Question about Whirlpool Duet GHW9150P Front Load Washer
My washer stops in the middle of the cycle, and flashes f121 and sd. i have to stop it and restart it a few times to get i load done.
SOURCE: washer stopped
The computer needs to reset. Try unplugging the machine. Plug it back in and then the system should be able to be restarted.
Posted on Jul 14, 2007
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Duet Washer
F11 is a serial communications error. This is a symptom of an electronic control board starting to go bad. As defined by the technical information provided by Whirlpool, the error could also be caused by a loose or broken wire connector and/or the central control unit (CCU) (front panel). I would double check all your wire connections leading to the control board and CCU, first. Don't be surprised, however, if the problem persists and you eventually have to replace the electronic control board. To check, follow these steps: 1. Unplug washer. 2. Remove the three screws along the top of the washer in the rear that holds the top panel on. 3. Once the screws are removed the top should slide back then lift up. 4. The electronic control board is gray (or white) in color and located in the rear of the washer. It's impossible to miss. Double check all the connections ONE AT A TIME. 5. Double check the wire harness connections leading to the front panel as well. I hope this resolves your problem, but experience has proven that this is usually an Electronic Control Board failure. It could actually be a combination of the CCU as well. The part numbers are as follows: Electronic Control Board: 959503 Central Control Unit: 1025824 Both boards cost about $150 each. Let me know if this helps you.
Posted on Sep 03, 2007
natengel
  • 19 Answers
SOURCE: Washer stopped in mid-cycle and is full of water. I can restart the cycle, but
if it stops at #6 u need to change timer and motor
Posted on Oct 31, 2007
  • 36 Answers
SOURCE: Whirlpool Duet Sport Front loading washer and dryer with error code
take off the bottom kick panel locate the drain pump now there will still be water in the washer so take caution when following this procedure i use a shop vac and suck all the water out of the drain hose to prevent a mess then the frount of the drain pump will screw off check it for blockage or damaged impeller blades
Posted on Dec 28, 2007
  • 11 Answers
SOURCE: Machine stopped in middle of wash cycle.
Timer needs replaced try gigling your timer knob and see if you get any reaction dont be afraid gigle it up and down hard sounds like point in timer are burnt
Posted on Sep 17, 2008
Machine stopped in middle of cycle ,wash flashing something on screen, tried to restart wont't run water could it be out of level for it not to run water
It's probably flashing an error code. Write down the code and look it up in the owners manual or online to find out what the issue is.
Aug 17, 2014 | Samsung WF328AA Front Load Washer
How do you go about restarting this model of washers so that it does not stop in the middle of the cycle?
Does the Machine fill up with water properly sounds to me like the fill sensor is stuffed or an inlet valve issue . Try checking the level of your machine some will stop half way through a load because the machine out of balance switch is stuck on.
Jul 11, 2014 | Fisher and Paykel WA37T26G Top Load Washer
My washer stops in the rinse cycle and sometimes in the begining of the wash cycle again
Not exactly easy to determine. Must check a few things first. 1) Does the timer stop at exactly the same places everytime when it stops? Make a mark at the place it stops and restart the program a few times. When it does stop, note if it is always at those marked positions. If so, the timer needs to be replaced. If the stopping positions on the timer are in the middle of washing and especially the spin, then the motor is defective.(the internal overload/overtemp) protection is activated,.
Aug 22, 2010 | Admiral 32 cu. ft. Washer
My Kenmore 110-46462501 washing machine stopped mid-cycle
Can you hear the pump running? It might be plugged or not running
Oct 20, 2017 | Kenmore HE2 Plus Front Load Washer
Stop frequently on spin and rinse cycle F6 code
I have a Kenmore Elite he4t front load washer that was working fine and then we moved and now it stops washing midstream and flashes an F and a H. I have to pause and restart then it will stop washing again after a few minutes and flash the same codes again. I reset again and then it stops with 1 minute left and will not drain.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
Amana nfw7200 washer stopped in middle of cycle and is flashing ''nd''
is it full of water? if so there is a drain problem and may have to clean out the pump
Aug 23, 2009 | Maytag NFW7200TW Front Load Washer
Washer stops and must be restarted flashes F51
there is a updated wiring harness and sensor on the the bottom of this tub on the motor. It needs replaced
Nov 13, 2008 | Kenmore 22422 Top Load Washer
"F" error code in WTW6600SG1 Cabrio Washer
I don't have a solition and am looking for one my duet whirlpool keeps coming up code F
Jul 07, 2008 | Whirlpool WTW6600SW Top Load
Washer stops during wash cycle
you may a pluse cycle where the washer will stop for a couple of min, this cycle is for perm press to minimize wrinkels
Nov 12, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washer stopped
May 02, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
55 people viewed this question
Dan Webster
Dan Webster
Sal De
