Question about Intel Motherboard
When i start my computer. the fan turn i on. but in just few second the cpu. stop working...its not rebooting at first, what should i do?
    Sergeant:
  • 188 Answers
Usually this problem comes when there is lots of dust on the cpu heat sink, fan and the mother board.just use a long soft paint brush and clean the dust, alos if you have a vacum cleaner reverse the inlet and use it as a blower.
try and post comments
regards
Posted on Dec 30, 2010
3 Suggested Answers
tom19511
  • 1601 Answers
SOURCE: cpu fan starts then stops
Replace it and let us know if it still happens with the new one.It shut down because of overheating, I hope it didnt mess up your CPU.
Posted on Jan 06, 2008
  • 262 Answers
SOURCE: cpu get stop after few second & no display at all
sounds like mite not have enough power supply how much power supply do you have 300 watt 450 watt ? if there isn't enough power it will shut cpu off , email me lala linda
Posted on Jun 03, 2008
Why is my Sony VAIO VPCEB33FM green power light flashing?
It won't be the cpu. If it was, nothing would happen. I would look for a GPU issue, possible over heat.
Jan 01, 2015 | Sony Vaio Vpceb33fm
Medion MED MT503 won't start or go through p.o.s.t.
When you say "fan" do you mean case fan or CPU fan? Almost sounds like the CPU fan is inoperative and the system is shutting down on CPU overtemp, then trying to restart.
Aug 01, 2014 | Medion Computers & Internet
When i plugged power cable to my pc cpu fan start without press power button
It should start for a few seconds, the fans should spin and then stop. You should be able to power it up as per normal. If that is no the case then you are having hardware issues which could be the Power supply
Apr 03, 2011 | Intel 845GE Motherboard
It was just this morning when I tried to turn my pc on.. unfortunately it did not. ! when i press the power button on cpu it turns on for a few second like one or two but immediately after it drops the...
Try replacing the power supply - I had a similar problem that was fixed that way. If that doesn't work, it's probably the motherboard itself. The CPU is also possible - have you overclocked it or otherwise cooked it? Is the CPU cooler/fan blocked with fluff, or has the fan been slow (or stopped) - noisy fan is a sign of bearing stiffness/partial seizure which slows the fan and lets the CPU get too hot. If the CPU is fried, you get the symptoms you describe (MB won't start the PS)
Dec 23, 2010 | ASUS M2N-MX Motherboard
My problem is, i've had this computer for since 2003, I installed a new harddrive and it was wornking fine for about a year or so, then I think i got a virus so i reformated the harddrive but in the midle...
it have 2 reason
first u check to change another memory
last ur fans in ur cpu not work fine so can not heat relieving for ur cpu so when overheat it auto turn off
Jan 15, 2010 | Sony VAIO FRV37 Notebook
I have checked monitor with work laptop and monitor works fine, issue started after replacing cpu fan on motherboard, had previous issue with old card, got no signal with old card rebooted computer and it...
I would check the video card to make sure it is seated properly and clear from any dust and lent in the slot.
Also, make sure the fan/heatsink is on properly. If your processor isn't staying cool, it will turn on for a few seconds then shut off.
Jan 13, 2010 | ASUS P4S800 Motherboard
Asus Laptop freeze after starting
if the fan does not work... don't use the computer till you replace the fan with one that is working.... a good chance you will burn out the cpu. usually thermal shutdown occurs when the cpu gets too hot... you may also want to consider purchasing a notebook cooler....
Robert
Dec 17, 2008 | ASUS m6n Notebook
Start up
If the Computer In question is a PC Desktop computer a few issues. First power supply may be malfunctioning. Second check the the CPU fan inside computer is running and not full of dust when you turn it on. If it's dusty, get vacuum cleaner and clean it. Fans need to be able to work without overheating because CPU runs hot.
Thirdly try to take out battery and restart computer. If starts up replace with new battery.
In Case it's a laptop. Take out battery and try to run using power supply and if turns on place battery back in. If battery isn't charging you will need a new battery. Let me know how you go!
Aug 03, 2008 | Computers & Internet
Trouble shooting
OC failure = over clocking failure. Make sure the CPU fan is clean, free from dirt & dust. Check CPU fan plug is connected correctly. If the CPU fan still stops after a few seconds replace the CPU fan.
It's harder to find just a fan to fit your heatsink, which sits on your CPU. It is easier to find a new heatsink \ fan combo for your Intel. Use your manual to find what Intel chip is on your board. Use that information & search google for a heatsink & fan combo. Pay close attention to how your current heatsink is mounted to the Gigabyte board.
Mike
Mar 24, 2008 | Computers & Internet
Cpu fan starts then stops
Jan 06, 2008 | Biostar GEFORCE 6100-M9 Motherboard
Intel Motherboard Logo
47 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
