Question about Proscan 26LB30QD 26 in. LCD HDTV
I keep gettting 'no CC info available' when I I hit the CC button on Proscan(26LB30QD) remote while watching cable. Cable box (DVR) is a Motorola DCX3400 and is provided by Comcast. I can do it from the front panel of the DVR, but it requires a power sequence.
  • Proscan Master
  • 736 Answers
You will not be able to get closed captioning by pressing the cc button on your television remote control. You must turn off the motorola cable box. Yes I did say turn off the motorola cable box. You should be standing in front of the cable box when you turn it off because as soon as it is turned off you must press the menu button on the cable box (not on the remote but on the cable box) right away. If you press menu soon enough after turning it off you will get a hidden menu. You will be able to scroll down to Closed Captioning and choose enable with the left or right arrow. Then just turn the cable box back on and you should have captions.
Posted on Dec 30, 2010
  • michaelmusin Dec 30, 2010
    Guru, thanks! I was aware of how to do that, but my the issue is the TV remote still won't work in that mode, meaning the CC is always on or off unless you power cycle the cable box. The main reason I use CC mode is some times I just want to rewind a a scene on TV turn on Cc and read what was just spoken. Does the CC not get passed thru to the when using the Motorola cable DVR? The same TV was fne using an Explorer DVR in Cox cable teritory....you have any other further resources? thanks for your assistance..
How do I switch from cable to an antenna
For the Proscan 26LB30QD, first make sure that the input is set to TV. (Use the Input button on the TV (top button on the side) or remote with that function.) Then press Menu (second button from the top on the TV) and use the up/down buttons/arrows to select Setup Menu. Use the left/right arrows to move into the sub-menu. Select the line Tuning Band with the up/down buttons/arrows. Use the left/right arrows to change the signal from Cable to Air. Press Enter (the Input button on the TV) to save the setting. Go back to Setup Menu and find Auto Ch Search to scan for channels. Once you select this line, press Enter and wait for the scan to be completed. Press Menu to exit.
I hope this helps.
Dec 01, 2015 | Proscan 26LB30QD 26 in. LCD HDTV
I need the remote code for Cisco cable box, model 9865HDC
This may not be a definite answer, but it may provide a hint what codes to try. Although the standard Cox cable box code for my Philips universal remote, 4200, worked for the 9865HDC, the standard code for my GE 24959, 0529, did not. Since Cisco acquired the Motorola cable box division a few years ago I tried all of those codes, but none worked. Then I noticed a single code 0506 for DVR under Motorola. It worked like a charm, even the dedicated DVR List button on the GE 24959. Hopefully you can find a Motorola DVR code for your universal remote.
Sep 26, 2013 | Cisco Computers & Internet
I unpacked my set and only received a remote and AC cord. Are there supposed to be cables to connect the TV monitor to the cable box?
More than likely no. It is not common for a t.v. to come with cables to connect to a cable box or anything else. You normally have to buy the cables you want to use separately.
Jan 05, 2011 | Proscan 26LB30QD 26 in. LCD HDTV
The list button doesn't work and I am unable to
turn off your cable box
turn off the dvr
disconnect cable box from wall outlet
disconnect dvr from wall outlet
unplug e-sata cable from dvr
replug e-sata cable back in to dvr
plug dvr into wall outlet
turn on dvr
plug in cable box to wall outlet
turn on cable box
wait for cable box to go completely thru startup procedure
...then try your list button again.
Mar 01, 2010 | Televison & Video
How to turn off CC. Button says no info
Go into your menu under Audio, it should be there, navigate to turn it off.
Jun 15, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Has a proscan 26lb30qd with no picture.
You need to give a lot more information about the type of set-up youare using with your television. The type of components in the system,like dvd/vcr receiver etc. The type of signal connection you are usingto the television. Cable or satellite box or antenna. If all yourconnections are correct and you are using the remote control correctly.You may have a problem with the video input circuits of you televisionand you should call for PROSCAN customer support at this telephonenumber. 1-888-977-6722. You can also get customer support from theirwebsite. www.oncorpus.com. I hope this has helped you with your problem.
Mar 10, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Synergy V remote - TV power on to last channel viewed - what's the code??
Actually, there is a setting in the cable box for this. You hit the settings button on the remote TWICE, then scroll down to Viewer:Power On. Click on what channel (or last channel) you want it to go to when you power on. Hope this helps. I have the 8300 HDC DVR.
Oct 07, 2008 | Televison & Video
Closed caption option on moterola cable box
I woke up this morning to try to win this fight I have had for days with my damn tv, our 3-year-old daughter somehow turned on the CC on the DVR box and we had no idea how to fix that.
I read the suggestions listed here and I wanna say a big huge THANK YOU to the person who suggested that to turn off the cable box thgen hit menu button and it would be there...your so right! THANK YOU again......
from a frustrated Mom in Maine
Jun 11, 2008 | Motorola Televison & Video
Turn off closed caption on input(component) on Sharp Aquos 42"
Had this happen on a Comcast box (Motorola DCT 6416 III)
Here's how to fix it:
Turn the cable box off, leave fully connected. Press Menu on the remote
The cable box internal menu will display (Not the Comcast one the Motorola one-- i.e. Display ratios-16:9 etc It's in black and white)
Use the arrows to cursor to the Closed Captioning and toggle to "Disabled" Press Manu again to exit and Voila!
Power the box on an have at it
Apr 10, 2008 | JVC HD-61Z575 61" Rear Projection...
Proscan 26LB30QD 26 in. LCD HDTV Logo
271 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
