Question about Sony KP-57WS510 57" Rear Projection HDTV
Pico fuse what kind of pico fuse need sony tv model kp57ws510?
  • Sony Master
  • 8,617 Answers
They are usually 3.5 amp picos depending on what circuit they are in. If you go to this link and leave a email with your model number and pico number such as PS321 they will tell you which rating you need and they have all picos for sonys instock.
http://servicemanuals.vstore.ca/
Posted on Jul 07, 2008
Kd-46wt500 sony big screen colors dont line up is projectors goin out picture on tv is blurry pic looks stretched out as well
Can you verify the model number and see if its A KP46WT500 model? If so chances are just the convergence Ics ( stk 392-560 ) and pico fuses are the problem. There are 6 3.5 amp pico fuses directly beneath the heat sink fins on the D board ( where the Convergence ICs are located) Check those six pico fuses and also two 5 amp picos on the G board ( where power cord plugs in) if any of the picos on either board are open then the Convergence ICs will require replacement.
Sep 26, 2011 | Sony KP-46WT500 46" Rear Projection...
I have a sony widescreen projection tv model KP51WS510. the picture has shadows and shows double.
Thats caused by failed convergence ICs your model uses the STK392-560 ICs you will also need several 3.5 amp pico fuses and a couple of 5 amp pico fuses to do the repair. The Sony Type 1 convergence repair kit is the correct kit for your model. It contains the parts and the CD with repair instructions. The kits available from www.tvrepairworld.com
Aug 09, 2011 | Sony KP-51WS510 51" Rear Projection...
I have a similar problem as described as a convergence problem with my Sony KP-53HS30 TV. Can you elaborate further on the solution to repair. Which IC and protector fuses do I replace? Thank you.
Your model uses two STK392-560 Convergence ICs. also there are 6 pico fuses on the D board and two pico fuses on the G board which may need replacement also. The Sony type 1 convergence repair kit from www.tvrepairworld.com contains the IC's pico fuses and a few resistors plus instructions on CD of how to do the repair.
Aug 08, 2010 | Sony KP-53HS30 53" Rear Projection...
Sony model kp57ws510 rear projection. convergence problem. convergence button on front of tv does nothing
There are a set of convergece chips that need to be replaced. If they have been replaced and you still have the convergence problem you will need to change ceramic fuses in the power supply or on the board where the STK chips are located
Mar 04, 2010 | Televison & Video
My Sony Big screen,57in.,Model #KP57WS510,the age-Feb.2004. I turned it on,it looks like i need a pair of 3-D glasses to watch it.Red and green outline the people or objects.Not so much in the...
The following convergence repair kit also applies to your model sony The kit contains the two convergence ICs all six pico fuses and four of the 4.7 ohm resistors. It also comes with free installation instructions and free tech support so you can do the repair yourself.
http://servicemanuals.vstore.ca/product_info.php/pName/sony-kp46wt510-convergence-repair-kit/cName/convergence-repair-kits/osCsid/e28ca8f8240833facd92d8890ef7e2b2
Jan 19, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Sony projection tv convergence issue
You will need two STK392-560 Convergence ICs and you will also need two of the 3.5 amp pico fuses as Sonys will always blow at least two of the Pico fuses. You can get replacement ICs and Pico fuses at the fiollowing link and they provide free instalation instructions. Heres the link.
Aug 10, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony kp57ws510
you need to replace both convergence ICs they are STK392-560 and you will also need a couple 3.5amp pico fuses and a couple 4.7 ohm 1/2watt resistors. You can get replacement parts at the following link and they provide free instalation instructions and free online tech support to help you with the instalation process. Heres the link.
Aug 07, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Flashing light
Video output IC on either the CR, CG or CB pcb boards is most likely the problem or the A board is defective. I would try the video output on the CR, CG and CB boards first.
Jul 16, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Convergence
there are a series of 4.7 ohm 1/2 watt resistors all in a row under the fins of the ICs. Check them they have to have one side unsolderd to check them. There are also 6 yellow pico fuses in that line of resistors that need to be checked as well.
Jul 05, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
There is a blinking light in front of my tv blinks 8times turns off for 4seconds and starts again
Check C514 next to flyback xformer.If shorted,burnt,replace
with part # 1-161-754-00 102K / 3KV capacitor.May also have open
2 amp pico fuse in power supply......T
Oct 25, 2007 | Sony KP-53S70 53" Rear Projection...
Sony KP-57WS510 57" Rear Projection HDTV Logo
181 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
