Question about Tomtom GPS
The Easyport mount for my TomTom 340S will not stay attached to the GPS unit. Whenever I try to adjust the position of the GPS when the Easyport is attached to the dash or the windshield it pops right off the mount. Is there a way to lock the GPS unit to the mount so it won't fall off so easily?
  • 1 more comment
  • Jed Fisk Dec 30, 2010
    Thanks for your post! I have checked the three wire loops on the back of the GPS unit and they all expand and contract with spring tension. The mount seems to attach to the back of the GPS properly as I rotate it 180 degrees to get the three wire loops to snap into place. But as soon as I pull or push on the GPS to adjust its position it easily just pops right out of the easyport mount. It seems like there should be a way to lock the easyport onto the back of the GPS.
    I actually have two different easyport mounts (the manufacturer sent me an additional one after I reported a problem). I get the same results with both of them. The GPS easily detaches from either easyport mount while making minor position adjustments. I have checked the 3 spring loops and they all appear to be functioning normally. When I attach the easyport to the GPS I rotate it at least 180 degrees to make sure all three loops have snapped into place. I attach the base of the easyport to a TomTom dashboard mount (the weighted bean bag mount) and the suction cup on the easyport works great with the dashboard mount--no problems with that part of it. The problem seems like a design issue to me, unless there is something very simple that I am missing.
  • Jed Fisk Jan 05, 2011
    Have you ever tried the Arkon TTEP112 easyport dash mount to replace the standard-issue mount?
  • 43,501 Answers
On the back of the GPS there are three wire loops that stick out slightly...make sure that all three are visible and that one is not jammed back into the base of the GPS...
Also make sure that the loops spring back and forth (in and out) with spring tension on them...
check that the llop that suctions onto the window or dash is not broken and can expand when the GPS is snapped in....
I find that mine seems to be hard to attach after mounting the suction part... I have started to push the GPS onto the suction part before attaching it to the window or dash...this makes it harder to get the suction cup to hold but that is easier then trying to attach the GPS with it already on the window...
Hopefully this will help you out there...
heatman101
Posted on Dec 30, 2010
  • 2 more comments
  • D. Floyd Kolb
    D. Floyd Kolb Dec 30, 2010
    Have you checked the loop of the mount to make sure that it is not cracked anywhere???
    I do agree though that the mounting seems to be very poor... Ihave not exactly been happy with mine either...
  • D. Floyd Kolb
    D. Floyd Kolb Dec 31, 2010
    I think you hit the nail on the head with the design issue/flaw...
    There is no way to "lock" that GPS into place...which there should be...
  • D. Floyd Kolb
    D. Floyd Kolb Jan 05, 2011
    No, but it would not take much for it to be a much better fix then the standard one...
  • kishenpatel1
    kishenpatel1 Feb 23, 2013
    I seem to be having the same problem but all the loops are fine...
How can I charge my tomtom xl 340s with my computer or is there an ac adapter option? Is car charging the only method?
According to Bill, from the TomTom technical services, your TomTom will charge when plugged either to your computer or to your car, as long at your gps unit is turned OFF.
Mar 03, 2010 | Tomtom XL 340S Car GPS Receiver
I recently purchased the tomtom 340S XL. Can it
Using cable data /charger port you can do charging both at system or in car under car charger option. those specifications placed in manual and normally lasts for 3 hours
Dec 16, 2009 | Tomtom XL 340S Car GPS Receiver
Where is the reset button on the Tomtom xl340s
The TomTom XL 340-S uses the power button as a reset. With the unit turned off, hold down the power button for approximately 15 seconds, until the TomTom turns on. As soon as the unit turns on, release the power button. The unit is now reset.
Nov 21, 2009 | Tomtom XL 340S Car GPS Receiver
We just purchased an XL 340-S amd cannot get it to stick to the dash in my Expedition. Any suggestions?
Step 1: Make sure the dash is clean and dry. Step 2: Take the dash mounting DISC that came with the unit and remove the cover sheet (yellowish in color). This should expose the adhesive. Step 3: Place the adhesive side of the disc on the area of the dash where you want your unit mounted. Be aware that the disc will not remove easily after being placed. Step 4: Press and hold the disc in place and put pressure on it to squeeze out any air pockets. Step 5: Once the disc is in place, ensure that the smooth surface of the disc is clean and dry, and free of grease. Step 6: Press the suction cup on the back of the TomTom windshield mount onto the smooth part of the disc, and rotate the locking ring clockwise until it won't turn any further. The locking ring is used to form an air-tight seal between the suction cup and the surface it is mounted to.
To remove the suction cup from the dashboard disc, simply rotate the locking ring counter clockwise and remove the unit from the disc. The disc remains permanently attached to the dash.
Oct 27, 2009 | Tomtom XL 340S Car GPS Receiver
TomTom EayPort mount will not stick to anything!
You will have to buy a new suction. After being in the hot car, and after suctioning up and taking down it will lose it stickingness.
Aug 10, 2009 | Tomtom One Europe v2 GPS Receiver
Tomtom one 125 easyport mount won't stick
The soft vinyl suction cup has two ears. Behind the ears are two depressions in the mount ring. The vinyl shapes itself into the depressions and forms two tiny gaps when you try to stick it to the windshield.
Place a pencil or other small round object between the ring and the soft vinyl part. Bend the vinyl outward. You may not be able to see the difference, but it should now stick
Jan 08, 2009 | Tomtom One Europe v2 GPS Receiver
How to mount tomtom 125 to the car
Alcohol works to a great degree to clean some surfaces. I have used lighter fluid to dissolve glue or adhesive residue that may exist. The alcohol will not work on a poorly cleaned surface. And lighter fluid does not seem to harm plastics. Use sparingly and clean in two or three apps.
Your solution seems to be that you are trying to attach the GPS suction cup to the dash without the plastic disc that comes with the unit. Glue the disc onto as flat a part of the dash as possible, Prefferably on the top of the dash. Then attach the Tom Tom with the cup onto the disc. A slight downward pressure while turning the locking handle is all that is necessary. I had a momentary adjustment time to learn how to lock mine. Love the TomTom GPS compared to the Navigon I returned to get an
XL330 S.
Dec 21, 2008 | Tomtom ONE GPS Receiver
Broke screen while trying to fix to windscreen
Are you talking about the easyport mount on the XL 330S model? If so it applies fairly easily in a secure snap. When I tested out the new mount, it was fairly easy to snap on without any added pressure. TomTom has great customer service and I'm sure they'll help out to the best of their ability and if it was in fact defective, you're bound to get a replacement. TomTom doesn't want any unhappy consumers. It's a shame it broke, because it is actually a great device.
Nov 07, 2008 | Tomtom One XL GPS Receiver
TomTom XL V2 EasyPort Mount
I wish I had that problem...mine won't stick at all!
Sep 16, 2008 | Tomtom One Europe v2 GPS Receiver
Unable to attach my new tomtom 930 go to the windshield mount, how do you unscrew the mount site at the back to fit into the nmount?
I have owned an off brand GPS unit for about 3 years and wanted to upgrade to a TomTom GPS unit. I have recently purchased a TomTom ONE XL. The TomTom will not stay mounted to my windshield. I have cleaned the suction cup and the windshield and nothing has helped. After the unit has been mounting for about 30~45 minutes it will fall off the windshield. I am afraid if this continues my TomTom GPS unit will be damaged. I have never had this problem before and as I mentioned earlier, I have owned a GPS unit for about 3 years. I noticed that the TomTom mount is very cheap built. Can you send me a better mount for my TomTom One XL? I am very disappointed in the unit so far and I only owned it for about 2 weeks.
Aug 18, 2008 | GPS
GPS Logo
261 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
