Question about JVC AM FM CD DET FACE CAR STEREO
Hi I have just installed my now JVC KD-R616 and stumped on two issues, one is the orange wire with white stripe from the deck the install sheet says wire to car light control switch, what is its purpose? is it needed ? and where does it get wired to? is it the dome/door light or the dash lights? I only have two wires remaining in the 95 NJ pajero's harness and both say do not use in this diagram http://www.installdr.com/Harnesses/Mitsubishi-Wiring.pdf my harness is the bottom one and i have a extra wire (black white stripe) in position H and a green one with a stripe in location F and both these say do not use... the green one have been cut off the harness and its taped up (not by me) and the black one is showing continuity but not sure what this is.... the second problem (not sure if its related to this orange wire is the deck is resetting to default when car is switched off now i have check and the constant wire in the pajero and its defiantly constant and double checked my wiring and its connected to the yellow on the deck and Ive tested this on both sides of my wiring and still getting continuity.. im stumped! help would be much appreciated thank you :)
    Guru:
  • 680 Answers
The orange light to the light control is usually for the face/display dimmer. When the headlights are on it tells the display to dim so as not to be too bright while driving. It can go to just about any interior light that is on when the headlights are switched on. Ashtray light is usually the easiest. As for the continuity on the constant/memory wire. It has to be constant with the key off as if connected directly to the battery. Turn the key off and check for a blank accessory location in the fuse box with a test light. If hooked to that, be sure to install an in line fuse in an accessible location. The black wire may very well be the memory wire from the original radio.
I hope I've helped. If so please rate my assistance and leave a testimonial.
Posted on Dec 30, 2010
  • Drew Z
    Drew Z Dec 30, 2010
    Sorry, I meant the orange wire with the white tracer to the light control...
KD-R616 wiring diagram?
Drew, KD-R616 wiring diagram. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
JVC KD R616 Instructions Manual
http://pdfstream.manualsonline.com/c/c2fdda73-62c0-4be2-8de4-4829af7d168f.pdf
https://www.google.ca/search?q=KD-R616+wiring+diagram&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwi3jbu1ttrOAhXJA8AKHSxpBmUQsAQIHA&biw=1024&bih=681
Aug 24, 2016 | Car Audio & Video
JVC KD-R616 wiring colour instrutions
dan go here install manual has everything you need to know trouble shooting also http://www.jvc.co.nz/assets/pdf-manual/KD-R616.pdf
Mar 10, 2012 | JVC Car Audio & Video
Jvc kd-hdr1
Most wiring now is standard colors....red=ignition(goes to a switched power source...Yellow=battery...goes to a hot all the time(even with key off)...black=ground...white=left front speaker positive...white w/blk stripe=left front speaker negative...gray=right front spkr +...gray/ blk=right front spkr - ...green=rear left +....green/blk rear left - ...violet=right rear +...violet/blk= right rear - ...light blue or blue with a stripe is the remote turn on lead either for an amplifier or power antenna...some radios have an orange/ with white stripe that connects to your parking light dimmer circuit to dim the radio light with the dash lights....and then you should have the antenna plug and possibly rca outputs that go to an external amp
Feb 26, 2012 | JVC KD-HDR1 CD Player
Where is my remote wire input on my jvc g-220
Remote wire is for power antena or any other ancilliary unit is the blue with white stripe. You can find the installation manual on the jvc home page. Click on support and Instruction manual.
Feb 25, 2012 | JVC KD-G220 CD Player
I would like the wiring instructions for a jvc kd-g845
Wiring harness connections as described in the installation manual:
  1. Black: Ground to metallic body or chassis of car.
  2. Yellow: Terminal in fuse block connecting to car battery (bypassing ignition switch) (constant 12 V).
  3. Red: To an accessory terminal in the fuse block.
  4. Blue: Power antenna if any (250 mA max).
  5. Blue with white stripe: To the remote lead of other equipment (200 mA max).
  6. Orange with white stripe: To car light control switch.
Speaker connections:
Left front: + White - White with black stripe
Right front: + Gray - Gray with black stripe
Left rear: + Green - Green with black stripe
Right rear: + Purple - Purple with black stripe
Jul 17, 2011 | JVC Car Audio & Video
Installing Jvc KD-R610 into 02 Nissan Frontier, where I have removed older JVC. Using old harness, but blue wire labels do not match... One says "amp power" and other says "power...
well it sound like your ground wire is not connected the properly way this wire is black make sure
the other 3 are connect right are Yellow is constant power ,Red is acc.ingnition,Blue is the remote.
that would complite your conection done.
Dec 27, 2010 | JVC AM FM CD DET FACE CAR STEREO
Wired and Installed a jvc KD-R610 deck in my 95 mustang and deck will not turn on
You should verify your wiring .Also check all fuses. that is on the radio and for the power wire (red) .
May 12, 2010 | Car Audio & Video
Cd stero wiring help
To my knowledge, the illumination wire need not be connected to the JVC KD-G230. Further, other than the 8 speaker wires, the JVC has only:
  • black - body ground;
  • yellow - always on B+12
  • red - ACC/IGN B+12
  • blue w/ white stripe - external amp trigger and/or power antenna
Perhaps this might be of further help to you.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 17, 2008 | JVC KD-G230 CD Player
Wiring a new radio in 1991 ford explorer
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
JVC AM FM CD DET FACE CAR STEREO Logo
862 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
