Question about HP Photosmart 4180 All-in-One Printer
Carriage jam The paper feeds into the printer and
Carriage jam The paper feeds into the printer and then stops half way out screen says carriage jam. I open and unjam then the paper feeds and it gets stuck in the back....
    Genius:
  • HP Expert
  • 1,325 Answers
I had a paper jam. I pulled the paper out. Now it will not print saying that the carriage is jammed, it says to open and unjam carriage but it is all the way to the right and I can not unjam. How do I get...
Try reset your printer by following this procedure to reset it,
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold # and 6 keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
Or
. Turn the printer power off.
2. Press and hold GO.
3. Turn the printer power back on and continue to hold GO until the Attention light turns on.
4. Release GO.
5. The device lights will begin cycling from front to rear. The cold-reset process will run until completion and the device will go to the ready state. This should fix the problem..
Sep 16, 2011 | HP PSC 750 All-In-One InkJet Printer
Turn printer on ERROR comes on screen. Carriage jam Open Door clear carriage jam and then press OK to continue. I do this nothing found in carriage close Error comes up the same?? What to do?
Joe,
Pull all of the paper out of the machine. Look for a wadded up small piece of paper. After you look for it. Examine the door slide tray where paper is stored. Look at take-up rollers... make sure slide drawers close easily...examine door where print cartridge is....Look at (on side) feed tray...Paper feed tray... If you fail get a flashlight and take another look it does not have to be a very large piece of paper...good luck
Nov 26, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Paper jammed
Hi Good day!!!
Here are some steps to remove paper jam
1. Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands on the metal tools inside the chassis.
2. Pin down the exact location of the jam. The three hot spots for a jam are before a sheet completely leaves the paper tray, between the feed tray and the print carriage or between the print carriage and the output tray.
3. Take off the front paper tray. If the sheet jammed around here, you should be able to see most of the paper.
4. Pull on the sheet with both hands and steady pressure. Don't tug too quickly. You might rip the paper, leaving a chunk of it deeper in the machine.
5. Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Use the carriage access door to get at a jam further inside. You may need to move the print carriage out of your way to get at the jam.
7. Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Thank you for using FixYa
Don't forget to vote thanks!!!
Nov 05, 2010 | Epson WorkForce 600 All-In-One InkJet...
Keeps saying paper jam and paper goes half way through
hi
1. 1 Switch off the printer and disconnect the powersupply. Allow any residual charge to fade away before putting your hands ormetal tools inside the chassis. 2. Step 2 Pin down the exact location of the jam. Thethree hot spots for a jam are the paper tray, anywhere between the feed trayand the print carriage, or between the print carriage and the output tray. 3. Step 3 Take off the front paper tray if the sheet gotstuck while it was still in the front area of the printer. If the sheet jammedhere, you should be able to see most of the paper. 4. Step 4 Pull on the sheet with both hands and steadypressure. Do not tug as you might rip the paper, leaving a chunk of it deeperin the machine. 5. Step 5 Open the back panel to reach paper jammedbetween the feed tray area and the print carriage of the all-in-one printer.Carefully remove the jammed paper from the machine. 6. Step 6 Use the carriage access door to reach a jamfurther inside the all-in-one printer. You may need to move the print carriageout of your way to clear the jam. 7. Step 7 Return any access panels to their closed andlocked positions. Plug your printer back in and flip the power switch.
Oct 31, 2010 | HP PSC 2355v All-In-One InkJet Printer
Error message carriage jam and/or paper jam
Often a carriage jam is caused by a paper jam. If you're getting a carriage jam message and a paper jam message, this video should help.
utube.png You-Tube video "wPjahOY5CDo" placeholder
Nov 21, 2009 | HP Photosmart C6380 All-In-One InkJet...
Keeps screwing up paper and e-90 comes up on
An error E-90 means that something is stopping the ink carriage from moving its full extent. Open the printer top and check that the ink carriage lid is firmly locked down, check along the path of the carriage for any foreign/loose objects. If the carriage moves when you switch it on, pull out the power cable when it is across to the left and check for loose gears or foreign objects in the gears on R/H side. As you are also getting screwed up paper I believe that there is something lodged in the paper path. To check this make sure the print carriage is parked fully right and out of the way. You will need an A4 (approx) sized piece of stiff cardboard such as the backing from an A4 note pad. Insert this into the paper feed locating it between the feed rollers on the R/H side. Then push quite firmly to overcome the spring pressure, when you feel it push through about a half inch stop and open the printer to see what is being pushed through. Push the card fully through and retrieve the foreign object (I have found everything from paperclips, curtain hooks and even a golf tee!). Push the card through fully and out of the printer. Always remove paper jams etc, in the direction of the paper feed whenever possible as pulling anything backwards can dislodge or break the sensor flags.
Hope this helps. Please take a moment to rate this solution, thanks.
Jul 09, 2009 | Epson Stylus RX560 All-In-One InkJet Photo...
PAPER JAM:
OK, this is going to take a bit of nerve but it has worked every time (dozens) I have seen this problem. Switch off the printer and unplug, make sure the ink carriage is parked. Get a stiff piece of A4 card such as the backing from an A4 notepad. Place the card in the paper feed and push through quite firmly for the first half inch then open the scanner unit and watch the rollers inside the printer as you push it further. It should push out anything blocking the paper path. Push the card fully through in the direction of paper feed, never try to pull paper jams or anything else out backwards if it can at all be helped.
Please take a moment to rate this solution. Thanks.
Mar 18, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Paper wont feed then says paper jam
Got rid of my problem!
In an act of despair I started to poke around the inside of the printer with a wooden match. Especially I found a small black lever mentioned on a Dell web site (general paper jam help page) that could be pressed a little. It is placed just a little bit right of center behind the carriage and just above the roll that feeds the paper beneath the printer heads. I'm not sure if this was what finally did it, but now the paper jam problem has gone away.
Another thing I noticed is that my carriage is now moving to center when I open the top. When the paper jam error was present it always moved to the far left (so I could remove any jammed paper, I suspect)
Apr 08, 2008 | Dell 924 All-in-One InkJet Printer
HP Photosmart 4180 All-in-One Printer Logo
295 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
