Question about Whirlpool Duet GHW9150P Front Load Washer
Im getting error code f11 8 mins in to the wash and the load finished
    Novelist:
  • 99 Answers
Hi, F11 code means the CCU circuit board and the motor control circuit board are losing communication. Most often it's the CCU circuit board. There are cold solder joints where the spade connectors and relays are attached to the circuit board (poor quality control by whirlpool) the CCU is at the top of the machine in a plastic case, it's easier to just remove the entire case. If you can handle resoldering those points that's great, if not just print out this response and take the board into a good appliance repair shop, they should be able to help you out. Good Luck.
Posted on Dec 31, 2010
Washer stops cycleing
First are you sure the error code is 'LE' and not 'tE' which looks very similar. The LE is usually the motor position sensor. Common on older washers. Easy fix. Under $20 part. The tE error is usually the thermistor. Inexpensive part about $6, but can be more complicated to get to. Ad a comment to your question and my answer with error code and I'll reply with more info if needed.
Jun 24, 2017 | LG WT4870CW 4.5 Cu. Ft. Top Load White...
Stops during wash cycle for about 1 min then starts again, stops, then starts, stops then starts. Does this several times before finally finishing the cycle.
Are you getting an error code? If not, Try unplugging it for 20 minutes.
Then plug it back in, The ccu might have to be reset.
Jan 27, 2013 | Washing Machines
Wont finish the load
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
Jul 21, 2010 | LG WM2701HV Washer
Panel is switching back between 6 and F at the end of the cylce
http://www.applianceblog.com/mainforums/attachments/sears-kenmore/639d1187051794-he2-error-codes-he2-error-codes.pdf
Above is a link for the error codes and what they mean.
http://www.servicematters.com/maytag_library/docs/16007803.pdf
Above is your service and repair manual. with troubleshooting steps, to isolate your issue.
Jun 22, 2010 | Kenmore HE2 Plus Front Load Washer
Whirlpool front load washer getting an error code of "F6"
f 06 is a in issue with the motor control board, check the wiring harness attached to the board.
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
HC code is on the front when it finish washing the clothes
This HC error code will appear at the end of the wash cycle to indicate that the hot and cold water inlet hoses are switched. If the hoses are not switched it could indicate a problem with the Electronic Control Board. You can try to rest the washer by unplugging or flipping the breaker to the washer fo 2-5 min. Restore power to the washer and try running a short cycle. This will help clear any irregularities that the control board may have encountered.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$#@
Nov 14, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Long wash cycles
WHEN YOU WASH IS THE WATER HOT ENOUGH IN A REASONABLE TIME? ALSO DOES THE WASHER SENCE THE AMOUNT OF SOAP THATS IN THE TUB. IT COULD BE GIVING ADDITIONAL RINCES TO REDUCE THE SOAP CONTENT.(TRY WITH NO SOAP IN SYSTEM AND SEE IF TIME IS SHORTER)
Sep 18, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
