Question about Intel Motherboard
My computer doesnot turn on, no video. Solid yellow led on motherboard.
  • Intel Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Dec 30, 2010
Nec vt540 vt540k
probably needs filters cleaning or a new lamp replacement.
Oct 07, 2013 | NEC VT460 Multimedia Projector
I need the wiring chart for a mcp61pm-am motherboard
Gateway Support > Gateway MCP61PM-AM motherboard,
http://support.gateway.com/s/MOTHERBD/Shared/4006200R/4006200Rnv.shtml
Click on - Product Views
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the wires from the Front panel go to, is the Front panel header.
If you need the pinout for the Front Panel header, click on -
S- Front Panel Connector
Looking at the different colors on the Front Panel header, and matching pin numbering;
Pin 2 = Orange with Yellow + sign.
Pin 4 is solid Orange.
Pin 6 is Green.
Pin 8 is Green
There is NO Pin 10.
Pin 1 is Red with a Yellow + sign.
Pin 3 is solid Red
Pin 5 is Blue
Pin 7 is Blue
Pin 9 is solid Yellow.
A) Pins 1 and 3 are for the HarDDrive activity LED (Light)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. Reserved for +5 Volts, and factory use.
D) Pins 2 and 4 are for the Power On LED. (Light)
Pin 2 is for the Positive ( + ) wire.
If the PWR ON LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) There is No Pin 10. Just a blank spot. (Yellow)
Click on B - Processor Core Power, for the 4-pin ATX +12 Volt power cable connector, location on the motherboard.
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
[ Processor to the Top, Ram Memory slots to the Right;
the square white 4-socket hole connector, is straight over to the left, from the bottom left corner of the Processor socket ]
On the U - Intrusion Switch Connector?
I believe the style of switch used, is if it is open, then the computer will not work.
Therefore connect a small wire to those two pins.
(Same thing as the switch is Closed)
Need Molex female metal terminals?
http://www.molex.com/molex/products/datasheet.jsp?part=active/0002081202_CRIMP_TERMINALS.xml&channel=Products&Lang=en-US
Could I be wrong about how the switch works? Yes.
Could be the alternate style where the switch is open, and removing the computer case cover, closes it.
In this case do not connect a jumper wire.
All the other wiring connections are shown.
Have a specific question on the wiring? Post back in a Comment.
Regards,
joecoolvette
Aug 05, 2012 | Gateway Computers & Internet
Dell Optiplex 740 Desktop Desktop Computer i shutdown my computer and i tryed to turn it back on and the power light is yellow?
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
A solid amber power LED indicates a problem with the motherboard, or something attached to it. (I've seen a bad mouse cause a no post before) Disconnect all cables except power, turn on system see if any LED change. If using a UPS, connect power direct to the wall. If still no change, open case, remove any expansion cards, try again. If still no go, disconnect power cables to all drives, try again.
If still no change, then replace the motherboard
Dec 25, 2010 | Dell Optiplex 740 Desktop Desktop Computer...
Computer wont turn on power light is yellow
Here is the Diagnostic LED information
Normally a solid Amber Power LED is a motherboard failure or a device attached to the motherboard (Expansion card or external device)
May 15, 2010 | Dell Inspiron 530 Desktop Computer
Main power button LED is flashing or solid yellow
This is a major problem that crippled Dell. Moels Optiplex Gx260, Gx 280, and Dimensions of whose mdel number i don't remember have this problems. This signal shows that either a power supply or your motherboard is malfunctioning. If you have an insurance better use it now or else get some technical assistance.
Nov 03, 2009 | Dell Dimension 8200 PC Desktop
No boot and no power!!!
Thank you for contacting FixYa. I would be more than happy to help you. The problem you mentioned seems interesting to solve..let's see what can
we do to fix this.
You said, as soon as you connect the adapter the computer shuts off, but on the battery it works. Here is what we can try to fix this : -
1. try to take out the battery and then start it with the adapter only. if it turns on then connect the battery else,
2. the motherboard port where the adapter connects to the system board has gone bad and needs to be replaced. you can get it fixed or soldered from a local technician.
3. Check the LED's status of your laptop by click here.
4. In case link doesnot work.
a. flashing, solid, solid : - Reseat the processor or replace the motherboard.
b. Solid , flashing , solid : - replace / reseat the memory.
c. flashing, flashing, flashing : - replace the motherboard.
d. flashing, flashing, solid :- replace the video card.
e. flashing, flashing , off :- reseat /replace the keyboard.
f. flashing , off, flashing :- Removing any USB devices.or Replacing the system board.
g. off, flashing, flashing : replace the motherbaord.
99% the motherboard has gone bad and needs to be replaced.
you can see the manulas for your computer by clicking here.
But, as per my understanding the motherboard needs to be replaced. you can contact a local technician who can fix that for you.
Your question was answered on 09/26/2009 at 17:55 Please rate my post "very high" if this answer is relevant to your question.
Sep 26, 2009 | Dell Latitude C640 Notebook
I have a toshiba v000108500 motherboard, when lan cable is plug into RJ45 socket, lan work normally, problem is the yellow LED of RJ45 always on (doesn't matter two computers communicate or not), when two...
If you are not having any reception problems to the internet, worry not.
Normal is solid amber, and when it flashes that is a sign of activity on the line. This is not a indicator of a problem or potential problem.
Again if I understand you correctly the local area network is working normally. If this is not the case please write back.
Hope this helps, please leave rating. Thank you kindly
May 07, 2009 | Computers & Internet
My computer system doesnot play sound
Its not difficult. First of all, right click my computer and click properties. Then go to hardware and then to device manager. If your media player is showing error that the driver is not found, then it will show red/yellow mark at "sound video and game controllers". If it is red/green, right click it and select update driver. It will ask for motherboard cd. insert the cd, the computer will automatically take the required driver. Then its is done.
Jan 13, 2009 | Philips GOGEAR SA6045 MP3 Player
D530 CMT minttower power problem
Hi, from your description it appears your power supply is ok.
Remove your RAM chips, clean everything with a soft brush or a can of compressede air [from computer store] Reinstall the RAM making sure it is seated firmly.
If this does not solve the problem, Are you using 1 or 2 RAM sticks? if 2 then remove them again and swap them around.
stick one in dimm2 and stick 2 in dimm 1.
If you only have one stick then beg or borrow another stick and try it. If all fails you may have developed a mobo problem.
Regards mistyman
Oct 13, 2007 | Compaq d530 CMT PC Desktop
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
