Question about Dishwashers
I have a GE Profile Dishwasher, Model# PDW7880J03SS that doesnt dry the dishes. I pulled out the dishwasher and checked the heating element for continuity with my ohm meter and got a closed circuit reading. I tested the voltage going to the heating element and got a 124V reading. However the dishes are still soaking wet after the drying cycle. What am i missing, what else could be wrong with the machine that the dishes won't dry at all?
  • 4,323 Answers
Hi
Check if the dishwasher is draining and filling properly is water temperature. Water temperature should be between 120 and 140 F. If water is not hot enough then heating element has gone bad, to check the element you'll need a multimeter. The reading of the element should be around 3300ohms(3.3k ohms), if the reading is less than this then the heating element is faulty. Use multimeter at resistance setting(RX1 or RX10) to check this. Next thing to check for is the detergent cup and spray arms. Check if the dishwasher's spray arms are working fine and all the holes of the arms are clear. Now try using a different detergent like gel or liquid based detergent to see if it helps.
Dishes are left unclean/wet when the dishwasher is not filling in properly or when the water pressure is low. Check for water pressure and water inlet valve. The water inlet valve if faulty will draw very little or no water. However, if you observe that water pressure is fine and there is no issue with the Fill valve then check whether the dishwasher is draining. If it's not draining then see if the drain hose is plugged or clogged. If drain hose is fine and the dishwasher is still not draining then there is some issue with the drain pump or drain filter. To check this you'll need to disassemble the dishwasher and trace back the drain hose to a pump, remove the drain hose from pump and clean the debris from the pump and filter. Make sure you have lots of towels as there would be a lot of water coming out from the pump. Hope this helps... Please post back if you need more information.
Daniel
Posted on Dec 30, 2010
My GE Profile Dishwasher Model pdw7880n10ss does not clean. Food sitcks to the dishes and food is at the bottom of the dishwasher when the cleaning is finished. It has not cleaned from day one. I have...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Apr 02, 2011 | GE 24 in. Profile PDW7800 Built-in...
The glassware is not being cleaned well. It is often covered in dried food particles - especially if the dishes are not totally rinsed off prior to running the dishwasher. It was much better at cleaning...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Jan 23, 2011 | GE Profile PDW8480JSS Built-in Dishwasher
I have a ge profile dishwasher that does not drain well and dosent do the best job cleaning .could it be the drain
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
Dishwasher Spray Arms not Spinning
How to Buy
heatman101
Dec 28, 2010 | GE Profile PDW8400J Built-in Dishwasher
Can't get soapy film off that is left on dishes on GE Profile, GSD4310z02aa using jet dry, liquid dishwashing soap and have cleaned dishwasher with a dishwasher cleaning product. ~Cathy
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
Oct 24, 2010 | GE Dishwashers
Our Ge profile Dishwasher is not cleaning the upper level dishes, mostly glasses and coffee cups. The insides are bumpy with dried on food. We have cleaned the bottom filter.
heatman101
Oct 24, 2010 | GE 24 in. Profile PDW7800 Built-in...
My GE Profile PDW8480J01SS doesn't dry the top rack, even though the detergent packs I use have rinse agent. help!!! there is also a white residue on the glasses when I am hand-drying them.
heatman101
Aug 23, 2010 | GE Profile PDW8400J Built-in Dishwasher
Ge nautilus leaves water on top of cups how can i fix this?
Well first of all you can check the Heating element,
your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element. Also check the drying fan, many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Please post comments if you need more help or information.............
Good Luck!!
Thanks
Jan 07, 2010 | GE Dishwashers
My GE Profile Dishwasher PDW7880 Soap dispenser does not empty
I had the same problem. After some investigation I found that the hose that brings water to the top arm was clogged. There was a piece of chipped china logged in there. I have no idea how it got there as it is at the top and facing the the back wall but once I managed to take it off it solved the problem.
Dec 21, 2008 | GE 24 in. Profile PDW7800 Built-in...
Dishwashers Logo
149 people viewed this question
Top Dishwashers Experts
