Question about Acer Aspire 5570-2067 Notebook
I forgot my password. I have bought a recovery disk but my laptop doesn't open to it. I was told to F2 and enable F12 and then change to boot the CDROM. I have changed everything I can see in the BIOS and it still boots to the password page. I tried the F8 and when I enter the SAFE MODE, it first lists all the drivers then flips me to the password page. I don't get desktop ICONS. Please help.
    Sniper:
  • 62 Answers
Sounds like your computer is protect with a BIOS password. A BIOS password is a protection measure that can be used to stop someone powering up a computer system or making changes in some of the computers most sensitive areas. That's why the CDROM has been disabled and you can not run the recovery disk.
As a computer enthusiast, it is possible to reset the BIOS password but could be potential fatal to your notebook if you don't know what your doing.
Here is a method to bypass or remove a BIOS password.
Note: Make sure you are working in a static free environment before opening up your computer.
The simplest way to remove a BIOS password is to simply remove the CMOS battery. A computer will remember its settings and keep the time even when it is turned off and unplugged because these parts are powered by small battery inside the computer called a CMOS battery.
If you pull out this battery, the computer will forget alot of its hardware settings, including its BIOS password.
Open up the computer case using a screw driver and locate the flat, circular and metallic CMOS battery. It should look something like the picture above.
There are many different ways to remove a CMOS battery but the most common way on newer computers can be seen in the picture below.
The computer must not be able to get power from anywhere for this to work so make sure its unplugged from everything.
Take out the CMOS battery and wait 10 - 25 minutes before putting it back in. The reason for this wait is because the computer can still store power in its capacitors even though everything is unplugged. The waiting period allows enough time for them to discharge.
Plug everything back in, power up the computer and enter the BIOS again. If everything went well there should be no more password. In some cases, if you get weird error messages during bootup now, you will need to goto "Load BIOS Defaults" in BIOS and save the changes to fix them.
Enjoy, Have Fun and Don't Stress.
Posted on Dec 30, 2010
Bootmgr doesnt work on my toshiba
If by boot mgr you understand the boot menu ..for to select the recovery or boot from disk ,,,it may need to go to bios settinsg by pressing F2 on start and in there look for the HOT KEYS .. and enable the f12 key or f11 after case..
If you are referring to a missing boot file ...and this massage is displayed when you try to ope (boot ) the computer ..it means the boot sequence is corrupted and you need to run the recovery partition or disk ..or reinstall the operation system from a boot-able disk ..
to do so ..go to bios and set the first boot device to be the cd /dvd ..save with F10 and restart with the disk inside..and press any key for to boot from cd ..
For recovery partition just press F12 on start and select the recovery partition for boot device ..or F11 if it has a direct recovery start by this key ..
follow the procedure and choose by the case repair or complete system installing ..
In second case you may loose data in the C drive ..including programs you have installed manually and were not installed by the manufacturer..
so ..if you want the files choose repair ..(either from recovery or from disk )
the command on repair if asked ..is fixboot ..(after you choose the hdd0 /windows)
Dec 08, 2011 | Compaq Presario CQ60-220US PC Laptop
I need to press a key on my keyboard to start factory recovery
Hi and welcome to Fixya!
In order to revert the machine back to its factory setting, you need to have the recovery disk (if you don't have it, call the warranty support line of e-machines so they can provide it to you).
To restore Windows from your recovery discs, you will need to
insert the first backup disc and enable the F12 Boot Menu via the BIOS Setup
Utility.
1 Turn on your computer and insert the first system recovery disc into the
optical disc drive. Restart your computer.
2 During startup when the eMachines logo shows, press the F2 key to enter
BIOS Setup, where you can set system parameters.
3 Use the left and right arrow keys to select the Main submenu.
4 Use the up and down arrow keys to select F12 Boot Menu.
5 Use the F5 or F6 key to change F12 Boot Menu to Enabled.
6 Press the ESC key to enter the Exit submenu, press the ENTER key to Exit
Saving Changes. Press the ENTER key again to select Yes. The system will
reboot.
7 After rebooting, when the eMachines logo shows, press the F12 key to
open the Boot Menu. Here you can select which device to boot from.
8 Use the arrow keys to select the IDE1*, then press the ENTER key. Windows
will be installed from the recovery disc.
9 Insert the second recovery disc when prompted, then follow the onscreen
prompts to complete the restore.
10 Remove the recovery disc from the optical drive once the restore is
complete. Do this before rebooting your computer.
Hope this helps!
Takasashi
Jul 25, 2011 | eMachines E620-5885 Notebook
I'm using a Toshiba Tecra A4 System unit note book and the cdrom is not working. So I tried using an external cdrom drive and the system does not recognize it when I go change the boot priority. Also...
Hi
If you press the F2 key when you start the laptop you may be able to enable the F12 and maybe the D2D option as well in the main menu of the bios then press F10 which is save and exit
this should enable the option to use the disks to recover
or
press the power up key as well as the 0 (zero ) key this may take you into the recovery option
many thanks
Jun 23, 2011 | Toshiba TECRA A4 9/1.6 Notebook
While am installing the recovery disks I had this problem error fa12-045d and i had it in disk number 3 ?????
first put disk in then restart computer when prompt push f2 ok now go boot format witn arrows on key board change boot format f12 its already set f2 but its better this way your disc will push f10 save formate start right away now restart push f12 now go under sec. option.
Feb 05, 2011 | Computers & Internet
Notebook only goes to f2 or f12 wont boot
If you can't get passed the F2, F12 then maybe the keys are disabled.. Windows does this sometimes. To release just hit "F".. if that doesn't do the trick then probably drive is corrupt..
You will need to restore using restore disc if you have one.
Jan 23, 2011 | Computers & Internet
Forgot my password
If you forgot windows password, you could create a windows password reset disk on an available computer which could download from Internet. With the disk you could perform windows password recovery. Only four steps:
Step 1: Download Windows Login Recovery from http://www.windowsloginrecovery.com/ and install it on the available computer
Step 2: Run the software and use it to burn a Windows password recovery disk (you could burn the file into the blank CD/DVD or USB flash drive)
Step 3: Change the BIOS setting of your locked computer to make it boot from the CD-ROM (Start computer and press F2 or Delete to enter BISO setup)
Step 4: Boot your locked computer from the created disk and remove the Windows password
It is easy and safe. Hope to help you.
Sep 09, 2010 | Computers & Internet
If you could use another computer which could download from Internet, you can create a windows password recovery disk. Third party windows password recovery software windows login recovery could create such a disk. Only four steps:
Step 1: Download Windows Login Recovery and install it on the available computer
Aug 13, 2010 | Compaq Presario CQ60-204NR Notebook
How can i open vious lock
Forgot windows 7 password?If you could use another computer which could download from Internet, you can create a windows password recovery disk to reset windows 7 password. Third party windows password recovery software windows login recovery could create such a disk. Only four steps:
May 24, 2010 | Acer Aspire 4520-5141 Notebook
My daughter reset the password on her webbook gateway windows xp- called the store i bought it from and they told me i have to format the thing but that all i have to do is hit F12 or someting and it will...
All modern laptops are coming with a hidden recovery partition - this way they no longer have to give you separate recovery disks so they save some bucks.
Press F12 while the laptop starts - you will be presented with an screen with at least 2 options : to boot from the install partition or to access the recovery partition - select the second one. Once you have done that it will be just like you would have used regular recovery disks - follow the instructions on the screen.
Feb 01, 2010 | Computers & Internet
Password help
please elaborate on main password, do you mean windows password? if so: 1) download a password reset disk (I can create one for you and email it) for a small fee. 2) boot laptop, when you see acer power on logo, look on screen for recovery or setup. Most likely F2, F6, F10, or F12 key. That will bring you to an Acer recovery menu. You can restore the laptop to factory, however you will lost all your personal data, and will haver the factory loaded software .
Aug 29, 2007 | Acer Aspire 3680 Laptop
Acer Aspire 5570-2067 Notebook Logo
122 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
