Question about Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE6200AYW dryer runs, no heat. I pulled out the timer motor and noticed the orange wire leading from the timer motor to the temperature switch had burned through. Also, the post on the timer motor where the orange wire connects was very loose and melted at it's base. My thought is to replace the timer motor and fix the orange wire so it can be remounted to the new timer motor but that's an approximately $90.00 part. That would tap me out and I'm unsure if the thermal fuse or the heater element is fried... question 1) is the cause of the lack of heat most likely attributable to the burned wire and melted post at the timer motor? 2) what would cause the wire to do that? 3) How would I safely test the thermal fuse and the heating element? Thanks, Dennis
danromarris
  • 101 Answers
SOURCE: Maytag Atlantis MDE6200AYW will run, but no heat
Check to make sure that you have the proper voltage running to the dryer first. Next you may have a problem with your heating element or with your thermal fuse. Get your dryer opened up so you can see your heating element. Run the dryer and if you see the heating element come on and then turn right back off again then you have a bad thermal fuse. If it doesn't come on at all though then the heating element is bad. Both parts can be picked up at your local appliance repair shop. Just make sure to unplug the dryer before replacing the part. If you have any other questions let me know and let me know if this was helpful for you. Good luck.
Posted on Jan 22, 2009
  • 686 Answers
SOURCE: disable buzzer on Maytag Atlantis MDE6200AYW
it could be done by taking the control panel off and maybe diconnecting the buzzer other than that what I have researched there is no other way sorry
Posted on Feb 18, 2009
  • 686 Answers
SOURCE: MAYTAG PYE2300AYW ELECTRIC DRYER running but no heating
you need to take it apart if you'd like call 417-926-0106 i'll walk you through it Jim
Posted on Feb 27, 2009
mark_37388
  • 100 Answers
SOURCE: Heating element is getting red hot - like a heater.
No the first thing I would check is the vent going outside may be cloged the air going across the heating element should keep it from glowing real bright
Posted on Mar 30, 2009
SOURCE: Maytag Performa PYE2200AYW Dryer Heats intermittently
i had the same problem with my dryer and i installed the wrong thermal fuse for gas dryer which calls for a pink thermal fuse in which i installed and it works fine also check the lint in the front of your dryer. also my dryer which is the same make as yours seems will run on the fluff cycle until i replaced the right thermal fuse. my dryer run exceptionally hot and eventally shut down and it only run on the fluff cycle for any length of time.
Posted on Sep 22, 2009
Why doesn't the timer count down? The dryer runs & heats but the Timer doesn't move. I replaced the Timer block but nothing changed. Is this related to a bad sensor?
go bak to 4 prong. why did u change it out? souns lik this isa 220 unit and not a 110? chk the book that came with the unit. lol.
Jul 22, 2014 | Maytag Dryers
Maytag atlantis mde6200ayw
be with you in a bit
Sep 12, 2013 | Dryers
Maytag atlantis MDE6400AY timer works but dryer doesn't come on
First thin I would try is to check your thermal fuse for continuity with a ohm meter with the wires removed from the fuse and the dryer unplugged. Its located on the tunnel that in cases the heating element.
Here is the part in case you find it bad.
Oct 31, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
I have a maytag dryer and when you start it the timer doesn't move - it will run for hours unless you stop it. now when you pull the knob to start it doesn't respond
Sounds like the problem is in your timer contacts, in which case you would have to replace your timer. A no heat scenario on auto dry could also cause a dryer to run continuously.
Hope this helps _MJ_
Jan 29, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Replaced timer module. Dryer did not run.
Check the voltage across the timer motor, make sure that you have 120 volts. If you have 120 across the timer motor, then it is bad. Also check your wiring to make sure you have wires in right place
May 01, 2009 | Maytag Atlantis MDG8400AW Gas Dryer
Maytag Atlantis MDE6200AYW loose dryer paddle
You might have to remove the back, then the top, but it looks like the paddles are either held on buy a screw from the outside of the drum or they just have clips that lock them to the drum. Once the back is removed, you should be able to see how the top is held on. I think it is screwed or has clips for the back and then you slide it forward to unlock the front tabs. You can follow this if you don;t get a reply
from someone who has worked on this model#. Hope you get it apart ok and fixed by yourself.
Mar 14, 2009 | Microsoft Windows XP Home Edition
Disable buzzer on Maytag Atlantis MDE6200AYW
Feb 18, 2009 | Maytag Atlantis MDE6400AY Electric Dryer
Maytag dryer belt replacement
maytag.gif Diagram E
Style: Flat with ribs
Installation Tips: Flat side of belt against drum
Jan 03, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Nov 22, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis doesnt run
change the copasitator this tells the machine to engage the motor
Oct 24, 2007 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
186 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
