Question about Garden
Hello, Ihave a Honda HRU214 motor mower, bout 1990 vintage. I have cleaned and reassemble the carby and now it runs on max revs. What do you think the prob might be? Regars Paul
  • 927 Answers
I think you may have to connect the governor (wind driven flag connected to the carb that pulls speed down when rotation gets too high, but I don't know without seeing it.
Posted on Dec 30, 2010
2007 vulcan 1600 classic wont stay running
i rekon when ya changed the tank over it had rust in it and has contaminated yer fuel lines, pump and carby with bits o rust. So rip off the tank, lines,pump and carby and give em all a good clean, reassemble and yer all good to go.
Nov 05, 2017 | Motorcycles
Ihave a1977 400t honda that wont run on 2 cyls at idle cuts in at 2500 revs carbys sonic cleaned plenty spark help. Thanks
Check that the spark plug boots aren't wet or worn. Sometimes the spark leaks to the cylinder head.
May 19, 2017 | Honda Motorcycles
Hru19r honda mower was running fine and then just stopped and won't start. Drained fuel from carby as well,checked spark all good any ideas?
Flush gas tank, add fresh gas with Stabil. Use clean air cleaner. Remove clean/replace plug. Take bread wrapper, clean plastic off 2 inches, use to clean port from bottom of carb up thru carb after removing float and needle valve. Reassemble.
Mar 29, 2015 | Honda Garden
Pump will not unload.
Hi if it stop when the trigger is pulled the issue is with the motor.
stopping is caused by , low revs on motor or low compression or poor spark, sometimes faulty carby.
change spark plug , adjust valve ( when valve has some slight side movment it is ok if up and down , it should be tighter (valves usually under side cover near top ) increase revs a little ( make sure revs dont get rough when running high) set max revs to when the engine still runs smoothly at max.
Mar 30, 2014 | Delta Model DT2400CS Pressure Washer 5.5HP
My accelerator cable on my Victa V40 appears to be looser now so when I pull the cord off choke the revs no longer increase, how do I fix it?
hi.. the thottle cable has round end has poped out of its cam housing(gray plastic) inside the plastic carby... the only way to fix that is to remove the carby, but before you do clean your mower as you will create more issues if dirt/grass gets into the parts you will be working on...also take pictures before you start taking thing off, so you know how to reassemble it, as the carby will need to be taken apart....good luck
Jan 01, 2014 | Briggs & Stratton Garden
Victa carburetor problems
Why you have a car carburetor fitted to a mower troubles me... I think you'll find you don't gain any power increases by having such a large carbie on there, if anything you'll simply flood the engine with air or fuel and will have great difficulty maintaining a stoichiometric ratio.
The fact that the motor will only run on choke indicated that it is getting too much air without choke, and not enough fuel. This would be due to the intake size being still too large and probably a restriction in the venturi flow near the jets causing lack of suction to draw fuel from the bowl which would be due to the mower engine not creating the same vacuum as a car engine.
My honest suggestion?
Put a Victa carbie back on it, it's probably not going to work...
If you want it to run harder, adjust the throttle assembly to rev harder, or change the governor position.
Nov 18, 2013 | Garden
Ihave a 1986 honda shadow 500,starts but won't rev
make a compression test on 2 cylinders, http://www.youtube.com/watch?v=cdif7gaWDLc
May 07, 2012 | 1986 Honda VT 500 C Shadow
Murray 4.5 hp Q lawn mower runs rough and smokes.
White smoke indicates that it is burning oil. The smoke would be black if it was running rich. So probably the rings will need to be replaced eventually. These mowers are prone to problems but the carbie is least likely to be the problem. So before you adjust the carbie take the cover off the top and give it a good clean and check that all the hoses are connected and are not cracked. Then make sure the airfilter is clean, blow it out with an air compessor or better still get a new one. Then try it out agian. If this doesn't help there is two screws on the carby marked L and H. Turn these only 1/8th of a turn at a time and note or make their current position. Start with the H scew with the mower at full revs. Turn anti clockwise untill you get max revs then turn it back a bit. Running too lean will over heat the motor and damage it. Then if needed adjust the L (or Low)screw. If you get black or grey smoke when you push the throttle up from idle to full its too rich so turn clockwise. If if slows before it picks up to full revs turn anti clockwise.
Sep 06, 2009 | Garden
Garden Logo
178 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
