Question about Behringer Sx2442fx Eurodesk 24channel Mixer New
I have a Behringer SL2442FX-Pro and while the mixer itself still works fine and the digital effects controls and displays all appear normal, the actual effects are not functioning. When I choose an effect, what I actually get is a slowly pulsating noise. The only effect that seems to function in-spite of the noise is the 1 kHz test tone. Of course, when I turn all the effects level pots down I'm back to a perfectly normally functioning mixer board. Has anyone seen this problem before and does it have a common culprit? I should tell you that I'm an electronic technician myself, though mixer boards are not my specialty and I don't have a schematic. So, you can get pretty technical with me and I'll understand what you're talking about. Thanks!
  • Behringer Master
  • 5,603 Answers
First thing to check is the power supply voltages. I have seen a Behringer effect module that had low 5 volts and it continually reset itself.
Schematics: http://elektrotanya.com/behringer_sl2442.pdf/download.html
Typical Behringer mixer should have same DSP as yours and similar or identical power supply
http://elektrotanya.com/behringer_ub1204fx_pro.pdf/download.html
Posted on Dec 30, 2010
I imported a behringer SX3242FX today and it was working fine for about an hour suddenly I felt the digital effect that I selected( Delay ) has lost from the microphones and voices became dry.. Then I...
Is the number on the effects display still flashing? Can you select effects or is that section dead now? I've had occasions with my Behringer mixers where a bad ground or otherwise improper power supply seems to cause issues with the effects section but the board seems otherwise functional. It has definitely had me scratching my head a few times and is worth investigating.
Aug 17, 2012 | Behringer Sx3242fx Eurodesk 32-channel...
My behringer djx700 does not work properly 2 use the effects u have 2 plug an rca into the booth output on the back but then nothin else works and i can only here my left turntable in my head phones there...
Semiconductor things involved with sending the booth signals into the mains are:
IC2 which is a 5241 gate controlled by MIC_ON.
IC30 4580 summer for MIC and BOOTH.
IC53 4580 inversion and gain control.
IC39 4580 MAIN output drivers.
May 13, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
LEVEL POT ON A BEHRINGER EURORACK MX 602A-BAD
It appears that both these use a 50K pot in the identical circuit and it is UNLIKELY they re-engineered very much so it is likely they use the same pot.
Behringer parts service should be able to tell you.
Apr 28, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
How can i open the music file for my digital dj pro mixer
I don't know what you are trying to do. But your mixers needs analog inputs such as cd players or turntables.
Feb 12, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
How do I connect my behringer mixer desk to
The first thing to do is to swap teh L & R INPUTS to the amplifier. Did the speaker that works change?
If som the problem is with the setting of the mixer deck. If it did not change, then the problem is with your speaker wiring of the dead speaker, the speaker itself, or that side of the amp.
If the working speaker did swap, that means problem is with the mixer. The question then becomes how are you connecting to the mixer. You should be using TRS 1/4 inch connectors or preferably XLR from the MAIN outputs. These are balanced outputs connections.
If the inputs are from one of the mono inputs, the PAN control for that channel will control how much goes to each speaker... If at center, both will get same signal.
There are so many possibilities that I can't evaluate them until you try the test to find if it is problem of the amp or the mixer that I have given you to try.
Dec 28, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
My effects on the behringer djx 700 dj mixer stop working how
This is a wild educated guess.
I repaired a Behringer guitar amp that had a DSP effects in it (BX1200 I believe).
The effects were on a seperate board and the board had its own 5 volt power supply. The filter capacitor for the 5 volt power on the board was UNDERSIZED and it had degraded causing the 5 volts to drop out of regulation, dipping to 4 volts. This caused the DSP effects to fail.
YOUR device MAY use the same DSP OR design.
Check the 5 volt power with an OSCILLOSCOPE to look for dips below the 5 volt operating point that occur at 120 HZ.
Oct 19, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
I need a wiring diagram for the main circuit board in a behringer djx700 mixer
Behringer only gives schematics to their authorized service people.
I find I can usually trace stuff out as needed as the mixers are a very symetrical repeating circuitry.
Most components are readily available from other sources.
Aug 26, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Faulty effects behringer djx700
The effects on the PMP powered mixers flash UNTIL you push in on the selector knob. This way you can dial in the next effect number and then push in later to activate when you want it... Could yours possibly be the same technique?
May 16, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Effects button not working!!!!
Most likely the fuse for the effects circuit has blown, which happens sometimes on mixers with built in effects.
You'll have to open the mixer as the fuse will be inside the mixer on a circuit board (look around inside where the effects part of the mixer is) replace it with an identically rated working fuse and you should be done.
Apr 24, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Behringer Sx2442fx Eurodesk 24channel Mixer New Logo
963 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
