I have a Luxman RV-371 Amp/Receiver and the left side speakers no longer work. It is not the speaker as I have hooked up the speakers to the right side A & B and it worked fine. Also the lights on the unit are no longer working as they once did. The lights for the tuner are fine but the lights for the A & B speakers, volume control, surround indicator lights and other small indicator lights are hardly visible or not at all visible.
SOURCE: Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
Posted on Aug 28, 2007
SOURCE: Pioneer Multichannel Receiver VSX-D508 (including cd player & tape deck)
receiver on the screen displaying power off
Posted on Apr 15, 2008
SOURCE: Pioneer SX-750 Old School Need Help
Check the speaker wire. Sometimes it can just be loose in the terminals and cause distortion. I have had the problem before.
Cheers!
DellMan94
Posted on Jan 12, 2009
easyq
  • 144 Answers
SOURCE: The subwoofer is not working on our Bose 5.1 surround speakers.
First of all you should never indicate speakers as Large unless they can produce below 20Hz (which is very low), otherwise always set your speakers to Small.
Second, did you also indicate in teh setupmenu that you have a subwoofer? Because if all speakers are set to Large some receivers will omit a subwoofer because Large indicates the speakers can reproduce all sounds even below 20Hz.
So walk through your setup menu, say YES when the sub (SFW) is asked for and that should do the trick.
Posted on Apr 17, 2009
SOURCE: Low speaker volume for B Side Speakers...
burn radio output
Posted on May 13, 2009
How do I fix a Luxman stereo receiver that has blown channel to one speaker
I myself would just get another stereo, and not tap wires together
Jan 25, 2015 | Cars & Trucks
I bought a used Luxman Stereo Receiver r113 and now my one Cerwin Vega speaker is crackling and distorted after 10 minutes of playing for the first time
As it's a stereo receiver and you specify one CV speaker, hook the speaker to the other side of the receiver and see if it still has the same problem. If so, hook it to any other audio source you may have. If it has a problem on only one side of the receiver, the receiver has a blown channel. If the speaker distorts on both sides of the receiver and on a separate audio source, the speaker is blown.
Can you have just 2 channel by hooking up to right & left front speaker posts on 5.1 surround
short answer.....no. If you hook more than one speaker up to a single channel, it will lower the impedence and will damage the amp. You can hook up multiple speakers by using a speaker switch box between the speakers and the amp. This will match the impedence and should keep the amp from blowing.
Dec 21, 2014 | Panasonic Technics SA-G76 AV Control...
Right outputs are not working
The right side output transisters are probally fried, End if you hook up both speakers to the left A&B channel you will do worse damage to it buy over loading it, Over it,s (OHM) Capacity, That mostly causes them to over heat end go up in smoke,
Dec 06, 2012 | Pioneer VSX-D606S Receiver
Problems with JBL PSW D110
The speaker level input option is designed for receivers that don't have digital output for the sub, used this way when you set to digital the speaker outputs only get the higher range outputs so won't reproduce much bass. To get the sub to work in digital mode you need to use the digital output (single RCA) from the amp to the sub
Mar 06, 2012 | Audio Players & Recorders
I have a 22 year old Luxman receiver. The left speakers periodically turn off, but seem to recover if I really turn up the receiver volume. I did just reconnect the speaker wires in an attempt to fix the...
To be honest it sounds as though your volume control needs a clean, try to find some switch cleaner (servisol or similar) remove the casing and spray into the volume control from behind the face plate as apposed to from the front. Rotate the volume all the way back and forth several times to clean the tracks, I have used deodorant in the past to achieve the same result but as this will leave a residue, probably not recommended as a permanent fix. Obviously do these actions with the amp switched off, otherwise you will at the very least annoy your neighbours with the loud volume.
Hope this is helpful.
May 06, 2011 | Audio Players & Recorders
I run a sub and two sets of speakers on speaker B of my NAD C740 through a speaker selector. I think there has been a short circuit caused by the + and - wires touching. The left channel no longer works on...
Check that both left and right channels work on A speakers. If they do, the amplifier is probably good and your problem may be outside the amplifier. Try swapping the left and right speaker connections at the back of the amp to see if the problem changes from left to right. this would tell you if the problem is in the amp or out to the speakers. Hope this helps
Jan 04, 2011 | NAD C740 Receiver
Our two left speakers, front and rear will not
Check the connection on the back of the receiver. Check the balance setting, make sure that it's in the middle. Try another mode like stereo, you should hear left and right front only. Also, if your receiver has an on screen menu, check the dB levels for the front and rear left speakers. Good luck!
Dec 09, 2009 | Audio Players & Recorders
Right rear speaker has no audio
Swap the speaker wire from left rear to right rear if the speaker was from RR now work on LR side this prove the speaker OK then you problem in the receiver
If you swap the RR speaker to LR side and still not work then you
have that RR speaker open
Make sure you hook up speakers cable properly and not short from both terminal speakers and receiver the RED and Black poles
Let me know how you go
Nov 28, 2008 | Yamaha HTR-6130 Receiver
327 people viewed this question
 Grubhead
Grubhead
