Hi, I have a 2Wire 270 DSl Modem I had bought through Qwest since they are my ISP. My home is a 1500 Sft Ranch, if the modem is in the bedroom and the Mac Book is in the family room down the hall the signal is very low and hard to get anything to load. I have the same # of bars as the signal from my neighbors modem in the next house. It seems to me that I should be able to get a signal in all rooms of the house. I called Qwest, they say my 2Wire 270 is from 08 and I should buy a new $100 Modem, I think that is what they said when I called in 08 due to poor performance, basically spending $50 per year on Modem's and never getting good signal in the entire small house. Pleas help thanks Tom
  • 536 Answers
If the walls in your house are made of lathe and plaster or concrete block, then the performance of WiFi through all the walls in your house will be very bad. The signal that you are receiving from your neighbor's modem is probably only going through two walls (the outside wall of their house and the outside wall of your house), while the signal from your modem is probably going through at least 4 or 5 walls.
I suggest that you do not buy a new modem, but buy a wireless access point, a spool of CAT6 cable and two Leviton RJ45 wall jacks. Run the CAT6 cable from the modem to your bedroom, install the Leviton RJ45 jacks on both ends of the cable, and then connect the wireless access point to the the jack in the bedroom and the modem to the jack near to it.
This will expand the wireless coverage in your house and allow you to buy much better wireless device than QWest would ever sell to you.
Here is a suggestion for Wireless Access Point.
You can buy the CAT6 cable and Leviton RJ45 jacks at Home Depot or Lowes.
Posted on Dec 30, 2010
I turned off the power to my 2wire box - now I can't get it to power up and have internet. What do I do??? More details: I had turned off the surge protector the 2wire box is connected to - when I turned...
Hi there!. unplug the power plug of your 2wire box from the surge protector for 1minute and after 1 min, plug in directly to the wall outlet, not to the surge protector. try to unplug and replug as well the connection on the back of your 2wirebox and check the cable connection from the isp cable to the modem,, the last option that your going to do is to reset the modem of your modem/router but make sure that you know the settings of your modem and wireless settings if u have.. or contact your isp provide for further details..there is a situation that there is a problem from your dsl company connection, most dsl use telephone lines..
Aug 14, 2009 | 2wire 1000hg DSL Modem & 802.11g Wireless...
Dsl light flashes red constantly
Whenever your dsl light on the 2wire modem turns red,it only means that there is a problem with the dsl connection to the modem. Here are some ways on how you can isolate the problem
1. check if your modem is properly connected to the phone jack by unplugging and replugging you phone cable
2. try to reboot the modem
3. if still getting the same lights, contact your ISP
Nov 13, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Modem speed slow, reboot modem speeds it up
THE REMOTE COMPUTER DID NOT RESPOND
Oct 22, 2008 | Computers & Internet
Ip problem
It is common to have this as the default IP to connect to equipment.
I suggest you unplug your modem while you set up your router. You can also change the default IP for the router while in the settings. be sure to remember the new IP or you will have to do a factory reset to get it back to default
Jul 03, 2008 | D-Link 802.11g Wireless Router WBR-1310...
We recently got high speed internet from Qwest. It will not work. It keeps saying that the can't "ping" it. All light are green; power DSL, and the Ethernet. The internet is not. I have...
The DSL router/modem will receive an address from your ISP (Qwest) and will assign an address to the connected PC.
There should be a cable that goes from your DSL modem to your PC. It'll either be a USB cable (flat rectangular plug on the PC end), or a RJ45 (looks like a wider telephone plug).
If there is neither connection between the DSL modem and your PC, then the PC can't "talk" to the DSL modem, so it's not getting an address from the DSL modem.
Apr 06, 2008 | Computers & Internet
From a server I don't go through now
Is your new server also a DSL server? If you're now using a different service (e.g. cable or satellite) then the Qwest modem will not work at all and is basically an expensive brick.
Otherwise...
Your best bet is to contact your new ISP and find out. Some local ISPs (particularly in Montana) are essentially resellers for Qwest or another national company. If this is the case, the tech support from that company can likely walk you through inputting your new credentials.
If the new company doesn't use Qwest, it will be difficult. From what I've seen of Qwest's modems, they're heavily customized towards Qwest's services. But it is possible, you just need to talk to your ISP.
Dec 07, 2007 | 2wire (1000-100052-000) 802.11g/b Wireless...
2wire not finding broadband connection
I have tried also in the past, to set up a connection with this make of router with an ISP other than the ISP that supplied it and i was not able to get it to connect as i think the firmware is set to only recognise certain ISP IP addresses or MAC settings.
Aug 10, 2007 | 2wire (1000-400108-001) Router
Computers & Internet Logo
166 people viewed this question
David Payne
David Payne
