It"s a maytag top load
  • Larry Harris Dec 30, 2010
    I have A maytag top load washer it will fill with water but want wash goes thouth that cycle draines the water fill again want wash drain an spin then turns off.
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number on the machine?
Posted on Dec 31, 2010
  • 43,501 Answers
Check the motor for power when it should be washing...if there is power there then the motor has lost the ability to turn the one direction... the spin goes the other direction...
If there is no power to the motor then the timer/control is bad and it is not sending power to turn the motor...
Replace your parts accordingly...
heatman101
Posted on Dec 30, 2010
Maytag top loader not working
check water supplys okay and lid closed properly to activate lid switch....
Jul 01, 2012 | Washing Machines
Maytag washer model # MAVT236AWW Ser # 11354800GV This thing will not wash or drain or spin. It will fill up with water. I have smelled a burning smell and smoke filled the back room. To me it has...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 20, 2011 | Maytag Washing Machines
My washer was filled with water but wont spin.. makes little noise but no spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Jan 18, 2011 | Maytag PAV5157A Top Load Washer
Maytag MHW2000AWW will fill with water but not spin
heatman101
Sep 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer doesn't work and the water doesn't come on.
Check the water valves work, fill then wash, then drain then spin, if it doesn't fill it won't wash
Nov 12, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
May 17, 2009 | Washing Machines
Maytag top loading washer won't agate. Instead it fills with water and spins, then drains, fills for the rinse and spins. Thanks Bill
Open your control panel.
Disconnect then reconnect your timer wiring harness.
If this does not correct the problem,replace the timer.
Feb 25, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer
Check to make sure your drain hose has a loop at least as high as washer top.  If the drain hose is not looped higher than tub water will continue to drain and it won't stop filling.  If it doesn'y reach the correct fill level it won't agitate.
Oct 29, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
