Question about Kenmore Washing Machines
The springs have come off the secure the drum. need picture/ drawing of how they go on. Two of the springs are the same and one is lighter gauge, narrower and longer. any help would be greatly appreciated
  • jkurtz589 Dec 30, 2010
    the only # I can find is 3361901. Hope this helps
    where will I find the model #?
  • Kenmore Master
  • 7,482 Answers
Maybe this website with the photos of the routing of the belt will help
Give it a try.
Please rate me
http://www.applianceaid.com/images/belt-config.JPG
Posted on Dec 31, 2010
  • 1,998 Answers
Could you please send me the model number of your machine and i can send you the schematics of your machine thanks again Rick
Posted on Dec 30, 2010
  • Rick Ead
    Rick Ead Dec 31, 2010
    usually when you open the door will be on a small sticker. That is not the correct model number
    0 results found for model # 3361901
    please message me back the correct model number or if you would like i could pull up any old kenmore elite and use that but i would need your permission first I await your reply thanks again
    Rick
    Rick
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
If you could post your model number I will be able to get you a exploded diagram of the machine.
The FixYa Team
  • Richard Roth
    Richard Roth Dec 31, 2010
    The narrow long one goes on the bottom back base frame to the bottom of the tub on the rear mount. The other short thick one goes either on the left, front, or right side of the tub base assembly depending on which one come off. Here is a diagram.
The drum on my Maytag dyer model MDE308DAYW, will not turn with a heavy load why?
Because of one of the following
The belt has stretched (new belt)
The belt is slipping (new belt and clean drum)
The Spring on the idler pulley tensioner is weak. (Replace spring and lubricate pulley)
Dec 08, 2015 | Dryers
Blew a fuse installing radio. Now, van won't start???
Unfortunately some vehicles use the same fuse for ignition and non- critical electrical devices such as the cigarette lighter, interior lighting trunk opener solenoid etc... It could also be that the power supply wire (red) for the radio is double tapped to a fuse that is dedicated to any number of components and if it is interrupted (blown) the vehicle won't start or even crank. Another possibility is the vehicles computer detected a short or high amp draw and disabled the ignition to avoid fire or further electrical system damage.
The radio/player power line should be properly fuse protected for the highest amperage that the radio/player may draw when it is at maximum wattage, meaning CRANKED UP! It must be connected to the positive cable coming from the battery, safely away from the battery using a properly rated power terminal or power bar that is covered and sealed. It must be securely mounted, grounded and in an area that is clear of anything under the hood . This requires cutting the positive cable, putting connectors on each side of the cut cable and connecting them along with the player and power amplifier power line(s) to the new power terminal.
DO NOT CONNECT THE PLAYER LINE DIRECTLY TO THE BATTERY TERMINAL! The power line wiring for the player at max. volume MUST be of the correct amp rated gauge. You may also need to get a higher amp battery and a higher gauge battery cable to handle the power draw. It is also CRITICAL that every entertainment system component is SECURELY grounded with the right gauge ground wire to metal that is part of the vehicles frame. Failure to do this on a high amp system will toast your vehicles entire electrical system, (very costly mistake) also use dielectric grease on all electrical connections to maintain the integrity of all connections. I may have given you too much info, Good luck!
Oct 29, 2014 | 1993 Volkswagen Eurovan
Replace rear drum brake pads
for the best help in this you really need to invest $25 in a manual for the vehicle. Here are the basic steps:
-jack up & remove wheel
-slide off drum (emergency brake off)
-remove springs between shoes, parking brake cable, pin thru backing plate with spring and twist cap retainer holding shoes to backing plate, draw or take a picture of each side before you disassemble as they may not be the same exactly on both sides
-check drum thickness & condition (have turned by shop or replace as required)
-rotate adjusting stars in all the way so that new assembly is not spread too wide to fit back in drum
-clean all parts well and re-assemble, use brake cleaner spray only! lubricate friction points of backing plate with high temp lithium grease-very small dab only! (important to double-check all the spring positions and levers and mechanical pieces during re-assembly
-brakes will self adjust to correct position while in reverse and applying pedal you may hear them clicking
Sep 30, 2010 | 2000 Dodge Caravan
Diagram for back brakes on a 1995 jeep cherokee sport
Brake Shoes REMOVAL & INSTALLATION Fig. 1: Use a brake cleaner to clean the brake surfaces 86749p23.jpg
Fig. 2: Using a brake tool, remove the return spring from the anchor pin 86749p24.jpg
Fig. 3: Remove the return spring and the adjuster cable guide 86749p25.jpg
Fig. 4: Remove the adjuster cable 86749p26.jpg
Fig. 5: Remove the shoe guide plate 86749p27.jpg
Fig. 6: Disengage the hold-down spring retainers from the hold-down pins 86749p28.jpg
Fig. 7: Remove the hold-down springs and pins 86749p29.jpg
Fig. 8: Pull the shoes apart and then . . . 86749p30.jpg
Fig. 9: . . . remove the parking brake strut and spring 86749p31.jpg
Fig. 10: Remove the shoes from the backing plate 86749p32.jpg
Fig. 11: Disengage the parking brake cable 86749p33.jpg
Fig. 12: Lubricate the shoe contact points — 10 inch drum brake backing plate shown 86749g41.gif
Fig. 13: Adjusting the gauge to fit the brake drum 86749g42.gif
Fig. 14: Adjust the brake shoes to fit the gauge 86749g43.gif
Fig. 15: Adjusting the drum brakes using a brake spoon 86749p35.jpg
CAUTION
Brake shoes may contain asbestos, which has been determined to be a cancer causing agent. Never clean the brake surfaces with compressed air! Avoid inhaling any dust from any brake surface! When cleaning brake surfaces, use a commercially available brake cleaning fluid. NOTE: A brake spring removal tool and a brake adjusting gauge are required for this procedure.
  1. Raise and support the vehicle safely with jackstands.
  2. If the brakes have never been serviced before, the drums will be held on the wheel studs with spring nuts. Remove the spring nuts and discard.
  3. Turn the adjustment starwheel so that the brake shoes are retracted from the brake drum and remove the brake drum.
  4. Install wheel cylinder clamps to retain the wheel cylinder pistons in place and prevent leakage of brake fluid while replacing the shoes.
  5. Remove the U-clip and washer securing the adjuster cable to the parking brake lever.
  6. Remove the adjuster cable, cable guide, adjuster lever and adjuster springs. Remove the return springs with a brake spring remover tool.
  7. Remove the hold-down retainers and springs, then remove the brake shoes. To install:
  8. Clean the backing plate with a brush or cloth. Place a dab of Lubriplate® on each spot where the brake shoes rub on the backing plate. NOTE: Always replace brake linings in axle sets. Never replace linings on one side or just on one wheel.
  9. Thoroughly clean and lubricate the adjuster cable guides, adjuster screw and pivot, parking brake lever and lever pivot pin with multi-purpose grease.
  10. Apply a thin coat of multi-purpose chassis lube to the mounting pads on the backing plate.
  11. Transfer the parking brake actuating lever to the new secondary shoe.
  12. Position the brake shoes on the backing plate, then install the hold-down springs and retainers. Don't forget to engage the parking brake lever with the cable.
  13. Install the parking brake actuating bar and spring between the parking brake lever and primary shoe.
  14. Install the self-adjusting cable, cable guide and upper return springs.
  15. Thoroughly clean the starwheel and lightly lubricate the threads with lithium based grease.
  16. Install the starwheel.
  17. Install the self-adjusting cam and lower spring. A big pair of locking pliers is good for this job.
  18. Check the surface of the brake shoes for any grease that may have gotten on them. If dirty, lightly clean with a piece of sandpaper.
  19. Adjust the brakes, install the brake drum and wheel. Lower the vehicle and test drive.
Aug 17, 2010 | Jeep Cherokee Cars & Trucks
I need a diagram for the rear drum brake for 2002 Ford Ranger
Copy and paste this into your search window: 2002 ford ranger rear brake diagram
You should see four pictures pop up, select the brake parts diagram or the brake picture.
Sep 03, 2009 | 1993 Ford F150 SuperCab
Change drum kyocera fs-3900
open printer front cover and remove drum unite ,two side screw open two side spring **** two side open drum
if you are not possible it then buy a new one unite in your service authorized delar
Aug 27, 2009 | Kyocera FS-3900DN Laser Printer
Change drum brakes
Brake Shoe: Service and Repair
REMOVAL
1. Raise vehicle and remove rear wheels.
2. Remove and discard spring nuts securing drums to wheel studs.
3. Remove brake drums.
NOTE: If drums prove difficult to remove, retract brake shoes. Remove access plug at the rear of backing plate and back off adjuster screw with
brake tool and screwdriver.
4. Remove U-clip and washer securing adjuster cable to parking brake lever.
5. Remove primary and secondary return springs from anchor pin with brake spring pliers.
6. Remove hold-down springs, retainers and pins with standard retaining spring tool.
7. Install spring clamps on wheel cylinders to hold pistons in place.
8. Remove adjuster lever, adjuster screw and spring.
9. Remove adjuster cable and cable guide.
10. Remove brake shoes and parking brake strut.
11. Disconnect cable from parking brake lever and remove lever.
INSTALLATION
1. Clean support plate with brake cleaner.
2. If new drums are being installed, remove protective coating with carburetor cleaner or brake cleaner.
3. Clean and lubricate anchor pin with light coat of Mopar multi-mileage grease.
4. Apply multi-purpose grease to brake shoe contact surfaces of support plate.
5. Lubricate adjuster screw threads and pivot with spray lube.
6. Attach parking brake lever to secondary brake shoe. Use new washer and U-clip to secure lever.
7. Remove wheel cylinder clamps.
8. Attach parking brake cable to lever.
9. Install brake shoes on support plate. Secure shoes with new hold-down springs, pins and retainers.
10. Install parking brake strut and spring.
11. Install guide plate and adjuster cable on anchor pin.
12. Install primary and secondary return springs.
13. Install adjuster cable guide on secondary shoe.
14. Lubricate and assemble adjuster screw.
15. Install adjuster screw, spring and lever and connect to adjuster cable.
16. Adjust shoes to drum.
17. Install wheel/tire assemblies and lower vehicle.
18. Verify firm brake pedal before moving vehicle.
Aug 12, 2009 | 1997 Jeep Cherokee Country
Powering a car amplifier
Bad idea. The wiring leading up to your cigarette lighter is usually a cheap 16 gauge wire. The amplifier will not be able to draw enough amperage through that power source. You could however, use the positive on your cigarette lighter as your remote for the amp. This would be helpful if your cigarette lighter turns off and on with the car.
Jun 24, 2009 | Car Audio & Video
Replace cigar lighter zx2 2001
here's picture. Looks like it unscrews.
Dec 27, 2008 | 2001 Ford Escort ZX2
Broken Spring/Shock for my GLEQ642AS0 Fridigaire Dryer
there are no "suspension shocks/springs" on a dryer, those are usually on your washer. here is hte par number for he washer spring 134144700(which is about 8 inches long and 3/4" in diameter made of heavy gauge steel) youll need (2) and heres the suspension shock absorber number 134564200 its a set of 2, there shold only be 2 on your machine.
Dec 11, 2008 | Frigidaire Dryers
Washing Machines Logo
18 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
