Question about Kenmore 65234 Bottom Freezer Refrigerator
My freezer is working but the fridge part isnt this has happened before a couple of times the fridge stops working but this time it's been two weeks and its not cold or working :(
  • Kenmore Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 30, 2010
  • 312 Answers
Hi, first thing is that your fridge has a problem with the defrost system. If it sometimes doesn't run at all. Then it runs and the freezer is cold and the refrigerator is warm. The most likely cause of the problem is the defrost timer. It is a clock type mechanism mounted, I believe in the fresh food compartment at the top. It is inside that panel. If you look with a good flashlight and perhaps a mirror you will find a hole that is not a screw hole but a hole that leads to the timer knob. In order to turn the timer knob you need a flat blade screwdriver. Put the screwdriver into the hole and very slowly turn the timer until you hear a click. It will have mild clicks and then a more firm and louder sounding click.
When it clicks the fridge will stop running and the defrost heater will come on and melt the frost away.
NOW. Because the fridge has not been defrosted for at least several days, (instead of twice or 3 times a day normally) a great deal of frost has accumulated on the cooling coils. To melt all of this away, it will take several turns of the timer until it click into defrost. After it clicks into defrost, leave the fridge alone until it comes back on. If it doesn't come back on, click it till it does.
Here is the theory behind this system. There is truly no such thing as a frost free refrigerator. Frost free refrigerators have a timing mechanism or circuit built into them. Every 6 to 12 hours the refrigerator compressor (cooling section) shuts down. At the same time a small heater turns on inside the cooling coils and melts the frost away. After the temperature in the coils reaches about 50 degrees, a tiny thermostat shuts off the heater. The frost is then melted away. It goes down a drain tube into a pan mounted in the base of the fridge below the freezer. after a few minutes, the timer starts the fridge cooling for another several hours and it then repeats the cycle.
There may be another component in your defrost system that has failed ,but. you siad that sometimes the fridge simply stops working. That is an indication along with the indicatin that the fresh food compartment gets warm. The reason the fresh food compartment gets warm is that the cooling coils become "frost clogged". In other words, there accumulates so much frost that the fan that moves the cold air into the fresh food compartment cannot pull air through the coils. Thus the fresh food compartment gets warm while the freezer is still cold. I hope this is the answer to your problem. Best Regards,
Mark
LG Fridge not cooling refrigerator (freezer is fine, fan is running)
those sensors do fail but if the freezer is not as cold as it should be .then the refrigerator part will also not get proper cooling . TEST the freezer temp .
Sep 25, 2015 | LG Refrigerators
Refrigerator stopped working - working on repair #4
I hope all that was covered under warranty, otherwise they are playing you and your wallet for fools. Sure sounds like a refrigerant leak to me.
Oct 14, 2014 | Refrigerators
Fridge completely stopped working. This happened a couple of weeks ago but after cleaning the dust off the coil, it worked again. However, this morning it went out again. Please help.
If you can tell me what model and make I can solve this for you, for example Frigidaire, GE, Whirlpool, Sears Brand that has different numbers like 159.58975
Let me if this is a GE brand and model number, Thanks, Sea Breeze
5a66864.jpg Here are my site hyperlinks below.
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
Apr 16, 2009 | GE Refrigerators
My Zanussi fridge/freezer is making a funny little noise
What you may be noticing is the system going through a defrost cycle. Check the time of the day that you notice this event. If it happens at the same times it could be a normal situation if at all other times normal temperatures are being maintained. A popping sound can be caused by thermal expansion during the defrost.
Sep 13, 2008 | Freezers
Kenmore fridge isnt working
check in the rear of the unit u will need to pull it out and remove the panel see if the fan (Condenser) is running is the compresser running?? is the compresser hottt?? do you hear a hum and then a click noise?? is the condenser dirty?? remove the front kick plate to see this.. After you have cked these things let me know and we can go from there
Feb 16, 2008 | Refrigerators
Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Oct 09, 2007 | Zanussi ZX99 / 5 Bottom Freezer...
Kenmore 596-76512 fridge not cooling freezer seems to be working still
If the fan above the evaporator coils in back of the cover isn't running then no cold air will be blown up to the fridge area. That's a common failure item and very easy to replace yourself. And by the way... $200 bucks and 2 weeks out is about normal these days believe it or not. It's what we would charge ya! :) At least you did the troubleshooting and saved yourself a couple hundred bucks.
Jan 14, 2007 | Kenmore 71812 / 71814 / 71819 Bottom...
Kenmore 65234 Bottom Freezer Refrigerator Logo
435 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
