IBM Selectric II
I have an IBM Selectric II but the retun key will not work. When I hit it the carriage goes to the right margin as if I hit the tab button instead of returning to the left margin.
  • monte318 Jul 08, 2008
    The carriage locks up at one and one half inches from the left margin and will not advance beyound that point. It will return to the left margin and it starts moving right as I type but stops after travelin to the right 1 and one half inches.
Can you make the type on an ibm wheelwriter condensed?
Posted on Oct 15, 2009
  • 3,594 Answers
R152
Sounds like you have a broken torquo limiter tension spring you should have it professionly serviced.
DickyO
Posted on Jul 11, 2008
  • Dick O Reilly Jul 31, 2008
    monte318;
    It sounds like the left dust cover (Black plastic under the printer) is warped, remove it and try again.
    DickyO
Carriage does not advance when pressing the space bar or pressing a key. Does advance when depressing tab.
If you press a key does it type or try to correct? The escapement mechanism that allows it to move from space to space may be sticking and causing your problem. That mechanism just may need a flushing and lubrication. You will see a shaft that runs through the carriage. Try to turn it top to rear until it stops. if you hear a click then it has been turned the right amount. If it doesn't turn, then it is as far as it goes. Try hitting the spacebar and see if the carriage moves. If it moves, hit any key and see if it moves. if it moves, hit another key. If it doesn't move then your escapement mechanism needs to either be flushed and lubed or adjusted.
Nov 20, 2015 | IBM Correcting Selectric II
IBM selectric II carriage stuck in right margin
There is a thin metal ribbon in the back that has come off the wheel. It is a devel of a thing to get back on.
Remove the cover and watch ... you will see what I am talking about.
It may have come un-attached ... equally difficult to fix without the little thingie the typewirter mechanic uses.
good luck
Oct 14, 2009 | Office Equipment & Supplies
My IBM selectric II typewriter carriage stuck in right margin
Sounds like the return lever arm is not putting enough pressure on the return clutch, or the clutch is slipping. The exp key uses the same clutch but the pressure comes from your finger. Theres no way you can fix this yourself. Get an IBM mechanic.
Oct 14, 2009 | Lexmark Wheelwriter 15 Series II...
IBM Selectric II keeps returning to right.
Check the pitch lever on the top L. of the cabinet it may be in between positions.
DickyO
Sep 08, 2009 | IBM Office Equipment & Supplies
IBM Selectric II right margin won't hold carriage
If the carrier stops but no bell the bell striker is brobably gummed up. It is located inside the case just above the tab set key, if you can get to it some WD40 should free it up.
DickyO
Jul 26, 2009 | IBM Office Equipment & Supplies
I have a IBM Correcting Selectric II and I'm having trouble clearing out the margins. Can you help?
space to the right side of the machine, hold down the tab clear key and hit return.
If the carriage stops partway back, one of the tab stops has rotated too far on the tab bar.
remove the platen and paper pan, go to the stuck stop, rotate it to the rear of the machine to line up with the other tabs
Jul 16, 2009 | Nakajima AE-710 Typewriter
IBM Selectric Typing carriage doesn't stop moving. Stuck key?
It sounds like a possible tab knockoff problem. This could be a small spring loose or broken in the escapement portion of the machine or the final knockoff in the tab unit out of alignment. You can try setting a tab before the end of the carriage by holding the carrier in place and using your other hand to press Tab Set, but the alignment may be just far enough off to keep you from actually setting the tab. One other thing that sometimes will cause the problem is the pitch setting lever is between the two pitches. Make sure your pitch setting lever is seated in its home position.
Mar 27, 2009 | IBM Office Equipment & Supplies
IBM Selectric II-return goes past the margin stop
The margin release mech. is probably gummy and allowing returns to go past the margin. If thi is a dual pitch machine see if the pitch selector lever will move easily. If not use some WD40 on the margin rack.
DickyO
Mar 11, 2009 | Lexmark Wheelwriter 15 Series II...
Carriage return problem
If it returns with the express key the latching mech. on the rt. side is probably gummy. Take off the case, get some WD40 and spray the mechinism that latches the ret on the rt. side below the platen.
DickyO
Dec 08, 2008 | Office Equipment & Supplies
IBM Selectric II
The return clutch torque limiter is off or broken. If you take the right dust cover off it is on the turning hub around the middle of the typewriter. a small spring about 1.25 inches long with a hook on the end. I have been fixing these for 35 years. good luck. Lawrence
Jun 06, 2008 | Lexmark Wheelwriter 15 Series II...
329 people viewed this question
jasbo
jasbo
