 with sound and no pic? no menu but guns are lit???please help...ps just replaced stk392-110 with same...before this happened...removed screen to clean and when replaced back on, i got...
After the set has been on for 20 min., the heat sinks on those should be nice and warm. If they are then if you have a stand-up video I/O board with plug in jacks, make sure it is seated properly.....Try this first and let me know.
Aug 14, 2009 | Toshiba 57H81 57" Rear Projection...
Too dark sony model kv21gmr1
Warning: The following procedures should be done by an expert.
1.First step is to check the physical condition of the set.Before starting troubleshooting try to resolder the board and find any cold or loss solder.Then after plug the set and see if the filament of the tube glows.If not the trouble is in heater circuit.
2.After seeing the filament if it glows, check the CRT socket and open it.If you can see a sign of terminal decay such as greenish unwanted element on terminal surface,replace the CRT socket.
3.If replacement does remedy the problem check RGB drivers and resolder or replace jungle IC.
4.Try also to adjust the screen adjustment found in the flyback transformer.
5.Another possible cause is the vertical IC.Adjust the screen to full and see if their is a white horizontal line on the screen.If so the problem isin vertical circuit.
Jul 12, 2009 | Sony Televison & Video
Blinking power light & black screen on toshiba 57h81
This TV could have one of several problems including but not limited to; convergence IC's,bad capacitors, shorted horizontal output transistor. Call a good TV Tech. Check with the BBB before you decide on one.
Jul 11, 2009 | Toshiba 57H81 57" Rear Projection...
Red color convergence on Toshiba 57H81
Often convergence issues do not require the entire board to be replaced. You can resolve it by replacing the convergence ICs. The part in question is STK392-110. You will need two of them and they cost around 10$ each. But replacing them is a pretty complicated procedure and I would not suggest it to someone without prior experience. A service manual should get you started in the right direction if you are planning to do this yourself.
https://www.completeservicemanuals.com/toshiba/crt-projection-television/57h81-service-manual/prod_1128.html
PS
: Disconnect from the power supply before you start the repair. Also read the legend, the hv circuits are denoted by a special symbol, so you will know what you shouldn't touch.
You may also need to replace the nearby resistors that may have popped the IC in the first place. Read the service manual for further details.
Good luck,
Sai.
Apr 01, 2009 | Toshiba 57H81 57" Rear Projection...
1080 Mitzubitchi
CHECK FOR LIQUID SPILL ON THE SIGNAL BOARD. THE LIQUID IS FROM THE CRTS. ALSO IF THIS IS AN OLDER SET THE SET MAY BE GOING INTO IK BIAS PROTECT WHICH IS CAUSED BY A WEAK CRT. TRY TURNING THE SCREEN DRIVES UP A LITTLE AND SEE IF YOU GET RASTER. SCREEN DRIVE CONTROLS LOCATED BEHIND FRONT SPKR GRILL.
IF YOU PRESS MENU DO YOU SEE ANYTHING?
Jan 23, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H81 Flashing Red Power Light, Blown Fused F850+F852
Solved by resoldering some solder joints!!!!!!!
Toshiba Model 57H81 Rear Projection TV - Purchased 11-09-2001
Problem: Toshiba 57H81 Flashing Red Power Light, No Picture/Sound, Blown Fuses F850 + F852
Symptoms January, 2009:
  • Upon turning on set I got flashing red power light and nothing else.
  • Removing plug for one minute and plugging in results in:
    • Audible click, steady red power light for 2 seconds then slow flashing red light
    • Pushing power button results in steady red for about 2 seconds then slow flashing red light, no other set activity
  • Removing power cord for several hours and plugging back in made no change
    • Audible click, steady red for about 2 seconds then slow flashing red light
  • Possible related note: Over past several months occasionally the entire screen would flicker momentarily and at other times be problem free for weeks.
  • Fuses F850 and F852 found blown
Repairs Made:
  • PD0074 DEF/CON Power Board
    • There are two main power supply capacitors in this set. They are C-809 and C-810. One their negative lead on the printed circuit board re-soldered leads and nearby contacts. I’m told that because the factory left out a printed circuit board eyelet, the connection will come loose over time. When I called Toshiba customer service they said there was a known solder joint problem causing blinking red light.
    • Replaced blown fuses F850 and F852.
      • I actually installed a fuse panel on the inside of the cabinet and routed the fuse connections here instead of ordering the special fuses and replacing them on the circuit board.
      • Had to use a 5 Amp SLO-BLOW for F850. Fast blow does not survive power up. Get the red blinking light.
      • Used a fast blow 2 Amp for F852.
  • PD0073 SIGNAL Board
    • Re-soldered Q751 + Q752 STK392-110 Convergence Amps
    • Re-soldered adjacent pads that looks suspicious
Total Cost to Repair about $10
  • Twelve hours of my time over three days to research issue, disassemble set, make repairs, add fuse panel.
  • Already owned Service Manual and Circuit diagrams from a different 2004 repair.
  • Less than ten dollars at Radio Shack for fuses and fuse panel. Already had wires, etc.
  • Some solder. Already owned de-soldering tools, etc.
  • Visited both local authorized Toshiba factory service repair facilities. One said repair would have to include replacing Q751 + Q752 STK392-110 Convergence Amps with ST392-180, and realigning set for a total of $500+ and it would be more if they had to order a power board. NO THANK YOU! Other shop said $65 for site visit and $30 to make an estimate that could be applied to repair.
Jan 04, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H81
These ICs are the Japan types and available from partstore.com under part number C5AA00000108 for $29.08 + shipping apeice. These are original replacements for the panasonic parts. Good Luck Ps please do not forget to rate this
Oct 14, 2006 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
