Question about KitchenAid KGRA806PSS Gas Kitchen Range
I put oven on self clean. Cycle finished and now no power on touch pad and cannot open oven door. Replaced touch pad three months ago.
  • KitchenAid Master
  • 43,501 Answers
This time the problem is not the touch pad...
The self cleaning feature gets things extremely hot and has either burnt up the wiring to the touch pad or has caused the power supply on the main circuit baord to fail...to find out for sure which problem it is the power supply will need to be checked and then the appropriate part changed...
Self Cleaning Oven Problem
heatman101
Posted on Dec 30, 2010
How to use self clean for oven
Turn off the oven light and remove all pans and racks from the oven. Clean the oven and door frames with a non-abrasive cleaner. Do not clean the door gasket. Remove any excess grease or debris from the oven bottom.
Close the door and move the lock lever to the right. The "Lock" indicator will light. Press the "Clean" pad, then press the up or down arrows on the "Set" pad to adjust the cleaning time: two hours for light soil, three hours for medium soil and four hours for heavy soil.
Cancel self-cleaning after it has started by pressing "Cancel."
Wait one hour after the cleaning cycle has ended for the "Lock" indicator to go out. Unlock the door.
Clean the oven racks with soapy water and a scouring pad and put them back in the oven.
Sep 25, 2010 | Maytag MGR5752BD Gas Range
Model SVD48600 door won't open after clean cycle. Fan also locked on. Powered off overnight; no change: "Locked" still displayed
That is a very complicated unit for the average handyman. It has electronic controls and a relay board, sensors and a locking mechanism. First thing I would check is the locking mechanism and the switch on it. Do this first and let me know if you find one of the switches defective or shorted. While there, check the light switch which is bi-functional being used for the light and also to tell the ERC the door is opened or closed.
Jenn-Air self-cleaning ovens have a special setting that allows you to clean the oven without chemicals or scrubbing. The oven heats to a temperature higher than used for cooking. The intense heat burns food spills and other residue off oven's inner surfaces.
Instructions
1. Remove the broiler pan and any utensils to prevent them from being damaged. Take out the oven racks, since the high heat might discolor them.
2. Wet a cleaning cloth or sponge with hot water and detergent. Wash off splatters or spills from areas that won't be affected by the cleaning process, including the oven door liner and the oven's front frame. Wipe up any excess grease or spills on the oven floor.
3. Close the oven door and press the "clean" pad on the unit's touch pad.
4. Enter the amount of cleaning time. For example, two hours is appropriate for a lightly soiled oven, three for average and four for heavily soiled. Cleaning should start immediately. The oven will remain locked during the cycle.
5. To delay cleaning, hit the "stop time" pad and enter the desired stop time. For example, if it is 9 p.m. and you want the oven to clean for three hours starting at 10 p.m., key in the numbers 1,0,0.
6. While the cleaning function operates, use the scouring pads to wash the oven racks and other utensils. Once the cycle ends and the oven unlocks and cools, you can use a damp cloth to pick up any loose or burnt debris inside. Replace the racks, broiler pan and utensils.
Tell us news.
May 09, 2010 | Jenn-Air JGW8130DD Gas Single Oven
How do I set the oven to self clean
The oven door must be closed and all controls set correctly for the cycle to work properly. After a Clean Cycle You may notice some white ash in the oven. Wipe it up with a damp cloth after the oven cools. If white spots remain, remove them with a soap- filled scouring pad and rinse thoroughly with a vinegar and water mixture. These deposits are usually a salt residue that cannot be removed by the clean cycle. If the oven is not clean after one clean cycle, repeat the cycle.
You cannot set the oven for cooking until
the oven is cool enough for the door to unlock.
While the oven is self-cleaning, you can
touch the TIMER/CLOCK pad to display the time of day.
To return to the clean
countdown, touch the COOKING TIME pad.
If the shelves become hard to slide,
apply a small amount of vegetable oil or cooking oil to a paper towel and wipe the edges of the oven shelves with the paper towel.
Using the self-cleaning oven.
How to Delay the Start of Cleaning
Make sure the clock shows the correct time of day. If your model has a latch, latch the door. Touch the SELF CLEAN pad. Using the + or or the number pads, enter the desired clean time. Touch the DELAY START pad. The earliest start time you can set will appear in the display. Using the + or or the number pads, enter the time of day you want the clean cycle to start. Touch the START pad. On models without a door latch, the door locks automatically. The display will show the start time. It will not be possible to open the oven door until the temperature drops below the lock temperature and the LOCKED DOOR light goes off. The oven shuts off automatically when the clean cycle is complete. When the LOCKED DOOR light is off, slide the latch handle to the left as far as it will go and open the door. If your range does not have a latch, the door will unlock automatically. n The words LOCK DOOR will flash and the oven control will signal if you set the clean cycle and forget to close the oven door or forget to latch the door on models with a latch. n To stop a clean cycle, touch the CLEAR/OFF pad. When the LOCKED DOOR light goes off indicating the oven has cooled below the locking temperature, unlatch the door (on models with a latch) and open the door.
Oct 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Can I clean a TruTemp oven with soap and water without ruining it?
Yes you could clean it.
Check few details :-
t the bottom of this post you will find the web address for your ranges manual and the self clean system is in side this manual.
How to self clean
If your model has a door latch, never force the latch handle. Forcing the handle will damage the door lock mechanism.
Before a Clean Cycle
For the first self-clean cycle, we recommend
venting your kitchen with an open window
or using a ventilation fan or hood.
Remove any broiler pan, broiler grid, all
cookware, probe and any aluminum foil
from the oven—they cannot withstand the
high cleaning temperatures.
NOTE:
If your oven is equipped with nickel oven
shelves, remove them before you begin
the self-clean cycle.
If your oven is equipped with gray
porcelain-coated oven shelves, they may
be left in the oven during the self-clean
cycle.
Soil on the front frame of the range and
outside the gasket on the door will need to
be cleaned by hand. Clean these areas with
hot water, soap-filled scouring pads or
cleansers such as Soft Scrub®. Rinse well
with clean water and dry.
Do not clean the gasket. The fiberglass
material of the oven door gasket cannot
withstand abrasion. It is essential for the
gasket to remain intact. If you notice it
becoming worn or frayed, replace it.
Wipe up any heavy spillovers on the oven
bottom.
Make sure the oven light bulb cover is in
place and the oven light is off.
IMPORTANT: The health of some birds
is extremely sensitive to the fumes given
off during the self-cleaning cycle of any
range. Move birds to another well ventilated
room.
NOTE: Use caution when opening the upper
oven after the self-clean cycle has ended.
The oven may still be hot.
How to Set the Upper Oven for Cleaning
On models with Gas/Control Lockout,
touch and hold the Gas/Control Lockout
pad for 3 seconds to turn it off.
NOTE: The surface burners must be turned
off prior to the self-clean start time.
Touch the Self Clean pad.
Using the number pads, enter the
desired clean time, if a time other than
4 hours is needed.
Clean cycle time is normally 4 hours. You can
change the clean time to any time between
3 hours and 5 hours, depending on how dirty
your oven is.
Touch the Start pad.
the clean time remaining. It will not be
light goes off.
To stop a clean cycle, touch the Clear/Off
off, indicating the oven has cooled below
of day.
the door.
desired clean time.
Touch the Delay Start pad. The earliest
display.
Using the number pads, enter the time
to start.
light goes off.
a latch.
pad
After a Clean Cycle
oven cools.
soap-filled scouring pad and rinse thoroughly
repeat the cycle.
unlock.
touch the Clock pad to display the time
of day. To return to the clean countdown,
touch the Cooking Time pad.
If the shelves become hard to slide, apply a
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
I need direction on how to start the clean cycle on my jenn air
CLEAN PAD
Use to set a self-clean cycle or a delayed
self-clean cycle. One press of the Clean
pad sets up an immediate clean cycle. A
second press of the Clean pad sets up a
delayed clean cycle.
• Clean oven
frame, door
frame (area
outside of gasket)
and
around the
opening in the door gasket with a nonabrasive
cleaner such as Bon Ami*. These
areas are not exposed to cleaning temperatures.
• Remove air grille.
• Remove oven racks. If racks are left in
during a clean cycle, it may impair function
and they will discolor. Turn off the
oven light and close door.
* Brand names for cleaning products are
registered trademarks of the respective
manufacturers.
TO SET FOR IMMEDIATE START:
1. Press Clean pad once.
2. Press the Auto Set pad for 3 hours of
cleaning time, press again for 4 hours
and again if 2 hours of clean time are
desired.
3. CLEANING and LOC plus the clean
time will appear in the display.
4. When the clean cycle is complete,
CLEANED will be displayed. LOC will
remain on until the oven has cooled
(approx. 1 hour).
5. When the oven is cool, LOC will no
longer be displayed and the door may be
opened.
6. Wipe out the oven interior with a damp
cloth. If soil remains it indicates the
cycle was not long enough.
TO CANCEL SELF-CLEAN:
1. Press Cancel pad.
2. If LOC is NOT displayed, open oven
door. If LOC is displayed, allow oven to
cool.
Thanks for using Fix Ya, Please take the time to rate this solution.
clarkco
Feb 08, 2009 | Jenn-Air JDS9860A Dual Fuel (Electric and...
Oven Door is locked and will not open
On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. Pull or push the rod to move the lock to the open position..
Jun 06, 2008 | GE JBP70SKSS Stainless Steel Electric...
GE Profile XL44 Spectra gas oven
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
Feb 14, 2008 | GE Profile JGS968 Gas Kitchen Range
Self cleaning
You can go to the Maytag web site and download the manual.  www.maytag.com, or go to http://shared.whirlpoolcorp.com/assets/pdfs/literature/8113p293.pdf
and download the manual CAUTION
• It is normal for parts of the ovens to become hot during a self-clean cycle.
• To prevent damage to oven doors, do not attempt to open the doors when LOCK is displayed.
• Avoid touching doors, windows or oven vent area during
a clean cycle.
Do not use commercial oven cleaners on the oven finish or around any part of the ovens.  They will damage the finish or parts.
Do not leave baking/pizza stone in the oven during self-clean.
The self-clean cycle uses above-normal cooking temperatures
to automatically clean the oven interior.
The oven should be cleaned regularly by wiping up spillovers
to prevent excessive smoke and flare-ups.  Do not allow a
heavy build-up of soil to accumulate in the oven.
During the cleaning process, the kitchen should be well
ventilated to get rid of normal odors associated with cleaning.
Before Self-Cleaning
1. Turn off the oven light before cleaning as the light may burn out during the clean cycle.
2. Remove broiler pan, all pans, and oven racks from the oven.  The oven racks will discolor and may not slide easily after a self-clean cycle if they are not removed.
3. Clean oven frame, door frame (area outside of gasket, and around the opening in the door gasket) with a nonabrasive
cleaner such as Bon Ami* or detergent and water.  The self-cleaning process does not clean these areas.  They should be cleaned to prevent soil from baking on during the clean
cycle.  (The gasket is the seal around the oven door and window.)
4. To prevent damage, do not clean or rub the gasket around the oven door.  The gasket is designed to seal in heat during the clean cycle.
5. Wipe up excess grease or spillovers from the oven bottom. This prevents excessive smoking, flare-ups or flaming during the clean cycle.
6. Wipe up sugary and acidic spillovers such as sweet potatoes, tomato, or milk-based sauces. Porcelain enamel is acid-resistant, not acid-proof.  The porcelain finish may discolor if acidic or sugary spills are not wiped up before a self-clean cycle.
Important:
• Oven temperature must be below 400° F to program a clean cycle.
Only one oven can be cleaned at a time.
• Both oven doors lock when either oven is being cleaned.
To set Self-Clean:
1. Close the oven door.
2. Press the Clean pad.
    • CLEAN flashes.
    • SET and UPPER or LOWER flash in the display.
3. Press the Autoset pad.
    • “MEd” (Medium Soil, 3 hours) is displayed.
4. Press the Autoset pad to scroll through the self-cleaning settings.
     “HVy” (Heavy Soil, 4 hours)
     “MEd” (Medium soil, 3 hours)
     “LITE” ( Light Soil, 2 hours)
Choosing the soil level of the oven automatically programs the self-cleaning time.
5. After four seconds, the oven will start cleaning.
    • If the door is not closed, beeps will sound and ‘door’ will display.         If the door is not closed within 30 seconds, the self-cleaning       operation will be canceled and the display will return to the time of day.
    • CLEAN will appear in the display.
    • LOCK will flash in the display.  Once the door locks, LOCK will
      remain steady.
    • The cleaning time will start counting down in the display.
Nov 27, 2007 | Maytag MER6772 Gemini Electric Kitchen...
KitchenAid KGRA806PSS Gas Kitchen Range Logo
88 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
