Question about Kenmore Dryers
My dryers heating element turns on and off very frequently and takes forever to dry clothes
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
You need to replace the "high limit thermostat". It's function is to come on at 160 degrees and cut off at 190 degrees. When it gets out of tolerance, it displays the condition you have described. If you could post your model number I will be able to point you to the part you need.
Posted on Dec 30, 2010
  • Kenmore Master
  • 8,220 Answers
You either have air restrictions causing the heat to build to fast and shut down the control OR you have a bad control. The control mounts on the blower housing. Next to the thermal limit. my dryers heating element turns - themobilian_611.jpgthemobilian_612.jpgFancy new fangled dryers with electronics use thermistors. Gotta have a NASA computer program to judge the temps in the drum. So where do they go to get them thermistors built?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
My dryer takes forever to dry anything and often times will not turn on when i press start after it's been ran for a 70 minute cycle but will turn itself on after sitting for awhile my dryer is
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 14, 2012 | Whirlpool Dryers
Indesit IS70C tumble dryer not heating
May 10, 2012 | Indesit IS70C Electric Dryer
My dryer only damp dries. Cannot dry towels. seems to take forever to dry anything
Hello there and thank you for choosing fixya
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it. To determine if the heating element is burned out, watch the part testing video at the bottom of this page. Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician. Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Jun 29, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer takes forever to dry clothes. now it will not dry clothing
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
This is a Free answer, Please rate me.
Apr 11, 2011 | Dryers
Heating elements are lit up working normal, drum hot but not inside of drum. it takes forever to dry clothes. vent wide open no clogging inside. need help ?
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Jan 04, 2011 | Whirlpool LER5636P Electric Dryer
My kenmore Electri Dryer is humming while drying.
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.hope this help you out sincerely D.Jones
Jun 08, 2010 | Kenmore 64672 Electric Dryer
Neptune glass front takes 4 hours to dry clothes.
make sure the vent system is clean. any restrictions can cause the safety switches to activate and turn off heaters. When it cools, the switch resets and starts heating. Unit will continue to cycle the heat off and on. Make sure all elements are working.
Start there.
Jun 07, 2010 | Maytag Neptune MDE6700A Electric Dryer
My dryer is a LER3624JQ1 it heats up but takes forever drying clothes. I have to run it 2 or 3 times. Help
Drying is too slow
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent
Heating element
Internal ductwork
Cycling thermostat
Good Luck!!
Thanks
Jul 07, 2009 | Whirlpool Dryers
Our dryer takes multiple cycles to get clothes dry. Eventually the clothes dry, but it takes forever.
If your dryer is taking more than an hour, check these. Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it. Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician. Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws. It overheats Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat (read about cycling thermostats in "Drying is too slow," above). It seems to run forever If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system. Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But?if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork
Jun 12, 2009 | Whirlpool Dryers
Estate Dryer 840 jq2 takes forever to dry our clothes.....
Is outlet holding plug good and tight (assuming this is electric as you say heating element). I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Estate TEDS840JQ Electric Dryer
Dryers Logo
53 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
