Question about Cameras
When i turn camera on it shows card locked and i go to the menu option and that only gives me a few options to choose from. How can I fix the problem
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
Take the memory card out of the camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Posted on Dec 30, 2010
How to fix hdd format error?
on the menu screen push the "show other" option then scroll down "manage media" scroll down you can see media format in this menu, push this option there will show two options 1, HDD 2nd one is memory card here you select the HDD the screen will show "Format?" All data will be deleted. here you give "yes" another dialogue will appear "are you sure?" here you give yes, finally will show executing then press ok.
Jan 05, 2016 | Sony Handycam DCR-SR100 Camcorder
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
Camera says out of memory won't let me take pictures. i cleared all the pictures out and still cant take pictures. What do you think the problem is?
I'm assuming you are trying to use an SD card in your camera and not the internal memory. I suggest you format the memory card if you are sure there is nothing on the card. Formatting the memory card deletes everything on the card and sets it up with a file system that your camera recognizes. Follow these steps to format your memory card using your camera. 1. Turn camera off 2. Insert memory card 3. Turn camera on 4. When the memory card is inserted in the camera, the [Format card] option appears in the setup menu 5. Choose Format to format the entire card. Don't choose Quick Format 6. Wait until your card is formatted
After formatting your memory card, try turning your camera off and on and you should now be able to take pictures to your memory card.
P.S. If you remove your memory card you can choose Format Memory from the setup menu to format the camera's built-in internal memory
Sep 01, 2011 | Nikon COOLPIX L5 Digital Camera
How to format a sd card
Hello and welcome to FixYa!
1- If you want to format it by keeping in digital camera then follow the given procedure:-
  • Put the SD card into your digital camera and then turn the power on. Press the button on your camera to bring up your recently shot photographs.
  • Press the "Menu" or "OK" button on the camera to bring up the photograph options. Choose the option that says either "Setup" or "Options."
  • Scroll over to the "Format" option and hit "OK." Choose the option to set the file format to "FAT16."
2- You can also format it by connecting it to computer through card reader, For it follow the given procedure:-
  • Turn on your computer and put the SD card into the card reader slot on the front of your computer or the external card reader attached to a USB port. Wait to see if your operating system automatically opens a window prompting you for information. Click on the option to "Open a folder to view files" if the window pops up.
  • Click on the "Start" button if your operating system does not automatically prompt you to open a folder. Choose the "My Computer" option to bring up a new window.
  • Right-click on the drive bay for your card reader, and then choose the option that says "Reformat" from the pop-up menu. Click on the option to set the formatting to "FAT16" if you receive a separate pop up window asking you which file system to set the card to.
You can also get help from the given video, if you choose second option
If you think this solution helps you then your token of appreciation in the form of Rating as Four Thumbs and a testimonial will be esteemed.
Thanks you for using FixYa!
Apr 09, 2011 | Vivitar ViviCam 3720 Digital Camera
HOW TO FORMAT SD CARD
other way to format is Put the SD card in card reader and follow these steps:-
Right-click on the drive bay for your card reader, and then choose the option that says "format" from the pop-up menu. Click on the option to set the formatting to "FAT16" if you receive a separate pop up window asking you which file system to set the card to.
good luck
hope it helps if so do rate the solution
Nov 29, 2010 | Kodak EasyShare DX4350 Digital Camera
I have a Polaroid a330 and just bought a 2GB sd card. The manual says to format a card before using and gives instructions. However, when I insert the card and turn on the camera, the screen shows "card...
first try to see if the card is not locked from the side ..It has a little button that locks it ...after that insert the card into a computer with a card reader ..and format it in Fat mode...by opening my computer folder...right click on the removable storage device ...and choose format ...when it opens choose Fat ..and quick format ..than OK ..this will format it for the first time ..and after that isert it in the camera and see if it is seen ..
if the format card is not available now..(to format it in the camera again and be sure it is the right way and make the folders fro storage ) ..
goto storage feature in the main menu ..and choose to store in teh card ..in tis moment will prompt you to format ...or ..just choose a picture from the camera memory in the view mode..and options ..and try to move it in the card ..if it is not proper formatted will ask you to format it ..and give you the possibility to make it right the way by asking you if you want to format it now...choose ok..and that's all..But I suspect that if you unlock it ..and format it in a computer will work like a charm ...
May 30, 2010 | Polaroid a330 Digital Camera
How do you transfer internal memory to memory card
-Turn On camera
-Press menu button and look for setup menu
-Under setup menu Look for the word image storage then Press Ok button
-Under image storage choose Internal memory then press Ok Button
-Now if your setting is in internal Memory turn Off camera.
-Turn On camera again
-Press review Button to show pictures in Internal Memory
-Press Menu button then Choose Copy.
-Now under copy wil provide three option copy ALL/PICTURE/Exit
-If you wnat to transffer all the pictures to you memory card choose all if selected picture just choose picture.
-Now your picture in internal memory is in your memory card
_Note; You need to set your iamage storage to Auto again for you to able to access or used the Memory card
Nov 08, 2009 | Kodak EasyShare C653 Digital Camera
Problem with nikon coolpix 8700
Same problem that would not allow me to take a picture without pressing the LOCK button on my Nikon 8700. Here is how I believe I fixed the problem:
Turn the camera ON.
Press MENU button on your camera to bring up the menu.
Scroll down to SET-UP, open the SET-UP menu by scrolling right.
In the SET-UP menu, scroll all the way down to FUNC (Controls) on page 2/3 , open the FUNC (Controls) menu by scrolling right.
You are now presented with 2 options:FUNC and AE-L, AF-L)
Select the FUNC option by right scrolling.
Choose the 2nd option: i.e the mountain, flower and timer icon (distance, macro and self-timer icon) by right scrolling.
Press the MENU button to get out of the menu.
Attempt to take a picture without pressing LOCK.
Should work! Anyways, it worked for me.
Cheers.
Sep 28, 2008 | Nikon Coolpix 8700 Digital Camera
Problem with coolpix 8700 camera
Turn the camera ON.
Cheers.
Memory card
is it for a camera or a phone because if it is for a camera you have to format the memory card by the camera itself you cannot format the data or etc on the computer
Sep 26, 2007 | Samsung Digimax S630 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
