Question about Belkin (F5D7011) 802.11g/b Wireless Adapter
I have an 802.11g belkin card and it will not pick up a signal even if I am sitting right next to a router when I click on the program it tells me that I have encountered an error the green light on the card blinks but will not pick up on the signal. how can I fix this?
  • Jeffrey Groves
    Jeffrey Groves Dec 30, 2010
    Please provide the entire model number of the network adapter card and the version of your operating system that you are using.
  • 59 Answers
Check the drivers?
check to see if your "wireless zero config" is started? Goto Start/Run type in box "services.msc" scroll down to the bottom to where it says "Wireless Zero Configuration" make sure its Started, if not double click on it and click "start". Close when done.....
check for new wireless connections.
-mk3ride
Posted on Dec 30, 2010
I am having problems connecting to the internet on my desktop but fine on wireless laptop. Dell says I should check the router. Could the router be the problem and how do I determine that?
Well there are 2 other options to consider. The router is functioning somewhat at least, since the wireless laptop can pick up the signal. So ...
#1. Check the ethernet cable... kinks overtime can damage the wires within, try a new ethernet cable.
#2 In Device Manager are there any "!" or "?" or "X" near the Network Adapters?
(right click my computer, go to properties, Hardware, click Device Manager)
If so there may be a problem with the network interface card/ports. Could be hardware or driver related.
Feb 08, 2010 | Belkin (F5D7230-4) Router (587009)
Vista wireless connection to belkin-n
It sounds like your linksys is your main connection so therefor it will not always let belkin connect because your pc has registerd your linksys to be your connection.
Sep 20, 2009 | Belkin (F5D5231-4) Router
Trendnet router on 2nd floor gives poor signal on first floor.
The Trendnet router did not get very many if any good reviews. I would say any router is better than what you have. Belkin is ok but on the low end of OK.
Spend some time on CNet, PCMagazine, Anandtech, Tom's Hardware and look at some of the reviews they have done.
Good luck
Apr 09, 2009 | Belkin Computers & Internet
Cant get router to pick up with PS3
Hi
Try to reset the router to factory defaults by holding down the reset button for 30 seconds. report back with results.
Dec 28, 2008 | Belkin Computers & Internet
How close do I have to be to the router for the wireless signal to be picked up? The Led light flashes but we cannot pick up the signal/.
usually those have a 25 to 40 meter range....if there is nothing in the way of the signal..i use 20 meters as a rule of thumb..
Oct 15, 2008 | Belkin Computers & Internet
Cant get wirless lap top pick up router
I know it sounds stupid but a lot of people just forget to turn on the wireless switch.
You may want to check first if the router is being picked up by other computers just to eliminate the possibility of a busted router. If no other computers can pick up your Router's signal then it's the router that you need to replace. If other computers can pick up your router's signal, then it's the computer's wireless card that's busted.
Sep 19, 2008 | Belkin Computers & Internet
Program for belkin router
you don't require the disk...
co0nnect your belkin router with ethernet cable into the comp...
open internet explorer type an address as 192.168.2.1 it will take you to router config page..it will ask for a password leave it blank
click submit
click the Wizard link on the top menu bar.
For a UK ADSL connection, you will need to select PPPoA (Routing mode, for multiple PCs) even if you are only going to connect a single computer, then click the next button.
The next step is to enter your username and password that your service provider has provided you with. To try and ensure the password is entered correctly it must be entered twice. The VPI/VCI values of 0/38 are the correct ones for a BT Wholesale ADSL line. If you are using another telephone provider check the settings required. Click next again to continue to the next phase in the wizard.
This screen tells you what your Internet IP address is (the WAN IP), and you will note that the menu bar at the top of the page now shows the Internet Status as connected. For the review, there is really one bit of configuration left to do. During the course of reviewing hardware we tend to swap kit in and out several times, we generally prefer to run the routers on the same IP address (192.168.0.1). This is easily accomplished by clicking the LAN Settings link on the left hand menu of the Belkins web setup and altering the routers IP address.
The router is clever enough to alter the DHCP server IP ranges to match the new LAN IP address of the router. Once the changes were applied it took around a minute for the router to restart, during which time the wireless signal dropped, but once this reconnected the PC was assigned an IP address in the new range of 192.168.0.x.
Feb 16, 2008 | Belkin (F5D7000) 802.11g/b Wireless...
Wireless router belkin n1
Right click on the network icon in your task bar and click view wireless networks, then when all the networks show delete them all and close the window, next, a pop up will say found wireless connections click the icon again and look for your connection in the list and click connect and enter the pass phrase
Nov 05, 2007 | Belkin (F5D8231-4) Wireless Router...
Belkin (F5D7011) 802.11g/b Wireless Adapter Logo
64 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
