Question about Dryers
I have an Estate electric dryer. there is power to the unit but it will not turn on.
Check the thermal fuse also check the belt. If the belt is broke there is a micro switch that needs belt tension to operate
Posted on Jan 03, 2011
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Posted on Dec 30, 2010
Dryer stop working has power going to all parts
Check the continuity of the thermal fuse, often the culprit. Also check the power relay. Sorry but I am not familiar with the Estate dryers. But the above are two common problems in a wide variety of electric dryers.
Nov 10, 2011 | Estate EED4300TQ Electric Dryer
I have power but the unit won't turn on is it a bad start switch
Dryer Repair - The
Dryer Repair - The
heatman101
Feb 06, 2011 | Estate TEDX640JQ Electric Dryer
Young dryer quits in mid cycle.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 05, 2010 | Estate EED4300TQ Electric Dryer
Estate dryer makes ascraping noise when turning
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
uioto
Dec 29, 2009 | Estate EED4300TQ Electric Dryer
The WHIRLPOOL TEDS840PQ0 dryer wont turn on. The
Check the house electrical panel dryer circuit breaker pair--push off, then on. Try the dryer again. If still nothing, measure the voltage across the two slanted slots in the dryer power socket. It should measure: ~230 volts AC. If at or near zero, either one of the breaker pair is defective, or a wire is open from the breaker to the socket. If you read ~230 volts, then the problem is within the dryer--motor runs, but drum doesn't turn (broken belt), or motor doesn't run (bad controller, motor, door switch, start switch. Does the unit get hot? Need more help on your end.
Oct 18, 2009 | Estate TEDS840JQ Electric Dryer
Drum will not turn
YOUR BELT ON YOUR DRYER IS BROKEN. THAT IS WHY YOUR DRUM WON'T SPIN. YOU CAN BUY A NEW BELT FOR YOUR DRYER AT ANY PLACE THAT SELLS APPLIANCES.
RODNEY
May 15, 2009 | Estate TEDS740JQ Electric Dryer
Estate TEDX640PQ0 electric dryer makes grinding noise when running and seems harder to turn drum
heatman101
Apr 21, 2009 | Estate TEDX640JQ Electric Dryer
ON OFF SWITCH
Either the door switch is bad or the on/off switch is bad. You can do a continuity test on the switches to determine which one it is. Usually it's the door switch because it takes the most punishment. You need to check if the unit is getting power because the above fix is based on the fact you are getting power. Manually reset your breakers and pull the unit out and look at where the power cord is connected on to the unit. If they look fine and you have checked that there is voltage to the dryer you can do the above checks. Have a great weekend.
Apr 11, 2009 | Estate EED4300TQ Electric Dryer
Dryers Logo
47 people viewed this question
Top Dryers Experts
