Question about Meade LX200GPS Telescope
My 8" LX200GPS won't turn
  • 3,186 Answers
Then it is an internal circuit board issue. Something is either unplugged inside the scope base-- or is burned out. Meade can repair these call them:
http://www.meade.com/support/index.html
Posted on Dec 30, 2010
Troubleshooting for maxent mx-42hpt51
hello!
Blue screen(bright blue) indicates an absence of signal. If you have "on screen" display characters: menu, channel ##, volume bar, etc, your set might be configured for digital antenna settings, or DTV, "air" mode. Then, you won't be able to get cable channels through. If your "blue screen" is dim and there is no any characters, then your Y-sustain module is bad. Especially, if you have encountered loud "pop" shortly before "blue screen" appeared. Then, it's a major repair with board(s?) replacement. If you can handle that, get back to me in a next session. I will guide yourself "how to".
Thanks,
Alex.
Feb 16, 2012 | Maxent MX-42HPT51 42 in. Plasma TV
NO SCREEN
Hello!
Depends on circumstances: if your display glows, but there is no characters(menu, ##), your t-con board is at fault. The one, what adapts display to main(signal) board. It always attached to panel itself, covered by metal shield. Tough to get to it, but less expensive. If display won't glow, but flashes once and then quits: inverter(s?) at fault. In some TVs there are 2 inverters: master and slave. Usually, just one is bad, but better to replace them both, unless you can diagnose which is bad. Bad one might have blown fuse and/or burned IC chip on board.
Good luck with your project,
thanks,
Alex.
Jan 01, 2012 | LG 42LC2D 42 in. LCD HDTV
The machine appears to be stuck in a wash cycle. After unplugging the machine & plugging it back into an outlet you have no indicator lights. The only button that has a response when pressed is the...
this machine sounds to have a computer board problem I have a calypso washer also and i had the same problem so I ordered both computer boards and replaced them and everything was working like new , I haven't had any further problems since
Jul 31, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
When i am copying some videos and wallpapers in the memory card it is showing "unable to display all files exceeding 52 characters are not supported in the phone"please tell me the solution..if...
before copying the files rename them to reduce the number
of characters of the name, because your model won't display files with name
exceeding 52 characters..
Jan 30, 2011 | Samsung GTC3300 Cell Phone
My telescope/autostar not working ,will only display startup info on handbox ,then nothing happens !.
This is sometimes caused by a bad hand controller cable and or corrupted firmware in the hand controller.
Get a new cable first and try it-- if this does does work then RESET the hand controller and reload the firmware using the proper computer cable and Autostar Updater Version 5.9 available here:
http://www.meade.com/support/auto.html
http://www.meade.com/support/Win7_ASU592_Installation.pdf
Aug 31, 2010 | Meade LX200GPS Telescope
I have a frozen autostar 497 handbox, can it be reset or saved? While doing an update, the updater program window asked if the handbox was in ''safe mode'' (I think it was something like that), I clicked...
Turn off the scope and plug in your computer update cable.
While holding down the ENTER key and the Scroll DOWN ARROW key on the bottom, turn the scope on.
The controller will go into Safe Load mode-- redo your update again.
Oct 12, 2009 | Meade Optics
Meade LX200 drive system keeps spinning
The older Lx200's go into tracking mode when turned on if they are not recieving a signal from the handbox. It does this on purpose so you can use the telescope without the handbox and still track sky objects. If it is still doing this with the handbox plugged in then you have a bad chip in the electronics and Meade is notorious for not having parts for their older telescopes. Don't send it in to them to repair. It will cost you a fortune to mail back and forth and they still can't repair most electronic problems with their older scopes(from my personal experience).
Apr 21, 2009 | Meade LX200GPS Telescope
Meade Autostar handbox
removeformat.gifBecause this is a new purchase i would suggest getting the handbox replaced under warranty. If the guy was rude, then mention this to their management. There have been quite a few prolems with meade gear on our site here. Handbox included.
If you are up to it you can open it up. if so inspect the board for damage, shorts or loose solder joints. Some of these things can be repaired, some cannot. On this last statement it would seem sensible to get the replacement then start again from scratch. I have found about 7 recent problems with this unit, so be aware this is not a fault free unit.
nettiser
Sep 15, 2007 | Meade 494 AutoStar Telescope Control Unit...
Meade LX200GPS Telescope Logo
141 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
