Question about Square D Trilliant 100 Amp Circuit Breaker Main
Double pole 30 amp square d breaker is getting very hot when i run my forced air heat - why?
  • 55 Answers
Not enough amps. Check your wire size and see if it's safe to up the size of your breaker without having to run new wires
Posted on Mar 28, 2013
  • 16 Answers
SOURCE: 30 amp 2 pole GE GFCI breaker pops on hot tub after hrs of use
I have seen circuit breakers trip at a lower amperage. It seems that they are weak. Generally circuit breakers run with 80% load with no problem, in your case 24 amps. I would replace the circuit breaker.
Posted on Jan 12, 2009
  • 744 Answers
SOURCE: Need Alternate for Federal Pacific Breaker
Does the panel have room for the breaker?
Federal Pacific is a brand name panel and you may be able to find breakers at Home Depot, Menards, or Lowes if those stores are in your area. Bring the panel number to the store with you.
Here's a link for additional info:
http://www.baybreakers.com/catalog/Federal-Pacific-FPE.html
There have also been some recalls for these panel breakers. See:
http://www.philadelphiaelectric.com/recall__federal_pacific_breaker.htm
Posted on Apr 28, 2009
protek480
  • 1714 Answers
SOURCE: My double pole 30 amp sqaure D breaker gets a little warm...
You need to check the amp draw on the breaker that is warm. The smell you notice is not normal. Use a temp gun to test the breakers for higher that normal reading. High temp is caused by high current or loose connection.
Posted on Jun 30, 2009
volpe_42
  • 35 Answers
SOURCE: Gfi Breaker 2 Pole 20 Amp: installed 20 amp dbl pole breaker to hot tub. Keep...
When Working with Household Electricity you want to always keep in mind that the BLACK wire ALWAYS carries DEATH. What I mean by this is that working with a Single Phase Circuit (one that uses 120VAC) the only wire that should be carrying a voltage is the BLACK one, the other 2 wires (typically the White Neutral and Green Ground) should both be electrically connected to Earth Ground (usually by being attached to your water pipe.)
It is also possible that your hot tub may use more than 20 Amps.
Posted on May 19, 2010
  • 13 Answers
SOURCE: I have a Square D
im going off memerory right now but i seem to recall that you may only be able to instal that breaker in the lower part of the panel maybe check to see if the buss bar is a little short to acomadate the 2 pole breakers i will check it out in the am sorry if im mistaken
Posted on Jul 27, 2011
I have a Square D QO panel. I am trying to install a couple of 2 pole thin line breakers. I bought 2 QOT2020 breakers at Home Depot and they will not fit. I am aware of Square D's Homeline series...
Jul 23, 2011 | Square QO 30 Amp Double Pole Circuit...
I have a Maytag dryer model MED5740TQ0 that won't start. Dryer was recently moved to a new location. House was being remodeled so plug and breaker had to be installed. Plug is a 3 prong and dryer had 4...
If you are only getting 120v to the dryer, you still have a breaker tripped. It should be right next to the single pole 30. It takes 2 breakers to get the 240v you need to run the dryer. Try resetting another breaker expecially the ones marked 30amp. You do need to get a double pole breaker installed even for safety reasons.
Apr 12, 2011 | Maytag PYE2300AY Electric Dryer
There is the liquid seeping out of the breakers, it is not water the box is dry and it feels like an oil of some kind. breakers are working and are not hot. i have not seen this before. what is it and what...
It is oil. It's used to extinguish the arc.
When a circuit breaker trips, there is an Arc of electricity made inside the breaker, due to the contacts.
The contacts are instantly brought away from each other.
There are three methods employed to extinguish that arc.
[Extinguish the arc. Non-technical explanation. With out some medium to extinguish the arc produced inside, it would go Z-z-z-z-z-z-z-z-z-z-z-z-zap, instead of z-zap]
Oil, Air, and Sulfur Hexafluoride.
So yes, as long as the circuit breaker doesn't have to trip, and produce the arc inside, it is a working circuit breaker.
Is it a safe unit?
NO
The method employed to extinguish the arc if the breaker trips is leaking out.
Replace all breakers that are doing this.
Average cost for a GE single-pole 15, or 20 Amp is around $11 here. A few dollars more for 30 and 40 Amp, but usually double-pole breakers are used for 30, and 40 Amp.
Nov 18, 2010 | GE Circuit Breaker THQB BoltOn 1 Pole 15...
LG Dryer DLE2516W contiuously trips breaker but only on heat setting greater than low
Your circuit breaker may be bad. Run dryer and if breaker gets hot after 10min or so the breaker is bad.
Higher heat settings draw more amperage thus tripping the bad or undersized breaker. 30 amp 2 pole breaker required.
Ck. the power cord for signs of arching. Replace power cord or outlet if damaged.
Jan 04, 2010 | LG DLE2516 Electric Dryer
I have a 2hp compressor motor that keeps tripping the breaker after about 5 minutes of use. i have changed the caps but it keeps popping the starter cap. is the motor just bad?
Our 2 HP Speedaire horizontal tank compressor is rated 115 / 230 volts at 24 / 12 amps, respectively. This means at 115 volts, a 30 amp circuit breaker is the bare minimum. That also means that the wiring should be #10 copper wires for short runs, but the next size up; #8 copper wires would be better connected to a 40 amp circuit breaker. Running at 230 drops the amperage requirement by half, to 12. A #14 copper wire is minimum for short runs with a double pole 15 amp circuit breaker, but #12 copper wires connected to a double pole 20 amp circuit breaker would be better choice.
If the compressor is cord connected (or even directly wired) with the minimum sized wires, it will likely a voltage drop problem unless very close to the panel. This problem is more pronounced as the distance between the circuit breaker and motor increases, or when smaller wires are in the circuit. All the voltage at the circuit breaker does not reach the motor, as it is lost as heat; so the compressor only sees 90 to 105 volts instead of the 115 volts it expects.
If the cords, connections, etc are getting hot, it is a tell tale sign of under-sized wires and /or poor connections. Once you solve these problems, the compressor should run "as advertised " because motors usually don't "go bad" but fail all at once. Unless you have a bearing problem - or there is a problem with the load itself (compressor).
I hope this helped.
Nov 12, 2009 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Double breaker will not shut all the way off to reset to on
The breaker is bad and needs to be replaced when they do that.
Jun 29, 2009 | Square QO 30 Amp Double Pole Circuit...
Installing 30 amp square d breaker
if you have another breaker, try installing another one.(i have gotten bad ones from new all ready). if you dont have another breaker, disconnect or unplug what ever is controlled by that breaker. if it still does it while everything is unplugged/disconnected, there is a short in the line.
Jun 26, 2009 | Square QO 30 Amp Double Pole Circuit...
There is loose connection somewhere.Might want to look at the wires coming to the panel.
Mar 15, 2009 | Square QO 30 Amp Double Pole Circuit...
Technical Troubleshooting
1. Current Rating. 2. Trip Curve (B, C, D, K, UC-K, Z, UC-Z, etc)
Aug 27, 2008 | Square QO 30 Amp Double Pole Circuit...
Square D Trilliant 100 Amp Circuit Breaker Main Logo
125 people viewed this question
Top Square Electrical Supplies Experts
Jim D
Level 1 Expert
ken skalski
JOHN LAPIER
Are you a Square Electrical Supply Expert? Answer questions, earn points and help others
