Question about Sport & Outdoor - Others
Need replacement wheels for the Fast Track exercise ski machine/glider There are supposed to be 8 Found only oce source, but the do not stock anymore Thanks
  • 4 more comments
  • Misty Rhodes
    Misty Rhodes Nov 19, 2013
    HERE IS HOW TO REPLACE BROKEN WHEELS ON THE FAST TRACK GLIDER TREADMILL
  • Misty Rhodes
    BUY 6200-2RS 10x30x9 Sealed 10mm/30mm/9mm 6200RS Deep Groove Radial Ball Bearings
  • Misty Rhodes
    AND ADD A NUT AS A SPACER. YOU CAN BUY THE BALL BEARING WHEELS ON EBAY; 10 FOR JUST UNDER 18 DOLLARS.
  • Misty Rhodes
    How to fix Fast Track treadmill glider exercise machine. But 10mmX30mmX9mm ball bearings and add a nut as spacer using the screw from old wheels. Works great. Can find ball bearings on ebay. Got mine for under $18.
  • Bill Williams
    Bill Williams Mar 27, 2014
    www.kamway.com
  • Bill Williams
    That company sells the replacement wheels for the Fast Track
2 Suggested Answers
SOURCE: also looking for fast track
I have the same issue, need replacement wheels for Fitness master FM340, it is the same wheels as for Fast Trak 1 & 2.
Posted on Jan 22, 2011
RESISTANCE PROBLEM WITH FREEMOTION 350R
9 out of 10 times the issue is a worn out clutch bearing or "one way needle bearing". Freemotion and Nordic Track are both owned by ICON Fitness. This technology for fitness equipment comes from the original Nordic Track skier. In the skier, there is a flywheel with an axle through it in the middle with skis left and right. Under each ski just about center of the length is a rubber roller that fits over the flywheel axle. Inside this roller is a "one way needle bearing". That is, when you push to the rear with the ski, the bearings rollers will shift and lock against the axle and engage the flywheel. When you pull the ski back forward the rollers inside the bearing release the axle and allow free movent forward untill you again push to the rear. Many poor souls were sold new skis and tension straps in most cases to no avail. What needed to be replaced or rebuilt were the rubber rollers under the center of each ski with the "one way needle bearing clutch" inside. The same technology is used inside this exercise bike except that the "one way needle bearing" is pressed directly into the flywheel itself. So rather that replacing or rebuilding the "roller clutches", you need to replace or rebuild the "flywheel". The price for the flywheel from ICON is $600 plus. Thats right $100 more than you probably paid for the bike. There used to be businesses that rebuilt the roller clutches for the skiers. There is no rebuild service available for the flywheel on this bike. So if you don't buy the maintenance contract witch will cost you as much as the bike for 4 or 5 years you have a very heavy piece of junk to dispose of. This is planned obsolescence at it's best. If you are very handy. You can disassemble the bike and find a commercial machine shop that can replace the bearing for you. It is sandwiched between roller bearings on each end. You will need a press designed to remove and replace bearings for commercial machinery like conveyor belts and assembly line equipment and someone to order and replace the same or an equivalent bearing. This actually should be a relatively affordable service. At least in comparison the only other option.
Oct 30, 2013 | FreeMotion 350R Recumbent Bike
What different types of cross-country skis are there?
there are two types
1. general touring skis -these are for track skiing. They are long, narrow, and light compared to metal-edge skis, making them more efficient and very fast. This makes them better to use for the groomed trails.
2. metal-edge skis -for skiing out-of-track or on steeper terrain. They are heavier than touring skis and have metal edges to grip the snow and ice. The edges also help with turning on steep slopes. They are meant for deep snow and icy terrain. They are wider in order to be more stable.
Feb 27, 2013 | Winter Sports
Nordic track commercial 1300 manual
It sounds like reed switch inside the side panel located on the frame by the large pulley either needs to be adjusted or replaced. Try adjusting the switch first the clearance between the switch and large pulley magnet will be 1/8" if you have the same result then replace the switch.
Jun 12, 2010 | Nordic Track Exercise & Fitness
1990 Passenger window keeps falling off tracks. Had new window replaced because it shattered, but still doesnt roll down right. What is wrong?
Your window has a lower glider that floats on a track, and sometimes when people replace the glass they fail to replace the stopper on the end, which acts as a brake. If you can see the track with the panel off, watch as you roll up the window and see if the rollers stay in the track. Also remember that the glass has a glider glued to its back side to keep the window level as you roll. The most common problem here is the glass slipping off track, and a new track inserted into your window frame will fix that (Dealer Item)
Mar 10, 2010 | Buick Regal Cars & Trucks
Sport & Outdoor - Others Logo
1,111 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
