Question about Panasonic Televison & Video
TV power switch does not turn TV off but causes it to go to a washed out picture and no sound. This is a Panasonic model CT31G20 purchased in 1995.
  • GOODOLDBOB Jul 07, 2008
    The power button on the remote and on the DISH remote both produce the same result.
    I answered the first question and received an e-mail with another solution but there was no other solution from "marked"
  • 6,487 Answers
Sometimes a fuse will take care of the problem but if it blows again you will most likley have problems in the power supply
you can sub a fuse and see what happens if it blows again dont keep changing fuses though it could be anything from a bridge rectifier to a switching transistor and a cap. So you can do some checking by yourself or take it to a service center near you.
Hope that helps...
Posted on Jul 07, 2008
  • Mark Gil
    Mark Gil Jul 07, 2008
    Because you need to check which one solve your concern...
    Master:
  • 555 Answers
Does the power button on your remote do the same thing?
Panasonic CT-36HX42F I turn it on and then, turns off
It seems that the electrical relay's, it getting completed is not able to create the high voltage required for proper display. Hence on switching it on, the power LED will immediately light up but since the circuit is not completed it switches to standby and then off. Get the relays replaced and make sure you connect the main power chord to a 15 Ampere rating wiring usually the line meant for A/c and hot water Geyser(called as high power line)..........sodeep
Sep 19, 2009 | Panasonic CT-32HX42 32" TV
Model TC-32LX700 Power indicator light on from is
Problem is caused by voltage irregularity. Pulled plug for an hour and then plugged it back in. TV reset and it works fine. If this does not work it needs a TV technician.
Sep 14, 2009 | Panasonic TC-32LX700 Television
Panasonic T.V. model number PT-47WX42F no picture or sound
R800 open on power board next to the relay.the resistor value is1.5 ohms 10 watt resistor.
Jul 15, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic Viera 46" plasma~no sound, no picture
I would use the warranty at Bestbuy at that point. Opening up the TV would most likely void the warranty.
Jun 28, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
No power to TV. No sound, no picture.
frist you need to check the fuse it is inside of tv by the power cord looks like this maybe a Panasonic tv did notsee any model number so i will gess as to what is wrong check fuse if blown need to replace with a white glass looking fuse of same value like i said dont know what model number this set is but the thermister could be at falt for the fuse to blow.
Mar 14, 2009 | Panasonic Televison & Video
No picture or sound
Make sure that there is actualy power going to the AC power source where the TV is plugged in. You can re-set the TV by disconnecting the power for about 10 seconds and then connecting it back again. If the set still does not start it will require service.
If the set is dead it is most likely the main power supply board that failed. The service tech would replace the power supply and also investigate to find the cause of the failure. Sometimes another board could have a failure and cause the power supply to be damaged.
If the set will not start up, it will require shop service. You can call Panasonic tech support to find out the authorised service rep for your area. Check to see if the set is still under warranty. If not, it will be expensive to service.
Jerry G.
Dec 01, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
DVB PROBLEM WITH Panasonic- TH50PX600A
theres this panasonic tv that when i turn on it shows no picture and sound and makes a noise how can i solve that problem?
May 11, 2008 | Panasonic TH-42PX60U Television
No picture but sound on panasonic plasma
Unplug the TV and disconnect any HDMI cables to the set. If the issue goes away there is a possibility that your HDMI source is causing the problem. Anything on the HDMI can cause odd problems with the TV since the serial data and serail clock lines are routed on HDMI. Those are the 2 commmunication lines used throught the TV for operation so anything HDMI that might load down one of those can cause issues.
Mar 07, 2008 | Televison & Video
Buzzing sound, no picture on my Panasonic TV
You might have a short causing the set not to start. Probably in the horizontal/high voltage circuit. The buzzing sound that you're hearing is the power supply overloaded. Stargazer
Apr 22, 2007 | Panasonic CT-27G23 27" TV
Televison & Video Logo
35 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
