Question about Maytag Washing Machines
What does f21 mean - Maytag Washing Machines
    President:
  • 228 Answers
An error code f21 means your machine may not be draining properly , it may have a kinked or bent hose that is keeping the water from flowing completely. check the back of the machine unkink it or replace it. good luck!
Posted on Dec 30, 2010
I have F21 on my machine, how can I fix it?
The F21 error is generally related to the drain of the washing machine (depending on the brand of your machine). Basically it means that the drain is clogged and the machine is taking too long to empty the water out.
Cleaning the drain is not for the queasy. You can find information on how to clean out the drain by visiting: http://www.kiwiservices.com/angela-says/fix-an-f21-code/
Apr 07, 2017 | Washing Machines
I want to know how can i cleare the erro f21 about siemens washing mechine.
Error f21 happens when the machine does not drain in an appropriate time. This can be caused by a blockage in the drain or a faulty pump. There is a previous post in relation to resetting this error. have siemens washing machine that says f21 what does that mean
Jan 14, 2017 | Siemens Washing Machines
Whats f21 mean?? a new belt??
Hello, Welcome to FixYa.
Based on your post I understand you have a F21 problem with a Whirlpool Duet washer, that indicates the F21 error means an excessive drain time, the belt is a non-factor.
If you follow the link to my solution to this error you should be fixed up in no time.
http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds
Thank you for visiting fixya for your washer inquiry.
Regards,
Macmarkus :)
May 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer wfw8300sw02 code F21 what does that mean
the F21 code is a ' drain issue ' --- if you remove the bottom panel from the machine you will see the water pump right there,, just in front of the pump you will see a clean out area,, unscrew counter clockwise and remove the catch screen,,, it most likely has a few things in it ,, clean out - re-install and start the cycle. and the F21 code should be gone AND washer is back up and running.
c...
Feb 03, 2011 | Whirlpool Washing Machines
What does F21 mean on the digital screen?
Hi
Error F21 means F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Error code SD means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump.
Hope this helps... Please post back if you need more information.
Daniel
Jan 01, 2011 | Kenmore Elite 45986 Front Load Washer
Keeps on coding F21 - we have adjusted the hose several times but still seems to be giving us problems
Hi
Daniel
Jan 01, 2011 | Kenmore HE2 Plus Front Load Washer
I am getting error code F21
hi there,
the F21 error means the communication between the touchpad and the control board behind it.
here is what you do:
unplug the washer
check the wiring harness betweeen the control board and the touchpad
make sure there is no corrosion on any connectors on the control board
check for any obvious burns or kinks on the control board & harness
if all of the above checks out okay, i would start by replacing the keypad first
let me know how it turns out.
Sep 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite front load washer
I HAVE A KENMORE ELITE WASHER AND IT STOPS IN THEN MIDDLE OF THE CYCLE AND DOESN'T RISNSE. THE DISPLAYS SHOWS F21. CAN YOU LET ME KNOW WHAT THIS MEANS?
Sep 22, 2008 | Kenmore Elite 45986 Front Load Washer
F21
f21 means long drain time, the pump has a clean out plug that you can remove and look for inpeller problems, and gunk coins ear rings ect.
lean the machine back aginst the wall remove the bottom panel to get access to the pump
I would start here first
Apr 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
413 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
