Question about Garden
Oil keeps leaking down the chisel, is there a way to stop this? The model is a ROK 1700w Demolition Hammer
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,949 Answers
There must be a seal leaking that needs replaced
Posted on Dec 30, 2010
How do I break up old bath room tiles
The common method is to use a small electric demolition hammer, like this
http://toolguyd.com/blog/wp-content/uploads/2013/05/Bosch-DH507-Demolition-Hammer-Tile-Removal.jpg
They can be easily hired if you are in a city. You can get various points for it, from spear to wide chisel.
http://images.makita.co.nz/_productshots/accessory/B/bits-chisel-M.jpg
If laying more tiles after, keep the undersurface as level as you can. Wear ear and eye protection. If your hands start to tingle while using the hammer, take a break.
There is a machine the pros use too, a power scraper
http://img.diynetwork.com/DIY/2003/09/18/adi609_3fe_lead.jpg
Jun 24, 2016 | Saws
The bit doesn't want to release from my dewalt hex demolition hammer
The first ring is pos 88 remove but wait ,! first solvent clean the whole head and the fitting part of the chisel try first before take any operation on the chisel to shift the rubber gasket on the bit with a little screwdriver if its cleanwet before all and then remove pos 88 a locking ring then look good on the parts order of your right powertool diagram setting of your hammer.
If its cleaned and the parts are removed from the
25992752-43ehxo1h3ibdcleqehq3fi4z-2-0.jpglocking sleeve wher the chisel is in place the chisel with whole hammer in a vise and only then if the 2 locking devices out the locking sleeve are removed take a
bench hammer with the point on the front part pos 94 between chisel and hammer sleeve and with a heavy mallet on the bench Hammer the machine from the chisel.
Dec 04, 2015 | Dewalt Hammering
What type of oil
http://www.homedepot.com/p/Makita-Hammer-Bit-Grease-194683-7/205182387
For outside chisels
Inside its depend on the model but most time its a Makita 181490-7 or for the older types Hammer grease Makita P-08361
Feb 19, 2014 | Makita Hammering
Hilti te 56 combi hammer not working
The gears inside that engage the chisel points to move back and forth are either not alligned properly or are stripped. You'll have to open up the hammer to see what, exactly, is the problem.
Sep 20, 2012 | Dewalt D25330K 2KG Sds Plus Demolition...
Makita sds max avt --when it is on the chisel only mode it still revolves like in drill mode . What has caused this ?
If the bit turns freely it's possible you have the change ring in the forward position. The HM0860C is a demolition hammer, not a rotary hammer so the bit should not be rotating under power for any reason. On the HM0860C the changing ring on the nose does slide forward to let you choose and lock the chisel bits in 12 different angles. Check to make sure the change ring is in the locked position.
Jun 30, 2012 | Makita HM0860C 11lb Demolition Hammer SDS...
Chisel not striking on makita demolition hammer
The o-rings are probably worn out. Take it to a service center and have them diagnose it. It most likely will need a service kit installed.
Feb 28, 2012 | Hammering
How to chisel
The Bosch 1199VSR Hammer Drill is capable of drilling or hammer drilling at two different speeds but can not hammer or chisel only. To do that you need a demolition hammer or roto/demo hammer tool.
Jan 28, 2012 | Bosch 1199vsr 1/2'' Dual Torque Hammer...
Do all sds drills have chisel function?
The SDS designation relates more to the type of chuck on the tool for the bits than to the tool/drill itself. There are both chisels and drill bits with SDS-Plus and SDS-Max shanks, SDS-Max being the the larger of the two. As far as the tools go: Demolition hammers will only hammer and can only use pointed chisels, scaling chisels, scrapers, etc, not anything like a drill bit that requires spinning to work. Rotary hammers can hammer and rotate the bits. Rotary hammers have a selector switch with two or three positions; one for hammer only for the above demolition bits, one for rotary hammer for use with carbite tipped drill bits, and some have a position for rotation only. The rotary hammer is a more versitile tool but more expensive because of extra workings inside.
Feb 17, 2011 | Garden
It won't rotate. It only hammers.
The 11316 Demolition Hammer is made to hammer only, it does not rotate the bit. It is for demolition with pointed bits or flat and scraping chisels. If you want to drill holes in cement you need a rotary hammer drill.
Dec 23, 2010 | Speed Bosch 11316evs Variable Sdsmax...
I need the parts for rockworth power task 1700w
Hello I need a new trigger switch for my Rockworth PowerTask
serial no uk004984 ARPD1/OOK. On the switch itself inside it has HY15C. Please put me in touch with your on parts division. Thanks.
Jun 13, 2009 | Hitachi H65XXX 1 - 1/8 " Hex Shank...
Garden Logo
59 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
