Question about Toshiba 62HM95 62" DLP HDTV
I have replaced the lamp and im still not getting any picture so whats the problem?
I have a 65 inch mitsu DLP, replaced the bulb 6 months ago.. Worked fine until this week.. Now the TV will power up, turn on, then show a picture for a second then go black.. It repeats this nonstop.. ...
Sounds like the Lamp is over temperature. Either the fan went out or the filter is clogged! You might check the filter first. I hope this will help you...
Jan 07, 2011 | Mitsubishi Televison & Video
Ive just bought a new bulb for my projector (Optoma HD700X DLP Projector), taken the old one out and screwed this one in, but im still getting a read light when i turn it on, it sounds like it is...
Hello
if replacement lamp has done, was the lamp timer reset after replacement? and if the lamp is original, there is either a bad lamp or a cooling problem.
Good luck
Dec 14, 2010 | Optoma HD700X DLP Projector
I have a 50" Sony Bravia Projection TV. In the morning when my kids turn on the TV, everything works fine. But if they turn it off and then 30 minutestry to turn it back on, the sound comes on but with...
i see a couple possibilites. im not going to rule out a bad lamp. the lamp does come on sometimes. i have seen faulty lamps display this sympton. since it gives no error codes (blinks) and then does not shutdown. i feel this is a deeper cuircit board problem that a tech might need to troubleshoot. how long has it been since lamp been replaced
Oct 13, 2010 | Sony KDF-50E3000 Television
I've replaced the bulb in my tv and the red lamp light is staying on with no picture or sound. What can i do to get my picture back?
Did you put back lamp cover after lamp replacement?
Make sure lamp cover has been fixed in its place securely after lamp replacement.
Aug 17, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Toshiba 61 rear projection, im not sure what wrong with it. One day it decided it wont transmit any pictures. The standby light is on but no picture. At first i thought i may be the remote not working, ive...
When was this tv has it projection lamp last replaced?If 1 1/2 or 2 years.Tv on an used like 4 or 5 hours a day.The projection lamp life is over.Require change another projection lamp.U hear alot of clickings too?That mean the board call the Ballast board it also dead,and require changing too.This Ballast board,help to ignite the projection lamp.
Aug 14, 2010 | Toshiba 61H71 61" Rear Projection...
Picture goes dim and shuts itself off.
Im not sure what model you have. But..... you could have a weak lamp. When the set shuts off or right before, does the lamp indicator light come on? Does the temp light come on? Im also assuming this is a DLP. If it is the lamp has to be working for the picture to come up at all. Hope this is helpful.
Dec 01, 2009 | Hitachi Televison & Video
KDF-50a12U Powers off then standby light blinks 3 times
Please recheck Lamp Cover and make sure it is fixed in its space securely as 3 times red blink shows lamp cover error.
There is small safety switch in TV cabinet under lamp cover that has to be pushed by lamp cover if it is fixed in its position properly. That switch is not being pressed by lamp cover and causing this error.
Thanks.
Oct 19, 2009 | Sony BRAVIA KDL-40V3000 Television
What bulb to get for my m50wh72s
Check this website to find a replacement lamp for your TV. You will need to use the housing from the defective lamp.
Dec 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Red light came on tv , replaced lamp and still no picture
Look at it really carefully where the bulb plugs into the lame the connector is not sitting firmly on it reconnect it and make sure it's firmly connected to the plug.
Dec 10, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Toshiba 62HM95 62" DLP HDTV Logo
220 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
