Question about Olympus Office Equipment & Supplies
Hi, I'm a Biomed tech that the nurses dumped a problem onto! Here is what they say about this Olympus OEP 1 printer: "It only printed the last three of nine pictuers and was supposed to print automatically after every fourth capture" (We do four pics per page) I haven't worked with these printers and was not aware that they could be set to automatically start printing after the four captures. Is this possible? If so, how do I get to that menu to adjust it back to auto print? Thanks for any help! Thanks, Tom
    Genius:
  • 1,739 Answers
I don't think you will find this information widely available. Suggest you try signing up for OlympusConnect.com web portal, you will then be able to access product manuals and access technical assistance:
https://www.olympusconnect.com/es_UserRegistration.asp?intCmp=msg_supportnav_olympusconnect
Trust this is helpul.
Posted on Dec 30, 2010
How do I align my Citizen CLP 7202e Lable printer print head to align with the lables? Currently it starts printing low on the lable and thus the last 1-2 lines print over onto the next lable
Adjust vertical offset in printer properties. If that doesn't fix it, adjust it under "advanced". Or... you can set the offset in the printer itself. Hold down the left two buttons at the same time. Cycle through the settings until you get to vertical offset.
Apr 19, 2015 | Citizen CLP-7202e Thermal Printer
Does my unit require recalibration I keep getting readings under 100 over under 70? 97/69
Sounds like placement or noise artifact to me. See if hospital Biomed staff can check it for you. I think it is more than likely how you are operating it though.
Sep 05, 2014 | Homedics BPA-260-CBL Automatic Blood...
Hi Everybody, My 6322DN says "printing...", you
First ckeck the line of the telephone,put another printer and see if you recive the fax on other printer.If you not recive fax possible fax board may be faulty.
Mar 16, 2011 | Samsung SCX-6322DN All-In-One Laser...
I am sending raw data to the printer. Where to find ESC codes for different control ops
This feature allows experienced users to see exactly what data is
coming to the printer. This can be useful in finding software
problems. When you turn on the hex dump function, the printer
prints all commands and other data in hexadecimal format, along
with a guide section to help you find specific commands.
To use the hex dump feature, follow these steps:
1. After you make sure the printer is off, open the cover.
2. Hold down the FEED button while you turn on the printer.
3. Close the cover.
4. Run any software program that sends data to the printer. The
printer prints “Hexadecimal Dump” and then all the codes it
receives in a two-column format. The first column contains the
hexadecimal codes and the second column gives the ASCII
characters that correspond to the codes.
Hexadecimal Dump
1B 21 00 1B 26 02 40 40 . ! . . & . @ @
1B 25 01 1B 63 34 00 1B . % . . c4 . .
41 42 43 44 45 46 47 48 ABCDEFGH
❏ A period (.) is printed for each code that has no ASCII
equivalent.
❏ During the hex dump all commands except DLE EOT and
DLE ENQ are disabled.
5. Open the cover to set the printer off line, so that it will print the
last line.
6. Close the cover and turn off the printer or reset it to turn off the
hex dump mode.
PLEASE CHECK THE LINK TO GET THE ESC CODES:
http://www.mit.edu/~vona/MSim/vona/terminal/VT100_Escape_Codes.html
Hope this helps u ..............
Feb 21, 2010 | Epson TM-T88III Thermal Printer
Hi can you help ? My zebra TLP 2824 printer keeps printing out of alignment. I reset the printer by holding the feed button while powering on but instead of printing dump info the label moves for a while...
If you are using a ribbon remove it and perform a calibration, hold down feed key for 2 seconds as you power on, release key and wait for it to complete its calibration, when it has stopped shifting labels (wait for 10 secs to be sure) HIT THE FEED KEY to exit dump mode. If it has successfully calibrated it will feed a label each time you hit feed key. Re-install ribbon, make sure ribbon is pushed formly onto drive sprockets and then re-run the calibration..
If this does not fix problem. download firmware to latest version. This will automatically reset printer to factory default condition.
Nov 12, 2009 | Zebra TLP 2824 Printer
Hi, my name is Fernson I have a Lexmark t630 anytime i try to print something it says "load mp feeder letter "
Load "MP" means to load media into the Multi Purpose feeder , which is in the front of the printer.
This can be caused by several things, all of which are easy to fix.
First, open the printer driver and verify the correct selection of media draw.
Next, ujse the printer's paper menu to set the proper tray.
Lastly, make sure that the print file going to the printer is not asking for the MP Feeder.
May 07, 2009 | Lexmark T630 Laser Printer
Hi have a lexmark x2530. printer does not print word doc pages. will only print alignment page.
Please follow the steps given below:
1. Please Load a plain paper.
2. Press and hold the "Scan" button for three seconds.
3. An alignment page prints.
4. Place the alignment page onto the scanner glass.
5. Press the "Scan" button.
6. Once scanning is complete, the cartridge has been aligned for optimal print quality. Alignment must be complete before continuing with any print jobs.
May 06, 2009 | Office Equipment & Supplies
Stupid easyshare kodak 5300
Sorry to hear about your problems with your printer. I have seen numerous issue s regarding this printer. Have you spoke with their tech support ?
Copiers
- Duplicators
- Copier Printers Office Imaging Customer Information Center
8 am - 8 pm
Mon-Fri 1-800-255-3434 585-784-0982
Jan 05, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Schiller AT-2 EKG
Hello Genesis3kr, You changed the mode by selecting automatic for the 12 lead function rather that the manual. I suggest an operational inservice from your local Biomed Technican or education dept. If nether is available than contact 'http://www.schilleramerica.com' select 'Contact" and request a local company rep for one and bill your education or Biomed dept. (been there do that). Good luck. Please inform me of the out come.
Oct 23, 2008 | Schiller Welch Allyn Cardiovit At 2...
How make "Print From Last
hi dear
just choose a back order fom printer properties,
Mar 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
154 people viewed this question
Top Olympus Office Equipment & Supplies Experts
James Cagle
James Cagle
John Tripp
John Tripp
Are you an Olympus Office Equipment and Supply Expert? Answer questions, earn points and help others
