Question about LG Dryers
Need a lent screen - LG Dryers
  • LG Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Posted on Dec 31, 2010
Where is the lent trap on the estate washer
If it is like my Kenmore washer, you need to remove the front panel at the base of the machine. You should see the trap front and center, caution when you open the trap there will be water coming out. good luck
Sep 06, 2014 | Estate Washing Machines
Dryer beeps every few seconds before the load is done drying
You timmer is going bad most like you need a new timer
Jan 14, 2012 | Whirlpool duet Washing Machines
My dishwasher wont drain.. water stays in the tank..
When you run a dishwasher, there is usually food particles left over from a cycle. First thing is to check the lent screen. The lent screen is located on the bottom usually in the back of the dishwasher. If you want to put some gloves on and remove it and turn on the drain cycle on your dishwasher. If that doesn't do it turn off the power to the dishwasher by the breaker box, and check your hoses inside the dishwasher.
May 11, 2011 | Maytag 24 in. Built-In Dishwasher w/...
Minha cam digital Kodak aparece com código de
O problema ? que a lente se tornou presa no cano. Existem algumas solu??es DIY, voc? pode tentar, mas a probabilidade ? que voc? ter? de obt?-lo fixo por um profissional. Use estas por conta e risco, pois pode prejudicar ainda mais a c?mera:
Em primeiro lugar, tente conectar o adaptador de corrente alternada ou cabo USB.
Tente segurar o bot?o do obturador quando ligar a c?mera.
Olhe para a lente, e se alguns dos "c?rculos" a lente est? desalinhada ou n?o conc?ntrica e tente mexer-lo (mantendo lente da c?mera para baixo).
Tente gentilmente empurrando ou puxando a lente quando ela se estende, mas isso ? arriscado, pois pode causar a lente para escapar de seu sistema de orienta??o.
Outra maneira de fazer isso ? colocar a lente da c?mera sobre uma superf?cie dura e, em seguida, poder-se. Tenha certeza de usar um pano macio ou algo similar para n?o arranhar sua lente ou inv?lucro. Vamos empurrar a lente da c?mera para cima e para baixo algumas vezes e ?s vezes a resist?ncia do pequeno fornecida pela c?mera ? suficiente para fazer as coisas andarem novamente.
Tente acertar a c?mera perto da lente no corpo com o tecido mole na palma da sua m?o.
Fora isso, eu tomaria a c?mara a um centro de repara??o de uma avalia??o para ver se ele custaria mais do que a repara??o para substituir a c?mera.
Visite aqui: LENSS ERROR
Boa suerte.
Dec 31, 2010 | Kodak EasyShare V610 Digital Camera
Broken outer screen on my toshiba progection
Manufacturer Toshiba Part Number 23311898 Description SCREEN FRESNEL 42H Manufacturer Toshiba Part Number 23311897 Description SCREEN LENT 42H81 Manufacturer Toshiba Part Number 23311863 Description SCREEN PROTECTOR
Nov 13, 2009 | Toshiba 42H81 42" Rear Projection...
Clean filter light flashing and making more noise than normal
There is an element where the lent screen is. It is the dry sensor. Check to see if it has lent on it.
Jun 27, 2009 | LG DLE5932W Electric Dryer
Focus error appear on screen
i just help the zoom to get out with a thin screwdriver and now the "ZOOM ERROR" message disappear, but i have another problem. The camera does not show the target (what to shoot) on the screen. It shows ONLY pictures on card.
I tried everything, but the target i choose does not appear on the screen.
Dec 09, 2008 | Cameras
After a few loads the dryer shuts off before the time cycle is finished. The lent screen is clean and the lent exhaust is clear. My dryer is whirlpool mod. GEQ9858JQ8.
the motor is over heating cutting out on the thermal overload inside the motor replace the motor 279787 part number
Apr 17, 2008 | Dryers
Dryers Logo
37 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
