Toshiba Equium M50-192 Blank Screen when Boot
My Toshiba strated to over heat, so i took it apart cleaned it and put it back together but now it want start, Power light lights up, fan comes on and goes off then on agian after a while, but nothing on screen and no HDD activity. Connect external VDU Nothing!!, no sound at all...
Please can someone help.......
Everything is connected back as it was... I have exactly the same problem and so do a few other people on the net. This problem seems to be attached to the machine randomly crashing or BSOD , eventualy not POST booting at all. l am currently working on my machine. I will post a solution when I get it solved. Although any technical advice will be most welcome!
  • 1 more comment
  • widjet Jul 08, 2008
    Thanks for that, I do suspect the processor and am waiting for a
    replacement to test. I suspect that the overheating problem may have
    cooked the chip and there are "Heat" marks on the chip case on the
    side furthest from the heat sink. Will keep you posted.
  • widjet Aug 01, 2008
    Well Narrowed down the problem to the processor ZIF socket on the mother board. Have dismantled it and it looks like some contacts have come unstuck or broken . These are at the corners of the socket and may be due to the board flexing over time when picking up the machine. Problem is, I dont know how to replace this socket. The contacts are too small for me to repair so I need to replace the socket. But how do I get it off the board? Have removed the heat pad off the back of the board and this revealed that the socket is surface soldered and not through soldered ho hum ... Anyone any Ideas or solutions?? In hope - Wid
  • kevinh04 Jan 19, 2009
    i git the same problem have you solved yours yet ??
My laptop mouse is stuck
Posted on Jul 27, 2010
This happens to mine often. I found restarting it and powering up an external connected VDU it would then start up and pressing Fn F9 eventually got the screen back. A cool day and powering up the VDU just at the right time works. I can then use it until it overheats again. 2 months or 2 mins depending on the weather. I'm going to buy a new machine soon.
Posted on Jul 30, 2008
  • 2,028 Answers
This sounds to be an issue with the processor. Try removing the processor, blowing it off, and reseating it firmly and properly. Put it back together and see if this cures it. Keep in mind that a malfunctioning processor can cause an overheating problem just as easily as a fan or heatsink.
Posted on Jul 07, 2008
2 Suggested Answers
  • 177 Answers
SOURCE: Toshiba Equium M50-192 Blank Screen when Boot
I don't know "where" you worked on it, but I hope you were'nt standing on carpet when you did.If everything is connectrd the way it was, then the only thing I can think of is ESD (ElectroStatic Discharge) damage.
Posted on Feb 06, 2008
Screen is staying blank after start up
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :-
Mar 03, 2013 | Toshiba Equium A200-1vo 15.4" 1.4 Ghz...
Toshiba equium p200d-139d screen goin blank
Well, you can try this....
In safe mode, go to start->run, type in msconfig, and the system configuration window will come up.
Jun 12, 2009 | Toshiba Equium 7100S PC Desktop
Toshiba laptop won t start up
try taking the hard drive out then switch it on without it then switch it back off, put the hard drive back in then it should work, if not try f8 then safe mode and do a system restore
Jan 19, 2009 | Toshiba Satellite A60 Notebook
Toshiba Satallite 1415 wont boot
Sounds like maybe the hard drive is not hooked up or not hooked correctly. Tey unhooking it and re hooking it back up.
If it worked before but not now it has to be somethign is not hooked ack up correctly and a cd will not help.
If Its not the hard drive I would suggest taking it back apart to the point you had it before and reasembling it again but make sure all connections are tight, especially the ones where you slide the flat wire in and then lock it.
It has to be a loos connection some where.
that or the timing of the failure is just coincedental with the disasembly and one has nothing to do with the other.  If thats the case then you have a different problem.
If it is just a fluke and you just have failure I would suggest downloading a program you can install to cd like windows live and then boot to the cd.  once booted to cd you can access the hard drive and fix any problems with directory structure.
Dec 05, 2008 | Toshiba Satellite 1415-S173 Notebook
Feb 06, 2008 | Toshiba Satellite M45-S265 Notebook
Laptop would power off after 10 minutes....
open it bk up u may have knock any wires or links to the screen ps dont open laptops unless u no what u are doing
Jan 14, 2008 | Toshiba Satellite A105-S2717...
Computers & Internet Logo
1,444 people viewed this question
David Payne
David Payne
