Question about Orion Computers & Internet
Orion model 15dcl push power button monitor blinks on then goes black you can see image on screen but backlight is out
  • 11,361 Answers
Well, most common failure in the LCD monitor is due to bad caps, worst case will be the lamp assemblies.
So look for bad caps first.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Dec 30, 2010
Samsung LCD S27B350H blinks during 45 minutes after power on
The backlight is failing, or you have some other power supply problem
Sep 21, 2012 | Samsung S27B350H - SyncMaster S27B350H -...
Picture goes black at random intervals
There are 4 c5707/5706 in the inverter transformer driving circuits, the cause of the problem was due to poor solder connection in the bias circuits of the transistors. Make sure to check that after you install the new transistors otherwise you will blowthem up. Common problem with this model. When the circuit drwas too much power from the power supply, it will shut itself off to ptotect itself.
Dec 16, 2009 | Dell E173FP 17" LCD Monitor
Power light blinks but the screen is black and won't come on.
is it an LCD monitor?
if so then it's more than likely the backlight tubes or the backlight tubes inverter supply has died is it fixable but i am not sure how much it will cost you at your local repairer and monitors are so cheap these days its probably not worth it!
hope this helps,ben
Aug 13, 2009 | Computers & Internet
Toshiba satellite a135 monitor goes black
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Toshiba Satellite A135-S2386 Notebook
I have a shap lcd computer monitor and when i plug it into my computer and turn the power on, the little green power light comes on, screens back. and after 5-10 seconds the light turns orange and blinks...
It could be your monitor is fine. It simply goes to a cycle when its turned on and does not detect any signal coming from your CPU, it simply goes on standby mode (hence the darker image and orange/blinking light.) have you checked the computer (CPU) part?
Dec 04, 2008 | Computers & Internet
Syncmaster 910t blinks image perfectly once and goes back to black
I found a site that sells your (our) part: samsungparts.co. Look up that model number for the power supply under "Part #" and it seems to run about $60-70. I'm probably going to order one and give it a shot as a drop in replacement.
Oct 18, 2008 | Samsung SyncMaster 910T 19" LCD Monitor
Syncmaster 226bw goes black
If you can still faintly see data on your screen, it will be a faulty backlight in the panel most likely.
LCD panels have fluorescent tubes in them that provide the light needed to see the data. If one of these goes faulty, the circuit that drives it will turn off ALL the backlights, giving you a black screen.
Note: a faulty circuit that drives the backlights will often give the same apparent fault.
You will need to take the monitor in for repair.
Jun 23, 2008 | Samsung SyncMaster 214T 21.3" LCD Monitor
Screen going black, green LED staying on
Check to see if the image is Dimmed. Chances are the power supply on the FPD is either dead or not supplying power to the back lights.
Your problem is the power supply or the inverter on your board, you can replace it and it will be fixed.
Easy Fix REALLY EASY FIX
(inverter is what supplies power to your backlights. A lot of the times the reason a monitor goes black and the green power button is on, is because the backlights shut off. in most designs of the 1730 the inverter is embedded on the power supply. That is most often the case on this problem. Power supply/Inverter=Replace it and you will have a spanking new looking nice monitor working again. :)
Jun 19, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Monitor suddenly goes black
Is this monitor and LCD flat Panel? If so this is due to a bad power supply, an inverter board going bad or LCD backlight bulb blown. When the backlight goes bad it gets just enough power to start up, but when it is on for a long period of time it goes black because the bulb is not stable enough to hold the charge because it is going bad. These bulbs can be changed, but they also can be costly!
Nov 17, 2007 | LG L1930B 19" LCD Monitor
Monitor blinks on then turns off after computer boots up
It could be your LCD backlight giving you problems. When the image "goes off" shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. Depending on the monitor this is usually and economically repairable problem. Let us know if you have any other questions and please don?t forget to rate this posting.
Jul 20, 2007 | Hyundai L72S-8 17" LCD Monitor
Computers & Internet Logo
185 people viewed this question
Top Orion Computers & Internet Experts
David Payne
David Payne
Are you an Orion Computer and Internet Expert? Answer questions, earn points and help others
