Question about Speed Queen AGS28AWF Gas Dryer
I have a prob to my gas dryer,the ignitor is posiible ignite but not heat
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
Either two things, if your ingnitor is working and the gas is not coming on, you have a gas control issue.
If the igniter is not coming on you just have a ignitor issue.
THIS IS A GAS PRODUCT, INCORRECT REPAIR CAN CAUSE A EXPLOSION, AND DEATH CAN OCCUR. IF YOU DO HAVE THE PROPER TOOLS SUCH AS MANOMETER AND LEAK DETECTORS, I SUGGEST YOU CONTACT A SERVICE COMPANY
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Dec 30, 2010
My dryer is not heating up. The ignitor glows but the gas does not ignite. I took of the front lower panel and watched it. It doesn't ignite. The gas line is fine. What can it be?
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 21, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
Whirlpool dryer(LGQ9557HQ0), ignitor ignites but flame does not light
mounted on top of the gas vavlve is black electrical coils when energized it opens the gas valve,if one of the coils are defective it wont open and let the gas thru,its hard to test the coils so most repairmen just replace them all
Jul 07, 2008 | Whirlpool Dryers
You have answered this question before but does the ignitor stay on during the drying cycle? Kenmore series 80, model 110 72822101 gas, It starts correctly, ignitor glows, gas ignites,run for 5 to 6 min....
yes..
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 07, 2011 | Kenmore 72802 Gas Dryer
Dryer starts hot surface ignitor comes on gas valve opens i get a flame 5 mins flame shuts off hot surface ignitor repeats and tries to ignite no flame after unit is off for 20 mins to 30 mins off unit...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 17, 2010 | Kenmore 77632 Gas Dryer
Dryer will not heat up
Unlike electric dryers gas dryers will continue to run if the thermal fuse is blown. Usually some sort of air blockage will cause the thermal fuse to blow. The control thermostat powers up the gas assembly.cd79cfa.jpg It judges the drum temp as air passes over it on its way out the exhaust. It opens(quits sending electricity to the gas assembly) at 160f for cotton and closes(starts sending power to the gas assembly) again at 105f.
When the dryer is running and the timer is set for heat, the control thermostat is energised. It powers up the flame (ignitor) sensor, the ignitor, and the solenoids. The gas does not come out with those solenoids energised because the ignitor is using most of the power to get it lit. When the ignitor is glowing wide open the heat from it causes a bi-metal in the flame/ignitor sensor to bend and open the circuit to that ignitor. That kills power only to the ignitor. The resulting power surge causes the solenoids to yank open them flood gates and raw gas comes out onto that screaming hot ignitor. KAWOOOSHHHH Houston we has ignition. At this point the ignitor becomes a safety device. As long as the flame is washing through that ignitor the current keeps flowing to them solenoids and the gas keeps a coming. If for some reason their was no ignition the ignitor would cool down and shut off the solenoids. More here
Jul 25, 2010 | Whirlpool WED5520SQ Gas Dryer
Dryer runs fine but heating unit will not ignite
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Jul 11, 2010 | Kenmore 77632 Gas Dryer
Gas dryer on first cycle heats ok then igniter
Believe it or not your ignitor is probably the problem....
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Apr 20, 2010 | Dryers
KELVINATOR GAS DRYER. IGNITORLIGHTS UP THEN TURNS OFF. NO HEAT.
the ignitor needs to be glowing white hot not orange. it is not hot enough to ignite so you need to replace it.
Oct 04, 2009 | Frigidaire FGQ1442ES Gas Dryer
Maytag gas dryer runs but does not heat
If yo smelled gas then the ignitor may not be working.
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it)  It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off.  If the ignitor does not glow then the thermostat is bad.  If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced.   If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
May 30, 2009 | Maytag MDG2600BWW Gas Dryer
Our Maytag gas dryer will not heat up.
check if there is voltage across the igniter. if there's no voltage, trace the diagram and you might stumble on a thermal fuse that is busted.also, check the gas solenoid. the ignitor could be heating up but if you dont have gas then there will be no ignition...
Feb 12, 2008 | Dryers
Speed Queen AGS28AWF Gas Dryer Logo
82 people viewed this question
Top Speed Queen Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Kristy Heard Duke
Kristy Heard Duke
Level 1 Expert
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
