Question about Amana DLE330RAW Electric Dryer
Sounds like the tumbler is goinfg out , very loud
  • Amana Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Dec 31, 2010
Dryer making loud vibrating noise
In all likelihood, the belt that runs the tumbler is loose, causing the tumbler to rotate off center. While it takes a few minutes, the front of the dryer should be removable and you can take the tumbler out and replace the belt.
Oct 11, 2014 | Amana Dryers
Ive changed the belt on my white knight tumble dryer CL 372 once put back together the drum won't turn and makes a loud noise
There are two do-nut shaped rollers that the tumbler rests on located behind the tumbler. One or both could be bad. Some models have a single "axle" in the center of the tumbler that may be causing the problem.
Oct 10, 2014 | Dryers
Maytag gas dryer makes loud rattling noise. Not a squeaking noise, but something between a rattle and a fast, rhythmic knocking. Tumbler works, heat works, but insane noise.
sounds like the drum isnt balanced. either make sure appliance is properly balanced on the floor or make sure you are not overfilling the tub.
May 24, 2011 | Maytag MDE8000 Dryer
Loud noise as the tumbler is drying
Front or rear? Rear is probably center bearing. Fornt is front tub wheel or glide worn out. If noise is in front remove front and inspect.
Jul 19, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
I have a Maytag Neptune washer FAV6800AWW that I had the clutch replaced not long ago. Now it has a grinding sound, like a bad bearing or something when in the wash cycle. It seems ok when it spins out and...
Thank you for posying your model number.
I believe you may have debris under the tumblers maybe pocket change. Removing tumblers is a fairly easy job. I would start there and see what you find. A number of forum members have had this issue.
The Service manual has the procedure for tumbler removal starting on page 3. It’s not difficult to remove them the manual doesn’t call out the Torx driver size required for tumbler removal. You will need a number 20 Torx driver to remove the screw for tumbler removal.
The Service Manual for reference. Sears Parts Direct for reference
I have a procedure for clutch maintenance/repair for the FAV6800A/FAV9800A. I have helped a number of owners with the process. The other high failure item is the Left Hand Lid Lock causing OP,OD,FL errors. I or someone on the forum will help with other issues.
Post back if you have questions….Rich
Dec 25, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Tumbler makes loud sound rattle sounds like something loose
We called an appliance repairman who replaced the worn out rollers. Expensive but quiet!
Jan 06, 2009 | Dryers
Something stuck in drum, spinning cycle loud hammering/clacking sound
hi there,
sounds like you may have something caught between the tumbler and the cabinet. since the drum has holes in it, can you have a look if you can see anything that's come of clothing, like a bra wire. it's usually something bigger.
Sep 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Loud Noise when drying....
hi thanks for the question tome iot sounds like the blower a rumbling noise and the dryer takes too long to dry so i would check that thanks the appliance doc
Sep 14, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer Noise & Black Marks On Clothes
Most likely the front drum bearing part number 5303937139 needs to be replaced. Instructions come with the kit.
May 31, 2008 | Frigidaire FDE336RE Dryer
Loud dryer
sounds like somethings stuck inside the drum, between outer wall of drum and cabinet...please inspect for loose items..
May 10, 2008 | Dryers
Amana DLE330RAW Electric Dryer Logo
50 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
