Question about LG WM1812C Front Load Washer
How do you replace the pressure switch on a lg electronics washing machine?
Did anyone ever give you the answer? I have the same problem. I have ordered the part, but not sure how to install it when it arrives.
Able to help?
Posted on Feb 03, 2011
Hi i have a lg washing machine wft8061dd,can u please tell me why PE appear when it turn on
Water level sensor fault This fault code is fairly self-explanatory and tells you that the washing machine has detected an error with the pressure sensor or pressure switch. It is rare to see this error code on LG washers.
On non-display panel models this fault code can be shown by the lights for fuzzy, heating and speedy or super, normal and hold being lit or flashing.
  • Check water level sensor
  • Check wiring to water pressure sensor
  • Check connections to water level sensor
  • Check main electronic controller
Jun 13, 2016 | LG Washing Machines
How do I replace on-off switch?
Washer Pressure Switch Replacement - LG Front-Load ...
? 1:45
https://www.youtube.com/watch?v=v0pluB3fEA0
Sep 27, 2011 - Uploaded by RepairClinic.com
This video provides step-by-step repair instructions for replacingthe pressure switch on an LG front-loading ...
NEFF Washing Machine Repair - Replace On/Off Sw
Nov 17, 2015 | Washing Machines
I have a LG wd-1025 washing machine and the start button wont work and does this intermittently
REPLACE SWITCH! If the machine persists after replacement then have the programmer checked if it is mechanical and the main logic board if the machine has electronic programming functionality
Jul 31, 2015 | LG Washing Machines
PE error code for my lg washing machine
The PE error or fault code indicates that the machine is overfilling with water. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch.
Mar 15, 2015 | LG Washing Machines
I was going to wash some clothes and the lg machine started going PE
Feb 15, 2015 | LG Washing Machines
Lg washing machine pe error
Pressure switch fault. Replace pressure switch. It is located under the cover at the top rear of the machine( with the water valves etc)It has a tube plugged in to it.
Feb 05, 2014 | Washing Machines
Lg top load washing machine not using water on rinse cycle but filling to the top on wash then leaking in floor
take out plug
you need to check the pressure pipe to the pressure switch ...blow air into it and look for any cuts on the pipe ....repair or replace it
Dec 23, 2013 | LG Washing Machines
How do you fix fe error
LE means washing machine electronic controller has detected an overfill situation
* check for over foaming or over soaping
*check the air chamber and pressure switch hose for blockage
*check water level sensor
*check wiring to water pressure sensor
*check connections to water level sensor
*check main electronic controller
Nov 07, 2012 | LG Washing Machines
LG WM0532HW
I found a part number for a switch: http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/WM0532HW/LG+Electronics+Incorporated/LG+Electronics%2fZenith/6600FA1704X/New.aspx To see the full list of parts for this model: http://www.partstore.com/Model/LG+Electronics+Incorporated/LG+Electronics%2fZenith/WM0532HW.aspx
Sep 02, 2007 | Washing Machines
LG WM1812C Front Load Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
