Question about Kenmore 53642 / 53644 Side by Side Refrigerator
I belive the front doors on my unit are plastic made to look like stainless steal. are they replaceable with panals in a black color
    Sergeant:
  • 183 Answers
I believe that is possible, but it would be very costly; and obviously, not an easy task if you intend to do it yourself. You will have to replace both doors entirely in order to achieve the scheme that you would like to create.
Posted on Dec 30, 2010
How do i replace a 2008 chrysler sebring convertible drivers side mirror?
remve teh black plastic cover from the door then remove the door panal undo the conector if its power mirror remove 3 10mm nuts revers for instolaton
Feb 13, 2014 | 2008 Chrysler 300
Need to replace drivers side door lock after someone tried to steal car & broke off a key in the lock
remove inside panal and look inside door. should be clip holding lock in place.
Aug 13, 2012 | 2005 Scion xB
Need to replace stainless steal buners. 17" long
You have to remove the front panel to remove the old burners and install the new ones.
Mar 20, 2011 | Ducane 30400040 Stainless Steel Grill
The lights on the door panel are flashing and the little door compartment keeps peining and closing.
Do you also here a noise inside the frigde ? .any unit that i had do that / had to replace board at rear of fridge. there is a tech sheet at the bottom of the unit behind grill . you can disconnect the water unit if not being used the only thing you would see then is the light in the panal /I have done that if custumer did not want to order board.....good luck
Jan 30, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Can I buy a new front for my ge dishwasher in stainless steelit is currently black
you should take a look at www.applianceart.com they have a variety of stainless, color and design solutions for replacing your dishwasher door panel
May 20, 2010 | GE 24 in. GHDA960K Built-in Dishwasher
How do you remove the cook top on a GE profile model number JSP47SOH2SS
take off the knobs, unscrew the plastic underneath the knobs, take off the plastic cover. unscrew the four metal screws holding the the display panel on. remove the 5 silver screws across the top inside of the plastic cover front and the 2 black ones on the lower left and right sides. remove the to stainless steal stews on the sides of the stove towards the rear top. these should allow you to remove the cover once you unplug the two cables going into the burners.
Feb 26, 2010 | GE Cooktops
Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
Mar 26, 2009 | KitchenAid Microwave Ovens
Front panel color
I have the use&care guide for this unit. It explains how to change the panels - I also notice in ebay that you can order generic stainless ones. I'm going to remove my white panel to install the stainless.
Jul 28, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Discoloration of monogram stainless steel surface
Barmaster makes a stainless steal cleaner obtainable at a retail store like Wal Mart. Follow the cleaning instructions in that you must clean with the grain of the stainless steal surface.
Jun 15, 2008 | Refrigerators
Door won't open.
I TAKE WHAT YOU MEAN IS THAT HE PULLED THE DOOR HANDLE TO HARD WHICH MEANT THAT A PEICE OF THE DOOR MEAHISION HAS BROKEN WHAT YOU CAN DO IS UNPLUG THE MACHINE TAKE THE TOP OFF AND TAKE THE SOAP DRAWER OUT ALTOGETHER RELEASE THE FOUR SCREWS TAKE THE TWO KNOBS OFF THEN LIFT UP THE FRONT PANAL TAKE THE THREE SCREWS FROM ACCROSS THE FRONT AND THREE FROM THE BOTTOM THEN JUST LIFT FORWARD THE FRONT PANAL YOU SHOULD BE ABLE TO GAIN ACCESS TO THE INTERLOCK AND RELEASE THE DOOR REPLACE THE DOOR HANDLE UNIT
Apr 06, 2008 | Hotpoint Aquarius WD63 Front Load...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
