Question about KitchenAid KESC308LSS Electric Kitchen Range
Were is the fuses on the stove - KitchenAid KESC308LSS Electric Kitchen Range
    President:
  • 228 Answers
Pull out the range turn off power at the breaker or unplug the range if possible. in the back there is a panel you need to remove there is a thermal/fuse. remove it and if you have a continuity tester or can borrow one. test to see if the fuse is good. if it is not replace it. once replaced you can repower it back up. good luck!
Posted on Dec 30, 2010
Hi is there avfuse box or fuses on the stove?
If its an electric stove the fuse panel should be in the upper back of the stove. Ours was in the top behind the clock. There should be a fuse for each burner and one for the oven.
Jul 19, 2015 | Ovens
Defy 731 multifunction oven stopped working
switch as probably burt out so that the connecors inside dont touch anymore, or your supply fuses for the stove have blown, check your fuse box. but at any rate if there are sparks i would replace stove or get in a qualifed person the check your stove.
Oct 22, 2014 | Ovens
Where are fuses in Kenmore stove C970
Stoves generally do not have internal fuses they rely on the house circuit breaker to protect the circuit. Some stoves have what is called a thermal fuse. These can trip when the oven or broiler has overheated. Some are located on the back panel and some are located on the top panel under the top of the stove. Since this is a smooth top model there may be one on the back panel. More than likely there is a problem with the oven control circuit possibly in the electronic control. The relays can go bad on the control and the oven will not work.
Oct 11, 2014 | Kenmore Electric Smooth Top Stove
My stove top and wall oven are connected to one
Assuming you replaced the fuse with the same size, yes, both are reasonably safe.
Oct 08, 2014 | Kitchen Ranges
How do I change a fuse in stove model 55612?
Most stoves do not have fuses in them. Your house electrical box controls the electric to the stove
Sep 29, 2014 | Kenmore Stove / Oven / Range Bake Element...
Electric stove
Check the thermal coupler a copper thermometer for your stove after checking all the fuses in stove and circuit breaker box of house to see if any have tripped. Circuit Breakers should have the switches all in a line. Any not in the lie will be tripped. Fuses in your stove are usually in the top part of the stove where the instruments are and fuses screw out and visually are easy to detect if they are blown or not. Remember all ways Unplug what you are working on to prevent shock
Jul 03, 2013 | Ovens
Replace fuse on ge glass stove top
Maybe the top you can open above switches.
Mar 17, 2013 | GE Kitchen Ranges
No power , no clock, timer, no auto lighting in oven or stove burners, no lights nothing
Some stoves have secondary fuses inside the stove. Check these fuses.
Nov 19, 2011 | Kenmore Kitchen Ranges
Our stove turned on but then turned off and now it doesnt want to start how can we fix it its electric
check your fuse/circuit breaker. Most stoves have a specific fuse or circuit breaker in the power box.
Also, might seem a bit silly, but check if you have a stove switch on the wall near the stove. If that's turned off you won't get it to work :)
May 19, 2010 | Kitchen Appliances - Others
WE have a GE Stove top Range. The burners aren't
If you have power to the stove as in the oven light works and the clock works but the burners and oven will not work you only have 120 volts coming to the stove. The stove requires 240 volts for the burners and oven to work. Check the service panel for a blown fuse. There will be 2 fuses in the fuse holder. One of them is blown. If that is not the case then one of the wires has come loose either in the service panel or in the outlet behind the stove. Use a multimeter to check the input voltage at the outlet.
Apr 25, 2010 | General Electric Stove/Oven/Range Chrome...
KitchenAid KESC308LSS Electric Kitchen Range Logo
233 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
