Question about Nintendo Wii Console
My wii remote a and B buttons don't work and i have no pointer but i can turn it off and on??What to do?
    Problem Solver:
  • 15 Answers
Try charging it and replacing the batteries.
Posted on Dec 30, 2010
Wii nintendo controller wont show the pointer so i can access the game
You must sync the remote. To do this first take off Battery cover of remote.(leave batteries in) Then press the tiny red button on the front of the wii console next to the sd card slot for 2 seconds. Look at the back of the remote. In the battery compartment there is a tiny red button that looks like the one one the wii. Press it and they should sync. Now your remote should work.
Please rate.
Dec 31, 2010 | Video Game Consoles & Games
My wii remote pointer is not on the main screen but all the buttons work. I tried restarting cleaning both the wii sensor and the wii remote but nothing's working.
try reseting the system and then recalibrate it making sure that it is ok to be used
sorry i couldnt help much but GOOD LUCK!
Jul 21, 2010 | Nintendo Wii Console
I bought my son a Wii this past Christmas so it's not that old. The Wii remote finger pointer isn't working; however, I can power the remote on and off, use the "A" button, the home button, and use the "+"...
First you need to determine if the problem is your Wiimote, or your Wii's sensor bar.
You can check to see if your Wiimote is transmitting to the bar by looking at it through a digital camera (this allows you to see the infrared light). Turn everything on and view the tip of the remote through the camera, if it lights up: it's working, if it doesn't: you may need a new wiimote.
If it turns out your wiimote is working, then it probably means your sensor bar needs replacement. I think that is more likely (and less expensive)
Mar 29, 2010 | Nintendo Wii Console
I am attempting to adjust my wii remote sensitivity. The minus button will not work. it is currently set at 5...when I press the plus button it beeps as if I am adjusting in the positive, however when I...
Here are few Home remedies that should help you fix the issue.If you still face any problems then it is an internal issue with your remote and you will have to contact the nintendo support.
  1. Clean the Wii remote pointer lens. Use a soft cloth to remove any sticky substances. Wii remote jackets, stickers or other objects should not block the remote pointer lens, as it will cause characters to move erratically, disappear or remain off-center.
  2. Operate the Wii remote between three to eight feet away from the sensor. Otherwise, it will not perform properly.
  3. Note that infra-red lights from candles, toys, appliances, fireplaces and even sunlight may effect how the Wii remote performs. Try to remove or reduce infra-red interference from these sources when possible.
  4. Turn off or move wireless devices located near the Wii console. You may be experiencing radio frequency interference from other wireless devices.
  5. Check to see if anything is blocking the sensor. Clear objects away from the sensor and console to enable the remote to send a clear signal to the Wii system.
  6. Center the sensor bar directly below or above your television. Having the sensor off-center may cause the Wii remote to perform poorly.
Re-sync the Wii remote to the Wii system:
  1. Completely turn off the Wii system. Remove the batteries from the remote. Turn the power off on the Wii console. Unplug the unit from the wall. Wait five seconds and then replug the unit into the wall.
  2. Push the power button to turn on the Wii console. After the health and safety screen appears, open the small door on the front of the Wii console. Locate the red SYNC button. Push down on the SYNC button for fifteen seconds. This resets all previous SYNCS on the Wii system.
  3. Re-sync the Wii remote. Locate the red button on the remote control under the battery cover. Push and release this red button. The Wii remote should respond with blinking blue lights.
  4. Push and release the red SYNC button on the Wii console. Place the batteries back in the remote. When the remote is successfully re-synced, the LED light will remain lit.
  5. Repeat the re-syncing process with all other Wii remotes on this system.
Thank You
Oct 19, 2009 | Nintendo Wii Console
Remotes can't be found
When you change the batteries for a Wii Remote (in my experience) you have to re-sync (reconnect) them to the Wii console. To do this, there is a button on the Wii Remote by the batteries that either says sync or will show curved bars on I think i red button. This same button should be located on the Wii console. You have to push the sync button on the Wii then on the remote to sync them together. This should solve your connection problem.
Apr 29, 2009 | Nintendo Wii Console
Remotes
Under the battery cover on the remotes and under the panel on the front of the Wii are sync buttons. If you press one and then the other (I forget the order) it will connect the remote to the Wii.
FYI: The sensor bar only affects the pointer function of the remotes.
May 17, 2008 | Nintendo Wii Console
Wii sensor bar is acting up
wii snsor is very sensitive has it fell or had any cracks on it. play around woith remote more, maybe it will pick up the pointer, if not available online or in some stores.
Jan 11, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
13 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
