Question about Dishwashers
I need new upper and lower racks for my Maytag jetclean EQ+ MDB7100AWW. How much and how can I get them, Need to determine if it is worth the cost, or buy new DW.
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
upper rack is #99002037 $108.40
lower rack is # 99002034 $187.36
Try getting your parts here, www.aplusapplianceparts.com and use this coupon code 1051 for a discount.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Dec 30, 2010
  • Dishwashers Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Need part no. 9741982 Upper Rack for my Kitchen Aid dishwasher. It is a discontinued item. Where can I find one?
My mom bought new racks for her dishwasher and now her dishwasher has died. I have both an upper anda lower if you are still looking for one.
Dec 10, 2010 | Maytag MDB3100 Dishwasher
Maytag Jetclean Dishwasher EQ Plus, Model MD87100AWW making grinding noises 20 minutes into wash cycle.
You have debris down in the pump area. To get to the problem you will work from inside the dish washer and start by removing the spray arm and then using torx driver you will need to remove upper components of the pump/motro assembly to get to the debris. good luck
Feb 28, 2010 | Maytag Dishwashers
My maytag mdb8600aws jet clean 2 only cleans dishes in bottom
The seals that the racks "plug" into need replaced. Ours had the same issue and replaced the seals and it works fine now.
Nov 23, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
2 upper rack rollers cracked in Maytag #MDB7600AWS - cant find simple replacement rollers for inside track - 1 1/4" - of upper rack.
JP Weld works great on repairing these junky Maytag parts. Note that they don't have a replacement for these upper wheels and a guy is selling expensive stainless steel replacements. The round connector broke off of ours that holds the wheel to the rack. My wife found a plastic button that fit within the space and we glued it with JP Weld epoxy (water and temperature resistant). 10 washes later, still working great! I expect it will "heal" any other plastic parts. NEVER will I buy a Maytag again!
Sep 11, 2009 | Maytag 24 in. MDB7600A Jetclean® II...
I have a Maytag Jetclean Dishwsher EQ Plus, Model # MDBD880AWQ. The door won't close completely and latch. The racks are not in the way
I have the same issue. I need to put full weight on door to get the dishwasher to go. The tongue (on the top of inside) is fine. The problem is in the latch. Looks like I need to take the door apart and get a new latch. I am guessing you have to remove the 8 (?) allen screws on the inside of the door and take a look. Good luck. I will tell you how I do. Post back if you have it figured out.
Sep 09, 2009 | Maytag Dishwashers
Maytag Jetclean Dishwasher EQ Plus MDB7100AWB
the door seal has gone better change the door surround seal also. check for case damage and obstructions aswell.
Mar 14, 2009 | Maytag MDB7100AWB Dishwasher
MDB7601AWS Maytag dishwasher
hi there,
go to www.whirlpooparts.ca and type in the model # under Repair Parts. it will show you the exploded view of the racks.
May 13, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Maytag jetclean eq plus dishwasher: soap problem
This could be due to 2 problems: not enough water or water is not being pumped hard enough through the system. The 'not enough water' is easy to check - open the door in the middle of a wash cycle. If you have enough water (about 1" or more) then that is probably ok. The 'not pumping hard enough' could be as simple as plugged up filters and holes in the spray arms. Remove the racks and disassemble the lower spray arm and the filter assembly all the way down past the screen. Clean the arm holes, throughly clean the screen, clean everything. Pull the top spray arm and throughly clean the spray holes there. Put it all together and run a cycle. You should see a pronounced increase in the sound of the water spraying around. This should fix your problem - it did for me.
Mar 11, 2008 | Dishwashers
Dishwashers Logo
194 people viewed this question
Top Dishwashers Experts
