Question about Dell Dimension E310 PC Desktop
My Dell keyboard caps lock is stuck in a Word Document.
  • 50 Answers
USE ANOTHER KEY BOARD TO SEE IF IT'S THE PROBLEM OR REINSTALL WORD BUT SAVE EVERYTHING FIRST TO A USB DRIVE
Posted on Oct 11, 2011
How to tell if caps lock is on
Some keyboards will have a light that goes on when caps lock is turned on
Unlock the Caps on Computers
The All-Caps or "Caps Lock" function causes all letters to appear as capital letters when typing into word processing documents, emails or other files.
This is convenient when needing to type numerous capital letters or All-Caps phrases, as you do not have to hold down the "Shift" button with one finger as you type the words.
When All-Caps is stuck and does not respond to the "Caps Lock" keyboard button, a simple procedure overrides and shuts down the function.
Open a word processing program.
Press the "Caps Lock" button located on the left side of the keyboard to turn Caps Lock off. Type inside the document.
If lower case letters appear in the document, Caps are successfully unlocked.
Proceed if the text is in All-Caps.
Hold down "Shift" on the keyboard. Press the letter "P."
A lower case "p" appears in the document. Release the "Shift" button.
Type the phrase "rint" directly after the lower case "P." The word "pRINT" is now in the document, and the document cursor is after the phrase's "T."
Press "Enter" on the keyboard.
The cursor goes down one line and "pRINT" becomes "Print." The "Caps Lock" function is turned off.
Restart the computer to save the setting.
Enable the Caps Lock Key
The "Caps Lock" key is loved by some and disliked by others.
The key turns all letters into capitals as you type.
While this feature is useful in some situations, a more common occurrence is that the key is accidentally hit and all the text typed is capitalized.
The person typing must then delete the capitalized type and rehit the key to turn off "Caps Lock."
If the "Caps Lock" key needs to be enabled, it indicates that someone has disabled or remapped the key.
If a user wanted to, the "Caps Lock" key can be disabled and enabled through the registry or remapped through the control panels.
Updating the registry for the keyboard will enable the "Caps Lock" key.
Open the Notepad program.
Type the following:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout]
"Scancode Map"=-
Select "Save As" from the "File" drop down menu.
Navigate to the computer desktop as the save file location and choose "All Files" from the "Save as type:" drop-down menu at the bottom of the Save As window.
Type "enable.reg" without quotes in the "File name:" field and click "Save."
Minimize all open windows to view the desktop.
Double-click on the "enable.reg" file. A box will pop up asking if you are sure you want to run the file. Select "Run" or "Yes" and then click "Yes" for the Registry Editor warning.
Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled.
Manually Update the Registry
Click the "Start" menu, type "regedit" without the quotes and press "Enter." In older versions of Windows, Click the "Start" menu, select "Run," type "regedit" without the quotes and press "Enter." This will launch the Registry Editor.
Navigate to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout" to view the settings.
Right click on the "Scancode Map" setting and choose "Delete." Click "Yes" to confirm the deletion.
Disable the Caps Lock Key in Windows
Your computer's Caps Lock key has likely only collected dust since you first brought the machine home.
The Caps Lock key is beneficial if you want to type a long string of words entirely in capital letters, but this form of typing is not needed often.
Consider disabling your Caps Lock key if you do not need it, or if you are tired of hitting the key accidentally while rapidly typing.
Restart your computer before beginning the process of disabling your Caps Lock key.
Download the registry file necessary to disable your Caps Lock key.
You have the option to disable your Caps Lock key or change the key to a number of different keystrokes.
For example, you may choose to use the "ChangeCapsToShift" registry file if you want the Caps Lock button to function as a shift key.
Double-click the registry file you have downloaded.
A prompt will appear on your screen asking if you would like to add the registry file to your computer's registry.
Select "Yes" to install the registry file.
Restart your computer, once again, to complete the registry change.
Upon reboot, your Caps Lock key will no longer function as a traditional Caps Lock key.
Disable the Caps Lock Key on a Computer
The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately.
When this mistake occurs, usually you must correct some text errors and your time is wasted.
If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key.
Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window.
Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control".
Double click on "Keyboard Layout" to open the folder.
Open the "Edit" menu and choose "New" then "Binary Value".
A new file will appear on the right side of your screen with the file name highlighted.
Type "Scancode Map" for the new file name.
Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button.
Close the "Registry Editor" by selecting "Exit" from the "File" menu.
Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key.
Hope this helps
Nov 05, 2012 | Computers & Internet
Dell Studio 1737 with Back lit keyboard but Cap Lock Doesn't Light
Dear Janice,
The light under the Caps key must have burned out. Take your laptop to a Dell service center and get it repaired.
Oct 19, 2012 | Dell Studio 1737 (Studio 1737-RubyR) PC...
TURN OFF CAPS LOCK DELL SK-8185
Click on the Caps Lock button ;) if that wont work, then for lower case just use shift and the wanted letter
Aug 04, 2012 | Dell y530k - Slim Black Usb 104-key...
How do I get my mouse to not choose multiple icons when I click on one? Also, when I try to type a .com address, the keys are on cap lock even though I don't have the cap lock key on.
Sounds like you have a button sticking on your keyboard. Turn the keyboard upside down and gently tap on it to remove any foreign particles also get some electronic compressed dusting air. Or buy a new keyboard.
Mar 13, 2011 | Dell SK-8125 Keyboard
I have the dell wireless Y-RBP-DEL4 KEYBOARD is there any warning light on it to say i have caps lock on
Unfortunately there are no lights on the keyboard, which is ridiculous if you ask me!
You can however download a driver from the Dell website that will add a Cap Lock, Num Lock and Scroll Lock notification to the taskbar area.
You can get the driver here.
Hope this helps,
Matt
May 01, 2010 | Dell Keyboard/Mouse
Missing letters while typing on new dell laptop
Dollars and cents dictate just replace the keyboard.
Sep 16, 2009 | Dell 0Y3740 Keyboard
MY CAPS LOCK IS STUCK, AND WILLNOT GO BACK TO REGULAR
Just had this happen on a K800 wireless keyboard. Went into keyboard settings and *enabled* the caps lock key, turned off caps lock, then *disabled* the caps lock key again. Hope it helps
Jun 21, 2008 | Logitech LX 300 Keyboard/Mouse
Caps Lock issue
restart the computer
Feb 13, 2008 | Dell Latitude D600 Notebook
Dell Dimension E310 PC Desktop Logo
124 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
