The DVD stopped playing and I 'm unable to open it even manually to remove the DVD
  • 6,771 Answers
There should be a pin hole in front of the tray, if there is! use a needle or very fine screwdriver and push it in until you hear a click, the tray should pop open.
Posted on Dec 30, 2010
While playing the VHS the player switches from VCR to DVD in the middle of the movie multiple times. We ended up having to tape the DVD player closed because it would turn the player on in the middle of...
Hi, it sounds like either the eject button on the DVD player drawer has been damaged or the remote is in need of cleaning (I assume the remote to have an eject button too). you can remove the remote by removing a battery and seeing if the problem stops.
Best you remove the tape from the DVD drawer as this will not stop the DVD mechanism from trying to open the tray, bit like trying to constantly push against a locked door - you will cause damage if it hasn't already.
Aug 13, 2010 | Zenith XBV442 DVD Player/VCR
DVD player doesn't work
you can open the top cover and take the cd out.
Jun 04, 2008 | Sony SLV-D350P DVD Player/VCR
Buttons on the remote of my new undercabinet TV work only on an intermittent basis. I am unable to start at the 2nd or 3rd title of a DVD. Have not yet been able to make the ''Go to'' + ''number keypad''...
My new TV/DVD doesn't work. I went to the indicated GPX website for help, and all I get is a solicitation for a subscription assistance plan. Beautiful: misdirection, subterfuge and confusion. Smoke and mirrors. The new American way.
Nov 12, 2009 | GPX Televison & Video
Dvd player stops playing
Check out this website for troubleshooting and repair tips on your dvd player. Just paste the web address into your address bar. http://www.drx9000repair.netfirms.com/ They have lots information on these dvd players and also do repairs.
Apr 11, 2009 | Cyberhome CH-DVD 300 DVD Player
LD Repeats itself every 15 seconds in play, DVD's play fine.
This solution should help or at least decrease the occurances.
It has worked for me.
The problem seems to be that the original manufacturer lubrication on the glide rails and on the glide track has lost it's viscosity causing the Laser Pick-up Head gliding process to bind causing video to repeat at any random binding point.
Open the top cover and play a Laser Disc.
Manually change from Side "A" to Side "B".
Observe how the Laser Pick-up Head glides on the track and on the glide rail.
Stop play mode and remove the Laser Disc.
With the tray open, unplug the power at the power electrical cord. Now with the power removed and the tray left open, take a "Q-Tip"™ and spray some ""WD-40"­™ on the "Q-Tip"™.
Now gently tap the saturated "Q-Tip"™ along the full length of both the upper and bottom glide rails as well as the glide tracks.
Repeat this process.
Be careful not to touch or lube the Laser Pick-up Head with the "Q-Tip"™.
If you do touch the Laser Pick-up Head, just gently clean it with another "Q-Tip"™ saturated with alcohol.
When finished, reconnect the power and play a Laser Disc.
Manually change From "SIDE "A" to SIDE "B" about three times to spread the "WD-40"™ evenly and ease the gliding process.
This solution should help.
Feb 08, 2009 | Pioneer DVL-919 DVD Player
Dvd compartment will not open
unplug the Acoustimass power from the wall, then plug it back in.
Dec 25, 2008 | Bose 3 2 1 GSX System
Won't play, says open even when the lid is closed.
Well , from your bumping experiences , I would say the latch/hook/switch that tells the player that its lid is closed is loose.Carefully close your lid and see the parts that touch and you will find the latch/hook/switch.Manually play with it (or tape it down!) for a quick fix.For a more permament fix you might have to open it and fashion (or buy) a new switch.
Dec 18, 2008 | Televison & Video
Can't play region 2 dvd's on my player
Newer DVD224 is actually DVD-224ss - small print on front of manual. There are two possible hacks:
DVD224SS (This worked for me)
1. Open the DVD tray
2. Press STOP button on the remote control
3. Press 70
4. Press MENU
5. Use the numeric keypad to select your region code number (0 – 6).
OR
DVD224 (224SS)
2. Press STOP button of remote control
3. Press the digit number buttons “2008” of remote control.
4. Press MENU
Region code will appear, select your region code number.
Jun 22, 2008 | Coby DVD-224 DVD Player
DVD not playing message say H02
There is a solution but it takes a little care because the wrong thing touched will give you a shock. Just stay away from the unit near where the power lead enters the unit. OK. remove the top of the unit, place a disk in the unit press play and gently give the DVD a gentle push in a clockwise direction. This disk should then get up to speed and start playing. It also unlocks the error. No guarantees with this one some work, some don't. I hope yours does. BMW
Jul 28, 2006 | Panasonic DVD-RV31 DVD Player
13 people viewed this question
 Grubhead
Grubhead
