Question about Canon imageRUNNER 8500 Copier
Ir6000 harder toner - Canon imageRUNNER 8500 Copier
  • Canon Expert
  • 122 Answers
Check cooling fan at the bottom if it is clogged with dust, it wont allow air ventilation resulting in hardning toner.
Posted on Jan 02, 2011
I had a jam, upon clearing the jam, the printer will hang with the motor turning, and the display saing 'adding toner'. I changed the (new) toner, for a brand new one. Still message will not go away.
Leave the machine working to see the next message of Adding Toner. Usually the next message of "Adding Toner" is "Ready to Copy".
If the next message is "Add Toner", i suggest you to pull the new toner kit out and push it a little bit harder and check again.
If you power the machine off and on again, can you see what the message about toner is, Original or Unknown Toner is installed?
Sep 30, 2014 | Kyocera Office Equipment & Supplies
The problem is about error 000002 0000 for my ir6000
General condition
1) Is the developing assembly locking plate mounted correctly?
NO: Mount the plate correctly.
General condition
2) Is the shutter releasing member of the hopper mouth mounted correctly
to the developing assembly locking plate?
NO: It is likely that the inside of the hopper is clogged with toner. Remove
and then mount back the shutter releasing member to remove
the clog, or replace the hopper unit.
General condition, Developing assembly toner sensor (TS1)
3) Is the developing assembly adequately provided with toner?
YES: Check the developing assembly toner sensor.
General condition, Hopper toner sensor (TS2)
4) Is the hopper adequately provided with toner?
NO: Check the hopper toner sensor.
Hopper connector, Hopper supply motor (M10)
5) Is the connection of the hopper connector normal?
NO: Connect the connector securely.
YES: Check the hopper supply motor.
Feb 14, 2013 | Canon imageRUNNER 7200 Copier
I amusing cannon ir6000 . the error indcation is -check hopper conetivity
I take that it is saying that the toner hopper is not connected to the copier??? The connector for the hopper is covered by a small cover with one screw. With the front door open look on thebottom right of the hopper, there is a small cover > make sure the copier is "OFF" > remove the screw and you will see a white connector > make sure that the connector is installed & all the way in..... If that dose not do the trick, you may have a bigger problem....... Good Luck
Jan 26, 2011 | Canon imageRUNNER 5000 Copier
Why my ir6000 copier always hardern toner and make my cleaning screw brokem ????????????
Hi
first are all the filters clean and the fans working? If so then the drum heater is getting to hot. Unplug it see if that helps .If that works then replace the drum core heater.
Dec 30, 2010 | Canon imageRUNNER 8500 Copier
Canon ir6000 touch screen is not working
my canon IR6000 touch screen is not working
Sep 23, 2010 | Canon imageRUNNER 6000 Copier
ImageRUNNER 7200 Copier: hi I'm Akar I have a canon ir6000 copier my...
The problem is with toner section. The copier cant get toner to toner unit or the toner motor is faulty.
In one case eaven the main pcb caused the problem.
I would try to replace toner hopper assy.
call service.
May 16, 2010 | Canon imageRUNNER 7200 Copier
Error code e000020 in ir6000
E020
General condition
General condition
Oct 25, 2009 | Canon imageRUNNER 7200 Copier
Toner light on, will not printer, get a message that i need to move the green tab back and forth, printer will not print
It is out of toner. This message is the when it runs out. Almost 100% of the time it is out of toner. If it is not out the fix is harder. I suggest replace the toner.
Jul 07, 2009 | Brother HL 2140 Laser Printer
Canon imageRUNNER 8500 Copier Logo
42 people viewed this question
old marine
old marine
