Question about GE Profile JT912 Electric Single Oven
GE profile light comes on by itself and then get f7
I have a GE profile wall oven. The light comes on by itself. Then goes off by itself. When you try to turn it off the key pad does nothing. You can not turn anything off or on.
Wait a few minutes and you get the f7 alarm.
Right now I can not do anything with it. But wait a few minutes and the light will come back on. Then the f7 again.
Help. The extended warranty expired in May. But I am able to purchase another extended warranty if I hurry as they are giving me a 90 grace period.
Do I get the warranty or can I fix it myself.
I tried putting in the business card in the panel slot but no luck.
  • gary256 Oct 05, 2008
    The G.E. Profile JT912SF2SS Oven has worked great to 2 years. We used the self cleaning function as always and now the oven flashes F7 on the control panel. We press clear and the screen clears, only to be followed by the message low and press start. Your Previous message indicated that a control may be stuck on the control panel, how do you un-stick it or free it up?
    New Friend:
Had the exact same problem. Following instructions from another post on a similar problem I pulled the range. Removed the cover from the top of the electrical connections, pulled the plastic ribbon connector which connects the touch panel with the rest of the electronics. Used an eraser to clean the contact points on the ribbon connector. For some reason there appears to be a fairly heavy deposit of a blackish residue on the contact points... perhaps from the smoke generated during self cleaning. Reinstalled the ribbon connector and so far the problem has not reoccurred.
Posted on Dec 14, 2012
I have the SAME exact problem with my GE Profile Wall oven. I googled the issue and found your posting. It's such a shame that this is a defect with this expensive oven!!
Posted on Aug 13, 2008
    Scholar:
  • 148 Answers
Http://www.repairclinic.com/0078.asp#GE5, this site will give you the code and if your mechanically inclined you can do it your self ,but if the warranty isnt exspensive you might want that,but it is the keypad
Posted on Jul 07, 2008
GE Profile Wall Oven Model#PT916S error code F7
U have a bad clock or your probe inside of oven is bad.I would replace your probe first .it looks like a rod sticking out inside back upper top .f7 I believe means its not reading up temp and getting to hot
Nov 10, 2011 | Ovens
Double wall oven broiler goes off by itself f7 comes on light bottom oven goes on and off by itself whole panel will not operate and then will--serviceman was in said it is the panel ya think??
it could be the touch panel or the computer board,the model number you gave isn't the full model number like 10 different models came up,next time get the number off of the machine not the book,if this is a newer machine you can push the clear/off pad, unplug the touch panel ribbon for a minute or two,if the code comes back it's the computer board,if it doesn't come back it's the touch panel.he must have pulled out the tech sheet and showed you what it said for an f7 error code and if he said it's the panel he must have done this test.
Apr 18, 2011 | GE JRP24 Electric Double Oven
Ge profile wall oven - f7 but I fix with eraser trick - now the clock can't be reset and the 4 does not always work on the keypad
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Aug 28, 2009 | GE Profile Advantium 30" Built-In Single...
F7 error code
Hi
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
check out more detail here
http://www.fixya.com/howto/h155060-dreaded_f7_error
hope this helps
Aug 14, 2009 | GE Profile JTP56 Electric Double Oven
326B1230P001 GE Double oven that displays ?F7? and beeps
I have a GE JT950 double oven that just did the same thing: F7 and beeps like crazy. I found solution on another post: an engineer figured out how to solve the issue without calling GE or buying parts. I just did it tonight and it worked fine. Here is a copy of the post:
Send an e-mail to Charlie at hutchipop@yahoo.com for a fix-it that you can try. He explains a possible solution fully with his 'The Dreaded "F7" Error' solution. I actually found his information on another website when I did a web search for "GE Profile Oven F7 Issue". I sent an e-mail to him and he replied with free fix-it information. I am not a repair person myself, but, his instructions are very clear and simple to follow. I did the fix-it at no cost in approximately 10 minutes and it has solved my problem
Jul 30, 2009 | GE JTP20 Electric Single Oven
F7 Code on my GE Profile Oven
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Jun 17, 2009 | GE Profile JTP18 Electric Single Oven
GE JT912-30 single wall oven "help" with F7 - F0 error
I have a double oven GE Profile. The error message FO appeared. I shut off the circuit breaker for 30 minutes or more and the oven works but without warning FO reappears. FO message means there is short in the clear Off touch button. The only solution replace the complete panel. My cost delivered $328. Ouch!
Jan 19, 2009 | GE Profile JKP56 Electric Double Oven
JKP18 WALL OVEN IS A PIECE OF JUNK
http://www.fixya.com/howto/h155060-dreaded_f7_error    Go to the above link.  I will fix it.
Aug 17, 2008 | GE Profile JTP18 Electric Single Oven
F7 Error on the above range
There is a fix for the F7 error. Search for Powerman + GE + F7
Apr 27, 2008 | GE Profile JT910SASS Electric Single Oven
GE Profile JGB97 Self Cleaning Oven Controls won't work
You have a problem that may be solved with my solution to the Dreaded F7 Problem. Even though you don't have a F7 error on the display the symptoms are all the same. You can find my fix at the following links.
I have shared this with more than 1550 folks and most report success. This problem often develops after a self clean cycle.
I hope it works for you too. Please let me know at the following:
hutchipop@yahoo.com
Good Luck,
Charlie Popeck,P.E.
Consulting Engineer
Feb 06, 2008 | Ovens
GE Profile JT912 Electric Single Oven Logo
150 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
